7 Replies Latest reply: Apr 5, 2012 6:47 PM by Pierce Ewards RSS
    Flash uninstaller - Strange activity
    Pierce Ewards Community Member
      Hello,
      I noticed some unusual behavior with the latest flash uninstaller, can someone explain please?
      I download the 32bit flash uninstaller for Windows.
      http://helpx.adobe.com/flash-player/kb/uninstall-flash-player-windows.html
      When I double-click the uninstaller, a confirmation window appears asking whether I want to run the file.
      I select run, then a 2nd confirmation window appears asking again if I want to run the file.
      When I select run this time, I get a UAC prompt asking if I want to continue.
      Why are there 2 request to run the uninstaller?
      If I select run for the first prompt, but cancel the second prompt, the UI for the flash player uninstaller still appears.
      I didn't go any further as this behavior was suspicious enough for me to stop. Instead I used a previously saved flash player uninstaller.
      I'm wondering what would that second run prompt have executed if I had let it run?
      Pierce.
        • 1. Re: Flash uninstaller - Strange activity
          Manish-Sharma FormerEmployees
          Just single click on the uninstaller and check , do you get the confirmation window.
          also turnoff the UAC and then check.
          • 2. Re: Flash uninstaller - Strange activity
            Jeff A Wright Adobe Employee
            Moving this discussion to the Installing Flash Player forum.
            • 3. Re: Flash uninstaller - Strange activity
              pwillener ACP/MVPs
              What is your Windows version?
              What you describe I have seen happening when I accidentally triple-click an executable.
              Can you try again with a right-click, then Open (or Run)?
              • 4. Re: Flash uninstaller - Strange activity
                Thanks for the replies.
                System is Vista SP2 x86.
                Behavior is still the same if I right-click and select open.
                I'm still presented with 2 run windows, with only the 2nd one requiring UAC confirmation.
                I was also thinking maybe I had executed the uninstaller twice, but surely then I would be seeing a UAC prompt after clicking run on both confirmation windows, not just one.
                Thanks.
                • 5. Re: Flash uninstaller - Strange activity
                  pwillener ACP/MVPs
                  I do not know why this is happening; never seen this before.
                  Can you try to let it run completely (by clicking OK every time it asks), then post the contents of the FlashInstall.log file (from C:\Windows\system32\Macromed\Flash) here in the forum?  Maybe we can see from that log file what is happening.
                  • 6. Re: Flash uninstaller - Strange activity
                    chris.campbell Adobe Employee
                    Could you post the contents of your flashinstall.log so we can review it?
                    Where do I find the Flash Player installation log on Windows?
                    Chris
                    • 7. Re: Flash uninstaller - Strange activity
                      Sure.
                      =O====== M/11.2.202.228 2012-04-04+01-14-35.098 ========
                      0000 [I] 00000010 "C:\Users\Pierce\Downloads\install_flash_player_11_plugin_32bit.exe"
                      0001 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/Version 2
                      0002 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0003 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/Version 2
                      0004 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                      0005 [I] 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
                      0006 [W] 00001037 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
                      0007 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
                      0008 [W] 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
                      0009 [W] 00001036 Software\Opera Software/Last CommandLine 2
                      0010 [W] 00001036 Software\Opera Software/Last CommandLine 2
                      0011 [W] 00001036 Software\Opera Software/Plugin Path 2
                      0012 [W] 00001036 Software\Opera Software/Plugin Path 2
                      0013 [I] 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32_11_2_202_228.dll
                      0014 [I] 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_2_202_228_Plugin.exe
                      0015 [I] 00000017 C:\Windows\system32\Macromed\Flash
                      0016 [I] 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
                      0017 [I] 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
                      0018 [W] 00001102
                      0019 [W] 00001106
                      =X====== M/11.2.202.228 2012-04-04+01-14-53.303 ========
