1. Re: Not Enough Memory Errors
Scooby007 Apr 3, 2012 2:03 PM (in response to kayakcookman)2gb is way underpowered. Try 8 minimum. RAM is very cheap.
2. Re: Not Enough Memory Errors
Rusty Sterling Apr 3, 2012 2:21 PM (in response to Scooby007)Agreed that 2GB is seriously deficient. However, since you are on a 32-bit version of Vista, you won't get any benefit by installing 8GB since the OS will only recognize 3GB. So I'd suggest you upgrade to 4GB at least -- even though you'll only have 3GB available for programs. That would be the very least I'd suggest.
But, frankly, I'd upgrade to a 64-bit system (Win7) and 8GB of RAM. You will see a serious increase in performance all around.
3. Re: Not Enough Memory Errors
Scooby007 Apr 3, 2012 2:58 PM (in response to kayakcookman)Yes, good catch Rusty, no more than 2 (2.25 actually) in 32-bit, so I second Rusty's recommendation
4. Re: Not Enough Memory Errors
kayakcookman Apr 3, 2012 3:16 PM (in response to Scooby007)Brett & Rusty ...
Thanks for the suggestions; more RAM would certainly be helpful.
What is interesting is that I've exported many photos [often in batches] with LR4 without issues; it is only when I started applying develop settings to the exported photos did I start getting the out of memory dialogs. Maybe related?
But no doubt that upgrading the PC to a 64 bit box would be the thing to do; maybe after Win 8 gets final release.
Thanks again.
5. Re: Not Enough Memory Errors
Rusty Sterling Apr 3, 2012 10:30 PM (in response to kayakcookman)Frankly, I wouldn't wait for Win 8. It is designed primarily for a touch-screen experience similar to tablets and smart phones. While Win 7 is also not very well thought of, I'd still go with it over Win 8. I use Win 7 on one of my laptops and on a partition on my iMac (it's for programs I need but cannot get for Mac). I'm not unhappy with it at all.
6. Re: Not Enough Memory Errors
mangray Apr 3, 2012 11:36 PM (in response to kayakcookman)I have the same misstake!
LW3.6 works fine on my W7 32bit 4GByte RAM.
But LW4 Not Enough Memory and slow!
Where is not come a update I no buy this Version!
nice day
mangray
7. Re: Not Enough Memory Errors
Rusty Sterling Apr 4, 2012 9:24 AM (in response to mangray)Sorry to hear that mangray. It seems 64-bit is the key. With 32-bit you are not using the full 4GB of RAM. It is important that besides having a 64-bit OS you also need a platform (i.e., computer) that supports 64-bit. Adobe has not hidden anything regarding the 64-bit necessity for LR4. They did accommodate those on Windows 32-bit machines running Vista and up (nothing for 32-bit Mac users). But they did not promise a bed of roses. Technology is ever advancing and that includes the platforms.
8. Re: Not Enough Memory Errors
mangray Apr 4, 2012 11:33 AM (in response to Rusty Sterling)Ok Rusty,
This are the official ADOBE spec.
Windows
- Intel® Pentium® 4 or AMD Athlon® 64 processor
- Microsoft® Windows Vista® with Service Pack 2 or Windows® 7 with Service Pack 1
- 2GB of RAM
- 1GB of available hard-disk space
- 1024x768 display
- DVD-ROM drive
- Internet connection required for Internet-based services*
Premiere, Photoshop etc runs fine, my friend have a similar System it runs
better, no Error
I export only one Picture in LR4 and its come Not Enough Memory.
I export in LR3.6 120 Pictures and works fine!!!!
nice day
mangray
9. Re: Not Enough Memory Errors
Scooby007 Apr 4, 2012 12:16 PM (in response to kayakcookman)OP - But no doubt that upgrading the PC to a 64 bit box would be the thing to do; maybe after Win 8 gets final release.
No reason to wait. Windows 7 is an absolutely brilliant OS, and Win8 is basically Win7 with a new mobile interface added on top of it (that can easily be turned off).
Rusty - While Win 7 is also not very well thought of
Where? No way.
Ok Rusty,
Like a "two-person" tent. Minimum specs should not be taken seriously.
10. Re: Not Enough Memory Errors
kayakcookman Apr 5, 2012 7:46 AM (in response to kayakcookman)I'll offer a little more input here ...
I've been watching memory usage [with Task Manager]; normally, total memory in use will stay under 1.6 GB; but for some reason, if I work continuously in LR4 [going back and forth between Library and Map] placing photos on a map background, after a while, memory usage will then start to creep upwards towards 1.9 GB.
From my past experiences testing demanding software for software manufacturing companies, this behavior is often suggestive of a memory leak within the [LR4] application.
I understand that, on 32 bit machines, LR4 is coded so as not use more than 1 GB RAM, so a creep up in memory use [only LR4 in use] might indicate some buffer clearing is not always working as expected?
11. Re: Not Enough Memory Errors
Scooby007 Apr 5, 2012 11:00 AM (in response to kayakcookman)I've seen LR4 use more than 8gb of my 16gb of ram
12. Re: Not Enough Memory Errors
Bill Ingle Apr 5, 2012 12:07 PM (in response to kayakcookman)I'm having the exact same problem, and I'm running 16gb physical memory (32bit Win7). I'm having the same problem with 4.0 and RC 4.1. I've uninstalled and am dropping back to 3.6. I'll just wait until this beta testing phase is over and the real release version comes out (Version 4.5?). It's too much hassle for me to pay adobe to do their beta testing for them.
13. Re: Not Enough Memory Errors
carlosg980703 Feb 4, 2015 12:29 PM (in response to kayakcookman)Hi, is not a problem of memory ....... the original catalog that lightroom create do not allow you to save ...... try to create a new catalog and move all your photos to that catalog and export from the new catalog. Good luck
cg
14. Re: Not Enough Memory Errors
carlosg980703 Feb 5, 2015 8:17 AM (in response to kayakcookman)I had the same problem. Try creating a new catalog ..... that was the solution on my computer and still working fine.
15. Re: Not Enough Memory Errors
d.plummer Sep 2, 2015 2:35 AM (in response to kayakcookman)1 person found this helpfulI had similar problem but my RAM is 4GB and im running windows 10. No amount of adjusting jpeg size/quality would let it export the edited image to the hard drive. Got it to work by left clicking the 'windows icon' in the lower lefthand corner, then right clicking on the 'Lightroom' app/program and then left clicking on 'run as administrator'...
16. Re: Not Enough Memory Errors
alanr94978119 Jul 24, 2016 8:36 AM (in response to d.plummer)Nice, it worked
