7 Replies Latest reply on Apr 4, 2012 2:28 AM by Lilybiri
    Allowing student multiple attempts to answer a question
      I have created a multiple-choice quiz which has three questions, one correct and two distractors.
      The quiz works fine as long as you select the correct answer on your first attempt. If you select either the two incorrect answers, the quiz slide will  "auto advance" before you had a chance to select another answer. Whilst it is possible to go back to the question slide I would like the participant to have at least four attempts to get it right before the quiz slide "auto advances".
      In terms of setup, the question properties are set to allow four  attempts before failure
      .I have also tried to set the actions on failure to "no action" but this has absolutely no effect.
      Similarly setting the preferences to show "retake button" does not seem to work.
      I'd be very grateful for any help that anyone could give.
