5 Replies Latest reply on Apr 4, 2012 1:21 PM by MarkWalsh
    Help! multi-calculation JS needed...I have no clue!
    KateZB
      Hello, I have a horrific (to my mind) multi-step problem...and I figured out the math I need to use, but not sure how the heck to get it to work in JS - I am at wits' end!
      Please, gurus of JS, help me!
      So:
      1. The User types a number into "cell a"
      2. The number in "cell a" needs to be x by $120
      3. then the resulting value of "cell a x $120" is then x by 40%, which populates "cell b"
      4. then "cell b" is x by .9782, and populates "cell c"
      5. To get the value for "cell d", divide "cell c" by "cell a".
      Now, for the most evil part to my non-scripting mind:
      6. if the value of "cell d" is less-than $48, multiply "cell d" by $48 anyway to get the value for "cell e"
          If the value for "cell d" is greater than $48, use the greater number to calculate "cell e".
      Argh! Ack!
      There is more to the form, but I can figure out those bibs and bobs...it's just the run above is making my eyes cross.
        • 1. Re: Help! multi-calculation JS needed...I have no clue!
          MarkWalsh Champion
          Do you know how to do 1-5?
          The calculation for #6 is actually much simpler than you are making it - just use the Max of '48' and 'cell d' to calculate 'cell e' (you haven't quite explained clearly how you are calculating 'cell e' -- are you multiplying cell d by itself?)
          var cellD = this.getField('cell d').value
          var multiplier = Math.max(48, cellD);
          this.getField('cell e') = multiplier * cellD  // Is this what you want?
          • 2. Re: Help! multi-calculation JS needed...I have no clue!
            KateZB Newcomer
            Hi Mark, thanks for replying!
            The more I look at it, the more it doesn't make any sense! I'm going to work through the sheet again (gah, wish I could attach the file I'm working on).
            • 3. Re: Help! multi-calculation JS needed...I have no clue!
              MarkWalsh Champion
              It often helps to use descriptive names for your fields (and variables). 'cell a', 'cell b', etc. don't really help much.
              I am guessing at what your values are representing:
              'cell a' = QTY
              $120 = Price (per unit)
              40% = Discount??
              'cell b' = Total Price (line item)
              'cell c' = ??
              'cell d' = ??
              'cell e' = ??
              So, an example to understand what is happening with the numbers (X represents the unknown multiplier that I questioned for cell e):
              'cell a' = 5
              'cell b' = 5 * $120 * .4     [240]
              'cell c' = 240 * .9782       [234.768]
              'cell d' = 234.768 / 5       [46.9536]
              'cell e' = X * Max(48, 46.9536)       [ X * 48]
              Is this correct?
              • 4. Re: Help! multi-calculation JS needed...I have no clue!
                KateZB Newcomer
                Hi Mark,
                That is amazing - pretty much exactly what I am looking for...this is the original part of the "evil" document:
                So # of candidates*120*.4*.9782 = Total USA
                Test Rate is Total USD/# of Candidates
                Test rate, if < $48, is calculated for Total as ($48*# of Candidates) anyway.
                if the Test Rate is > $48, it is calculated at the higher rate for Total (Higher Rate*Number of candidates)
                *phew*...I see what I had missing in "cell e" now!
                • 5. Re: Help! multi-calculation JS needed...I have no clue!
                  MarkWalsh Champion
                  This still doesn't make much sense to me.
                  According to that, Test Rate will always be the same: 120 * .4 * .9782     [46.9536]
                  TotalUSD = #Cand * (120*.4*.9782)
                  TestRate = TotalUSD / #Cand
                  is the same as
                  TestRate = #Cand * (120*.4*.9782) / #Cand
                  is the same as
                  TestRate = #Cand/ #Cand * (120*.4*.9782)
                  is the same as
                  TestRate = 1 * (120*.4*.9782)
