Dive into Adobe Summit 2024! Explore curated list of AEM sessions & labs, register, connect with experts, ask questions, engage, and share insights. Don't miss the excitement.
Gemfire problem
Avatar
Former Community Member
I have a problem with 2-node cluster installation of Livececle ES 8.2 Update 1.
After installing and configuring both jboss servers i get following errors on whichever server that is started second.
First error is allways (from server.log):
at  com.adobe.livecycle.cache.adapter.CacheAdapterFactory.getCache(CacheAdapterFactory.java:102)
with
Caused by:  com.gemstone.gemfire.SystemConnectException: Received no connection  acknowledgments from any of the 1 senior cache members: NODE1:2359/2356
at  com.gemstone.gemfire.distributed.internal.DistributionManager.sendStartupMessage(DistributionManager.java:2099)
at  com.gemstone.gemfire.distributed.internal.DistributionManager.create(DistributionManager.java:474)
at  com.gemstone.gemfire.distributed.internal.InternalDistributedSystem.initialize(InternalDistributedSystem.java:398)
at  com.gemstone.gemfire.distributed.internal.InternalDistributedSystem.<init>(InternalDistributedSystem.java:259)
at  com.gemstone.gemfire.distributed.internal.InternalDistributedSystem.newInstance(InternalDistributedSystem.java:161)
at  com.gemstone.gemfire.distributed.DistributedSystem.connect(DistributedSystem.java:745)
at  com.adobe.livecycle.cache.adapter.GemfireCacheAdapter.<clinit>(GemfireCacheAdapter.java:140)
...  222 more
These errors then repeat several times causing failed deployment for umcache.war and consequently failed deployment for livecycle core.
My gemfire.log shows:
[info 2009/05/08 15:50:48.328 CEST GemfireCacheAdapter <main> nid=0xba9340] GemFire P2P Listener started on tcp:///172.16.131.72:2246
[info 2009/05/08 15:51:04.015 CEST GemfireCacheAdapter <main> nid=0xba9340] Starting distribution manager NODE2:2249/2246
[info 2009/05/08 15:51:20.531 CEST GemfireCacheAdapter <main> nid=0xba9340] Initial (membershipManager) view = [NODE1:2359/2356, LCPROD-NODE2:2249/2246]
[info 2009/05/08 15:51:20.531 CEST GemfireCacheAdapter <main> nid=0xba9340] DMMembership: admitting member <NODE1:2359/2356>; now there are 1 non-admin member(s)
[info 2009/05/08 15:51:20.531 CEST GemfireCacheAdapter <main> nid=0xba9340] DMMembership: admitting member <NODE2:2249/2246>; now there are 2 non-admin member(s)
[warning 2009/05/08 15:51:52.093 CEST  GemfireCacheAdapter <main> nid=0xba9340] Membership: received connection  from <NODE1:2359/2356> but received no startup response after 15000  ms.
[warning 2009/05/08 15:51:52.093 CEST  GemfireCacheAdapter <main> nid=0xba9340] Membership: startup timed out  after waiting 15000 milliseconds for responses from  [NODE1:2359/2356]
[info 2009/05/08 15:51:53.203 CEST  GemfireCacheAdapter <main> nid=0xba9340] Now closing distribution for  NODE2:2249/2246
It seems that nodes are able to find each other via UDP multicast but node that is started first doesn't reply (in 15 seconds) to startup message sent by second node.
If i start one server with different multicast port (–Dadobe.multicast-port) so that nodes cannot see each other then both servers start without errors.
I followed all instructions for cluster deployment and installation to best of my knowledge but this error keeps appearing.
Please help.
Zeljko Vranic
Avatar
Level 7
Can you send the complete server.log files from both cluster members to dev_info@adobe.com?  Also, please send the Gemfire.log file from \LC_TEMP\<your_server_name>\Caching\ of both nodes.
Thanks.
Avatar
Employee
Using TCP locators instead of UDP for cluster caching resolved this issue.
Avatar
Level 7
Can anyone suggest how to implement the TCP locators on Windows to start automatically, rather than manually calling the start and stop locators
Aditya
Avatar
Employee
Adobe does not test or provide a specific solution, leaving this up to the customer. Some customers have used the Java Services Wrapper to handle and manage running the TCP Locator as a windows service. http://wrapper.tanukisoftware.com/doc/english/download.jsp
Ameeth
