2 Replies Latest reply on Apr 4, 2012 7:38 AM by Rob Hecker2
    8 or 16 bits, that's the question
    AdobeCoussini
      I want to know wich color deep must i take for my web site.
      Just to learn some word about me, i a new born in this websitedesign world.
      But i know that many user have a good monitor can be use 16 bits or more in colors.
      So, i know that you can create gradient color in your web page.
      Finally, 8 bits is it "IN" or "OUT" actually. Is is old stud, and should i go for 16 bits for any web browser.
      Thanks.... a lot for any answer.
      Sorry, i speak french usualy !
        • 1. Re: 8 or 16 bits, that's the question
          Ben M Adobe Community Professional
          You say you are new to web design, but are you new to design?  I ask because if you are speaking in terms of something like Photoshpo with 8 bits per channel, then yes 8 bits is more than sufficient.  More than that is only needed for print mediums.
          When discussing file formats, I would typically stick to PNG or JPG depending on the nature of the image and whether or not you need transparency.  For instance PNG supports transparency in images whereas JPG files do not.
          • 2. Re: 8 or 16 bits, that's the question
            Rob Hecker2 Adobe Community Professional & MVP
            When you use SAVE FOR WEB in Photoshop or Illustrator, all images are saved as 8 bit, that's because it is impossible to use 16 bit images on the web. If anyone doesn't believe me, try using a 16 bit image. It will not work.
            As for image type, I try to use GIF as much as possible, for clean graphical elements. You have good control and the images can be very small.Of course it is not the type of choice for photographs.
