11 Replies Latest reply on Apr 9, 2012 6:57 AM by creativesurfacesamanda
    Problems printing a postscript in Illustrator CS4
    creativesurfacesamanda Newcomer
      I am trying to print a PS in illustrator CS4.  The file is quite large, 388 MB. However, this is usually not a problem.  I work at a sign company that produces casino signage, so the files from our client are quite large. Any suggestions as to why the program stalls when trying to print?  Many times the program crashes all together.  My operating system is Snow Lepoard (OS X 10.6.8), if it helps.  I have read somewhere in one of these forums, that it may be caused by the fact that Illustrator is not made for 64 bit systems just yet, thus causing a slow down or even an unexpected quit.  I have tried dumping preferences, as others on here have suggested. I have also went in & dumped the odd-ball PPD folders within the Library & then restarted.  I have tried shutting down, then "safe-boot" open the system back up. I have also "Verified Disk" numerous times.  All of these options don't seem to help at all.  When it comes down to the file itself, Illustrator fails.  I have even tried to created the file over again in a brand new document, as I figured that file must have been corrupt.  No such luck.   Anyone out there happen to have some other suggestions on what to do to get this to, at the least, print to a postscript?  Currently the print screen doesn't even pop up.
        • 1. Re: Problems printing a postscript in Illustrator CS4
          Manish-Sharma Ninja
          Remove the following files and back them up
          Hard Drive]/Library/Printers/PPDs/contents/Resources/en.lproj
          [Hard Drive]/Library/Printers/PPDs/contents/Resources/Zh_CN.lproj
          [Hard Drive]/Library/Printers/PPDs/contents/Resources/Ja.lproj
          [Hard Drive]/Library/Printers/PPDs/contents/Resources/ko.lproj
          [Hard Drive]/Library/Printers/PPDs/contents/Resources/Zh_TW.lproj
          • 2. Re: Problems printing a postscript in Illustrator CS4
            Yes, Manish.  I have removed all of these.  Thanks!
            • 5. Re: Problems printing a postscript in Illustrator CS4
              Manish-Sharma Ninja
              Check after reseting the preferences:-
              Users/Username/Library/Preferences/Adobe Illustrator CS #(version Number)Settings
              and from new user account
              • 6. Re: Problems printing a postscript in Illustrator CS4
                John Danek Champion
                You do not mention the printer itself.  Are you processing via a Postscript RIP?  I sense you may be running low on system real estate ( i.e., scratch disk memory and / or RAM ).  Try closing all other apps, well all apps and restart.  Then just open Illustrator and see if the file will open and print.  All of this deleting of system resources is not necessary yet.  How much disk space do you have available for scratch?
                • 7. Re: Problems printing a postscript in Illustrator CS4
                  I am trying to print via Postscript RIP. The .PS file will then be put on the server for our printer in another department to pull down.  He brings up the PS file into his WASATCH RIP software.
                  I have 177.85 GB available – that is not the issue.  I have also tried closing all programs & only have the one open. I have even done what you have suggested, John.  No dice.
                  • 8. Re: Problems printing a postscript in Illustrator CS4
                    These are the details to the most current crash that happened about 10 mins ago......   I had shut off a layer & then tried to print.  It crashed.
                    Process:     Adobe Illustrator [1685]
                    Path:        /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/MacOS/Adobe Illustrator
                    Identifier:  com.adobe.illustrator
                    Version:     367 (14.0.0)
                    Code Type:   X86 (Native)
                    Parent Process:  launchd [130]
                    Date/Time:   2012-04-05 09:56:16.373 -0500
                    OS Version:  Mac OS X 10.6.8 (10K549)
                    Report Version:  6
                    Interval Since Last Report:      84649 sec
                    Crashes Since Last Report:       8
                    Per-App Interval Since Last Report:  78248 sec
                    Per-App Crashes Since Last Report:   8
                    Anonymous UUID:                  4927D96A-08FA-473E-A069-6BF9A894DCD4
                    Exception Type:  EXC_BAD_ACCESS (SIGBUS)
                    Exception Codes: KERN_PROTECTION_FAILURE at 0x00000000000cca20
                    Crashed Thread:  0  Dispatch queue: com.apple.main-thread
                    Thread 0 Crashed:  Dispatch queue: com.apple.main-thread
                    0   com.apple.QD              0x08263704 BBFastDoubleSrcCopy + 405
                    1   com.apple.QD              0x082a6210 Stretch + 3515
                    2   com.apple.QD              0x0826a27a OneSrcOneDst + 59
                    3   com.apple.QD              0x0826aeb8 CommonBits + 1316
                    4   com.apple.QD              0x0826c490 StdBits + 878
                    5   com.apple.QD              0x0826abee CommonBits + 602
                    6   com.apple.QD              0x0826b717 CopyBits + 780
                    7   com.adobe.coretech.adm    0x14965975 0x14900000 + 416117
                    8   com.adobe.coretech.adm    0x1491c212 0x14900000 + 115218
                    9   com.adobe.coretech.adm    0x14920a8a 0x14900000 + 133770
                    10  ...e.illustrator.plugins.Print0x12ae61bb 0x12ab6000 + 197051
                    11  ...e.illustrator.plugins.Print0x12ae6ab8 0x12ab6000 + 199352
                    12  com.adobe.coretech.adm    0x14908e43 0x14900000 + 36419
                    13  com.adobe.coretech.adm    0x1496326c 0x14900000 + 406124
                    14  com.adobe.coretech.adm    0x14959efd 0x14900000 + 368381
                    15  com.adobe.coretech.adm    0x1491a7cf 0x14900000 + 108495
                    16  com.adobe.coretech.adm    0x14908e43 0x14900000 + 36419
                    17  com.adobe.coretech.adm    0x14958fa5 0x14900000 + 364453
                    18  com.adobe.coretech.adm    0x1495e42e 0x14900000 + 386094
                    19  com.apple.HIToolbox       0x05566c2f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
                    20  com.apple.HIToolbox       0x05565ef6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
                    21  com.apple.HIToolbox       0x055887f3 SendEventToEventTarget + 52
                    22  com.apple.HIToolbox       0x055990f9 SendEvent(unsigned long, WindowData*, OpaqueRgnHandle*) + 203
                    23  com.apple.HIToolbox       0x05598f84 PaintWindow(WindowData*, OpaqueRgnHandle*, PaintReason, bool) + 495
                    24  com.apple.HIToolbox       0x0558bdd8 WindowData::PrepareForVisibility() + 236
                    25  com.apple.HIToolbox       0x0558b338 _ShowHideWindows + 291
                    26  com.apple.HIToolbox       0x0558b212 ShowHide + 38
                    27  com.adobe.coretech.adm    0x1497b4bf 0x14900000 + 505023
                    28  com.adobe.coretech.adm    0x1495dc99 0x14900000 + 384153
                    29  com.adobe.coretech.adm    0x14919ebe 0x14900000 + 106174
                    30  ...e.illustrator.plugins.Print0x12ae2206 0x12ab6000 + 180742
                    31  com.adobe.coretech.adm    0x14908d85 0x14900000 + 36229
                    32  com.adobe.coretech.adm    0x1491162f 0x14900000 + 71215
                    33  com.adobe.coretech.adm    0x149127fb 0x14900000 + 75771
                    34  com.adobe.coretech.adm    0x1495a871 0x14900000 + 370801
                    35  com.adobe.coretech.adm    0x14918c53 0x14900000 + 101459
                    36  ...e.illustrator.plugins.Print0x12abfbc8 0x12ab6000 + 39880
                    37  ...e.illustrator.plugins.Print0x12ab78ff 0x12ab6000 + 6399
                    38  ...e.illustrator.plugins.Print0x12abdfee 0x12ab6000 + 32750
                    39  ...e.illustrator.plugins.Print0x12ae89ee PluginMain + 422
                    40  com.adobe.illustrator     0x006a93ff 0x1000 + 6980607
                    41  com.adobe.illustrator     0x006a89c6 0x1000 + 6977990
                    42  com.adobe.illustrator     0x00586d75 0x1000 + 5791093
                    43  com.adobe.illustrator     0x00160725 0x1000 + 1439525
                    44  com.adobe.illustrator     0x003f2ac2 0x1000 + 4135618
                    45  com.adobe.illustrator     0x004d43e5 0x1000 + 5059557
                    46  com.adobe.illustrator     0x000fedbe 0x1000 + 1039806
                    47  com.apple.HIToolbox       0x05566c2f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
                    48  com.apple.HIToolbox       0x05565ef6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
                    49  com.apple.HIToolbox       0x055887f3 SendEventToEventTarget + 52
                    50  com.apple.HIToolbox       0x055b4e87 SendHICommandEvent(unsigned long, HICommand const*, unsigned long, unsigned long, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 448
                    51  com.apple.HIToolbox       0x05711ed6 ProcessHICommand + 68
                    52  com.adobe.illustrator     0x000feb75 0x1000 + 1039221
                    53  com.apple.HIToolbox       0x05566c2f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
                    54  com.apple.HIToolbox       0x05565ef6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
                    55  com.apple.HIToolbox       0x055887f3 SendEventToEventTarget + 52
                    56  com.adobe.illustrator     0x00080d3e 0x1000 + 523582
                    57  com.apple.HIToolbox       0x05566c2f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
                    58  com.apple.HIToolbox       0x05565ef6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
                    59  com.apple.HIToolbox       0x05565d55 SendEventToEventTargetWithOptions + 58
                    60  com.apple.HIToolbox       0x0559aa24 ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 3006
                    61  com.apple.HIToolbox       0x05567080 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2672
                    62  com.apple.HIToolbox       0x05565ef6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
                    63  com.apple.HIToolbox       0x055887f3 SendEventToEventTarget + 52
                    64  com.apple.HIToolbox       0x05711c17 ToolboxEventDispatcher + 86
                    65  com.apple.HIToolbox       0x05711d4f RunApplicationEventLoop + 243
                    66  com.adobe.illustrator     0x00080f83 0x1000 + 524163
                    67  com.adobe.illustrator     0x000d84ab 0x1000 + 881835
                    68  com.adobe.illustrator     0x000a2cd2 0x1000 + 662738
                    69  com.adobe.illustrator     0x00003672 0x1000 + 9842
                    70  com.adobe.illustrator     0x00003599 0x1000 + 9625
                    Thread 1:  Dispatch queue: com.apple.libdispatch-manager
                    0   libSystem.B.dylib         0x05335382 kevent + 10
                    1   libSystem.B.dylib         0x05335a9c _dispatch_mgr_invoke + 215
                    2   libSystem.B.dylib         0x05334f59 _dispatch_queue_invoke + 163
                    3   libSystem.B.dylib         0x05334cfe _dispatch_worker_thread2 + 240
                    4   libSystem.B.dylib         0x05334781 _pthread_wqthread + 390
                    5   libSystem.B.dylib         0x053345c6 start_wqthread + 30
                    Thread 2:
                    0   libSystem.B.dylib         0x0530eb42 semaphore_wait_signal_trap + 10
                    1   libSystem.B.dylib         0x0533c6f8 _pthread_cond_wait + 1089
                    2   libSystem.B.dylib         0x0538505f pthread_cond_wait + 48
                    3   com.adobe.amt.services    0x047e2552 AMTConditionLock::LockWhenCondition(int) + 46
                    4   com.adobe.amt.services    0x047dd995 _AMTThreadedPCDService::PCDThreadWorker(_AMTThreadedPCDService*) + 115
                    5   com.adobe.amt.services    0x047e25b0 AMTThread::Worker(void*) + 20
                    6   libSystem.B.dylib         0x0533c259 _pthread_start + 345
                    7   libSystem.B.dylib         0x0533c0de thread_start + 34
                    Thread 3:
                    0   libSystem.B.dylib         0x0533caa2 __semwait_signal + 10
                    1   libSystem.B.dylib         0x0533c75e _pthread_cond_wait + 1191
                    2   libSystem.B.dylib         0x0533e3f8 pthread_cond_wait$UNIX2003 + 73
                    3   ...ple.CoreServices.CarbonCore0x05f8e21e TSWaitOnCondition + 126
                    4   ...ple.CoreServices.CarbonCore0x05f79b68 TSWaitOnConditionTimedRelative + 202
                    5   ...ple.CoreServices.CarbonCore0x05f75533 MPWaitOnQueue + 250
                    6   AdobeACE                  0x0132038d 0x12ef000 + 201613
                    7   AdobeACE                  0x0131fd85 0x12ef000 + 200069
                    8   ...ple.CoreServices.CarbonCore0x05f5954a PrivateMPEntryPoint + 68
                    9   libSystem.B.dylib         0x0533c259 _pthread_start + 345
                    10  libSystem.B.dylib         0x0533c0de thread_start + 34
                    Thread 4:
                    Thread 5:
                    Thread 6:
                    0   libSystem.B.dylib         0x0530eafa mach_msg_trap + 10
                    1   libSystem.B.dylib         0x0530f267 mach_msg + 68
                    2   ...ia.Flash Player.authplaylib0x1872363e ExternalPlayer_Initialize + 1865604
                    3   libSystem.B.dylib         0x0533c259 _pthread_start + 345
                    4   libSystem.B.dylib         0x0533c0de thread_start + 34
                    Thread 7:
                    3   ...ia.Flash Player.authplaylib0x1854fba6 0x18268000 + 3046310
                    4   ...ia.Flash Player.authplaylib0x18571f81 ExternalPlayer_Initialize + 90311
                    5   ...ia.Flash Player.authplaylib0x1854ff98 0x18268000 + 3047320
                    Thread 8:
                    Thread 9:
                    Thread 10:
                    Thread 11:
                    0   libSystem.B.dylib         0x0530ec0e mach_wait_until + 10
                    1   libSystem.B.dylib         0x05396429 nanosleep + 345
                    2   ...r.plugins.Scripting Support0x14dc589d PluginMain + 458031
                    3   ...r.plugins.Scripting Support0x14dc58fd PluginMain + 458127
                    4   ...r.plugins.Scripting Support0x14dc9402 PluginMain + 473236
                    5   ...r.plugins.Scripting Support0x14dc5bbf PluginMain + 458833
                    Thread 12:
                    0   libSystem.B.dylib         0x0530eb36 semaphore_wait_trap + 10
                    1   com.adobe.illustrator     0x00af8512 AWS_CUI_RevertAlert(OpaqueWindowPtr*, adobe::aws::gen::String<unsigned short>&, adobe::aws::gen::String<unsigned short>&) + 471694
                    2   com.adobe.illustrator     0x00526ec1 0x1000 + 5398209
                    3   com.adobe.illustrator     0x0052713b 0x1000 + 5398843
                    4   ...ple.CoreServices.CarbonCore0x05f5954a PrivateMPEntryPoint + 68
                    5   libSystem.B.dylib         0x0533c259 _pthread_start + 345
                    6   libSystem.B.dylib         0x0533c0de thread_start + 34
                    Thread 13:
                    Thread 14:
                    0   libSystem.B.dylib         0x0530eb4e semaphore_timedwait_trap + 10
                    1   ...ple.CoreServices.CarbonCore0x05f8b942 MPWaitOnSemaphore + 125
                    2   MultiProcessor Support    0x130c6eff 0x13097000 + 196351
                    3   ...ple.CoreServices.CarbonCore0x05f5954a PrivateMPEntryPoint + 68
                    4   libSystem.B.dylib         0x0533c259 _pthread_start + 345
                    5   libSystem.B.dylib         0x0533c0de thread_start + 34
                    Thread 15:
                    Thread 16:
                    Thread 0 crashed with X86 Thread State (32-bit):
                      eax: 0xff030303  ebx: 0x0000002e  ecx: 0x00000000  edx: 0x000cca20
                      edi: 0xbfffc180  esi: 0x0000002e  ebp: 0xbfffba18  esp: 0xbfffb9b0
                       ss: 0x0000001f  efl: 0x00010286  eip: 0x08263704   cs: 0x00000017
                       ds: 0x0000001f   es: 0x0000001f   fs: 0x00000000   gs: 0x00000037
                      cr2: 0x000cca20
                    Binary Images:
                    0x1000 -   0xe8eff3 +com.adobe.illustrator 367 (14.0.0) <F586A10F-F480-4783-A20B-C006B6321F47> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/MacOS/Adobe Illustrator
                    0x1190000 -  0x11a0fff  com.apple.carbonframeworktemplate 1.0 (1.0) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/Alcid.framework/Versions/A/Alcid
                    0x11a7000 -  0x11b5fe7  libz.1.dylib 1.2.3 (compatibility 1.0.0) <33C1B260-ED05-945D-FC33-EF56EC791E2E> /usr/lib/libz.1.dylib
                    0x11ba000 -  0x11baff7  com.apple.Carbon 150 (152) <BFDDA394-0F01-A3A3-A226-ED3A45975A56> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
                    0x11bd000 -  0x11d8ff9 +AdobePDFSettings ??? (???) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobePDFSettings.framework/Versions/A/AdobePDFSetting s
                    0x11f2000 -  0x1242fff +com.adobe.illustrator.aiport AIPort version 1.0 (1.0) <F625B836-9616-46B7-B681-F9AC11D0DA71> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AIPort.framework/Versions/A/AIPort
                    0x12db000 -  0x12dc027 +SPBasic ??? (???) <B1DC5A08-15C4-49F9-9DF1-6A94E0AD3448> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/SPBasic.framework/Versions/A/SPBasic
                    0x12e0000 -  0x12e6ff7 +com.adobe.coretech.adobesplashkit AdobeSplashKit version 1.0 (1.0) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobeSplashKit.framework/Versions/A/AdobeSplashKit
                    0x12ef000 -  0x13fcfff +AdobeACE ??? (???) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
                    0x141a000 -  0x1931fef +AdobeAGM ??? (???) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
                    0x1aaa000 -  0x1aeafef +AdobeARE ??? (???) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
                    0x1af4000 -  0x1b18ff6 +AdobeAXE8SharedExpat ??? (???) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8Sh aredExpat
                    0x1b2b000 -  0x1b45fff +AdobeBIB ??? (???) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
                    0x1b50000 -  0x1b71ff7 +AdobeBIBUtils ??? (???) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
                    0x1b7e000 -  0x1e1afef +AdobeCoolType ??? (???) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
                    0x1ea5000 -  0x1f73fff +AdobeExtendScript 3.7.0 (compatibility 3.7.0) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScr ipt
                    0x1fea000 -  0x20d2fdf +AdobePDFPort ??? (???) <F54A25D1-5E7A-472E-83D1-10D187434C85> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobePDFPort.framework/Versions/A/AdobePDFPort
                    0x2117000 -  0x270ffdf +AdobePDFL ??? (???) <8EC2ABBA-52D2-4230-B327-A6827FB2D33A> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobePDFL.framework/Versions/A/AdobePDFL
                    0x2853000 -  0x28f4fd7 +AdobeScCore 3.7.0 (compatibility 3.7.0) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
                    0x2950000 -  0x29fefd7 +AdobeSVGExport ??? (???) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobeSVGExport.framework/Versions/A/AdobeSVGExport
                    0x2a30000 -  0x2cd9fe2 +AdobeSVGRE ??? (???) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobeSVGRE.framework/Versions/A/AdobeSVGRE
                    0x2dc3000 -  0x2e23fc7 +AdobeXMP ??? (???) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
                    0x2e32000 -  0x2f07fdd +FileInfo ??? (???) <F0932F89-FC98-4BA9-B4F2-C58D0E71D3C1> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/FileInfo.framework/Versions/A/FileInfo
                    0x2f38000 -  0x2f38ff7  com.apple.Cocoa 6.6 (???) <EA27B428-5904-B00B-397A-185588698BCC> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
                    0x2f3b000 -  0x2fbdfd7 +AdobeXMPFiles ??? (???) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
                    0x2fd4000 -  0x30a323b +libicui18n.dylib.36.0 36.0.0 (compatibility 36.0.0) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/ICUInternationalization.framework/Versions/3.6/libicu i18n.dylib.36.0
                    0x314c000 -  0x3220db7 +libicuuc.dylib.36.0 36.0.0 (compatibility 36.0.0) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/ICUUnicode.framework/Versions/3.6/libicuuc.dylib.36.0
                    0x3281000 -  0x3c3157f +libicudata.dylib.36.0 36.0.0 (compatibility 36.0.0) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/ICUData.framework/Versions/3.6/libicudata.dylib.36.0
                    0x3c34000 -  0x3ffefef +AdobeMPS ??? (???) <277E01A3-CAC3-4FA9-A591-4BC0A5BC125A> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
                    0x408d000 -  0x4243ff4 +com.adobe.amtlib amtlib 2.0.1.10077 (2.0.1.10077) <CB2EC3BF-6771-4DAB-BF29-6775FB6F9608> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
                    0x427a000 -  0x43072cb +libicucnv.dylib.36.0 36.0.0 (compatibility 36.0.0) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/ICUConverter.framework/Versions/3.6/libicucnv.dylib.3 6.0
                    0x4334000 -  0x470e01f +com.adobe.linguistic.LinguisticManager 4.0.0 (7863) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
                    0x47c2000 -  0x4863fc3 +com.adobe.amt.services AMTServices 2.0.1.10077 (BuildVersion: 53.352460; BuildDate: Tue Jul 29 2008 16:31:09) (2 . 0) <31E82904-C3C2-424E-A1AE-A5EFADBB19B8> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/amtservices.framework/Versions/A/amtservices
                    0x4941000 -  0x4e3ffc3 +AdobeOwlCanvas ??? (???) <DC1EE447-FCDB-43C8-B6D2-A5454291C85D> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobeOwlCanvas.framework/Versions/A/AdobeOwlCanvas
                    0x4f88000 -  0x5018fc3 +WRServices ??? (???) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
                    0x519a000 -  0x519effc +com.adobe.AdobeCrashReporter 2.5 (3.0.20080806) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashRep orter
                    0x51a4000 -  0x51c0fd7 +com.adobe.LogTransport 1.0 (1.0) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/LogTransport.framework/Versions/A/LogTransport
                    0x51cb000 -  0x51faff7 +com.adobe.headlights.LogSessionFramework ??? (2.0.0.06112008) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
                    0x5222000 -  0x5233ffb +LogTransport2 ??? (???) <835B7B84-5A67-370B-AB39-8E448AA81FA0> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/LogTransport2.framework/Versions/A/LogTransport2
                    0x523d000 -  0x5243fff +com.adobe.pip ??? (1.0.0.220) <2CA89939-DFA7-4686-8536-8A1F1107CAF1> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobePIP.framework/Versions/A/AdobePIP
                    0x5249000 -  0x52b3fe7  libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
                    0x530e000 -  0x54b5ff7  libSystem.B.dylib 125.2.11 (compatibility 1.0.0) <2DCD13E3-1BD1-6F25-119A-3863A3848B90> /usr/lib/libSystem.B.dylib
                    0x5537000 -  0x5541fe7  com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/V ersions/A/CarbonSound
                    0x5549000 -  0x554ffff  com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
                    0x5557000 -  0x555affb  com.apple.help 1.3.2 (41.1) <8AC20B01-4A3B-94BA-D8AF-E39034B97D8C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
                    0x555f000 -  0x5883fef  com.apple.HIToolbox 1.6.5 (???) <21164164-41CE-61DE-C567-32E89755CB34> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                    0x59c3000 -  0x5a27ffb  com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework /Versions/A/HTMLRendering
                    0x5a49000 -  0x5a5efff  com.apple.ImageCapture 6.1 (6.1) <B909459A-EAC9-A7C8-F2A9-CD757CDB59E8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
                    0x5a74000 -  0x5b22ff3  com.apple.ink.framework 1.3.3 (107) <233A981E-A2F9-56FB-8BDE-C2DEC3F20784> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
                    0x5b4c000 -  0x5b8fff7  com.apple.NavigationServices 3.5.4 (182) <8DC6FD4A-6C74-9C23-A4C3-715B44A8D28C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.fram ework/Versions/A/NavigationServices
                    0x5bb8000 -  0x5bd4fe3  com.apple.openscripting 1.3.1 (???) <2A748037-D1C0-6D47-2C4A-0562AF799AC9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
                    0x5be4000 -  0x5be6ff7  com.apple.securityhi 4.0 (36638) <FC01BFC4-04DB-96F3-2412-A86CC4F94CB2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
                    0x5beb000 -  0x5bf5ffb  com.apple.speech.recognition.framework 3.11.1 (3.11.1) <7486003F-8FDB-BD6C-CB34-DE45315BD82C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
                    0x5bfe000 -  0x5bfeff7  com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
                    0x5c06000 -  0x5c06ff7  com.apple.CoreServices 44 (44) <51CFA89A-33DB-90ED-26A8-67D461718A4A> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
                    0x5c0e000 -  0x5c88fff  com.apple.audio.CoreAudio 3.2.6 (3.2.6) <156A532C-0B60-55B0-EE27-D02B82AA6217> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
                    0x5cba000 -  0x5e35fe7  com.apple.CoreFoundation 6.6.6 (550.44) <F88C95CD-1264-782D-A1F5-204739847E93> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                    0x5f2d000 -  0x5f30fe7  libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
                    0x5f33000 -  0x6253ff3  com.apple.CoreServices.CarbonCore 861.39 (861.39) <5C59805C-AF39-9010-B8B5-D673C9C38538> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
                    0x62c9000 -  0x6375fe7  com.apple.CFNetwork 454.12.4 (454.12.4) <DEDCD006-389F-967F-3405-EDF541F406D7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framewo rk/Versions/A/CFNetwork
                    0x63da000 -  0x641efe7  com.apple.Metadata 10.6.3 (507.15) <74F05E64-2A68-BA10-CCD4-128D164E5A0F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
                    0x6445000 -  0x6510fef  com.apple.CoreServices.OSServices 359.2 (359.2) <7C16D9C8-6F41-5754-17F7-2659D9DD9579> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
                    0x656f000 -  0x65effeb  com.apple.SearchKit 1.3.0 (1.3.0) <9E18AEA5-F4B4-8BE5-EEA9-818FC4F46FD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
                    0x6623000 -  0x6656ff7  com.apple.AE 496.5 (496.5) <BF9673D5-2419-7120-26A3-83D264C75222> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
                    0x666e000 -  0x670bfe3  com.apple.LaunchServices 362.3 (362.3) <15B47388-16C8-97DA-EEBB-1709E136169E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
                    0x674a000 -  0x6770ffb  com.apple.DictionaryServices 1.1.2 (1.1.2) <43E1D565-6E01-3681-F2E5-72AE4C3A097A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
                    0x6786000 -  0x67e3ff7  com.apple.framework.IOKit 2.0 (???) <3DABAB9C-4949-F441-B077-0498F8E47A35> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
                    0x6803000 -  0x6985fe7  libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <D5980817-6D19-9636-51C3-E82BAE26776B> /usr/lib/libicucore.A.dylib
                    0x69e7000 -  0x69f0ff7  com.apple.DiskArbitration 2.3 (2.3) <E9C40767-DA6A-6CCB-8B00-2D5706753000> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
                    0x69fa000 -  0x6a0efe7  libbsm.0.dylib ??? (???) <14CB053A-7C47-96DA-E415-0906BA1B78C9> /usr/lib/libbsm.0.dylib
                    0x6a17000 -  0x6a24ff7  com.apple.NetFS 3.2.2 (3.2.2) <DDC9C397-C35F-8D7A-BB24-3D1B42FA5FAB> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
                    0x6a2d000 -  0x6adafe7  libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <9F8413A6-736D-37D9-8EB3-7986D4699957> /usr/lib/libobjc.A.dylib
                    0x6aee000 -  0x6afaff7  libkxld.dylib ??? (???) <9A441C48-2D18-E716-5F38-CBEAE6A0BB3E> /usr/lib/system/libkxld.dylib
                    0x6afe000 -  0x6b44ff7  libauto.dylib ??? (???) <29422A70-87CF-10E2-CE59-FEE1234CFAAE> /usr/lib/libauto.dylib
                    0x6b51000 -  0x6db7ff7  com.apple.security 6.1.2 (55002) <A476227B-409D-A457-7D4D-A631A0B4AFDB> /System/Library/Frameworks/Security.framework/Versions/A/Security
                    0x6e94000 -  0x6f4dfe7  libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <52438E77-55D1-C231-1936-76F1369518E4> /usr/lib/libsqlite3.dylib
                    0x6f5b000 -  0x6f98ff7  com.apple.SystemConfiguration 1.10.8 (1.10.2) <50E4D49B-4F61-446F-1C21-1B2BA814713D> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
                    0x6fb5000 -  0x6fddff7  libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <315D97C2-4E1F-A95F-A759-4A3FA5639E75> /usr/lib/libxslt.1.dylib
                    0x6fe8000 -  0x70e9fe7  libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <C75F921C-F027-6372-A0A1-EDB8A6234331> /usr/lib/libxml2.2.dylib
                    0x710d000 -  0x737efef  com.apple.Foundation 6.6.8 (751.63) <69B3441C-B196-F2AD-07F8-D8DD24E4CD8C> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                    0x748c000 -  0x7c7b557  com.apple.CoreGraphics 1.545.0 (???) <1D9DC7A5-228B-42CB-7018-66F42C3A9BB3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
                    0x7d43000 -  0x7f05feb  com.apple.ImageIO.framework 3.0.5 (3.0.5) <051752C3-8C25-CF4A-9BFB-C7B6D20E58E8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/ImageIO
                    0x7f64000 -  0x7fc5fe7  com.apple.CoreText 151.12 (???) <98F53C15-1D29-A2B3-0717-5A26A2699163> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.f ramework/Versions/A/CoreText
                    0x7ffd000 -  0x8098fe7  com.apple.ApplicationServices.ATS 275.19 (???) <2E83B3E9-AF39-36FC-5D05-CC1E952098AB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
                    0x80bf000 -  0x817bfff  com.apple.ColorSync 4.6.8 (4.6.8) <920DD017-8B41-7334-E554-A85DB99EBD5A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
                    0x81b2000 -  0x8205ff7  com.apple.HIServices 1.8.3 (???) <1D3C4587-6318-C339-BD0F-1988F246BE2E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
                    0x8230000 -  0x8241ff7  com.apple.LangAnalysis 1.6.6 (1.6.6) <3036AD83-4F1D-1028-54EE-54165E562650> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
                    0x824e000 -  0x82f6ffb  com.apple.QD 3.36 (???) <FA2785A4-BB69-DCB4-3BA3-7C89A82CAB41> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
                    0x8323000 -  0x8337ffb  com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <57DD5458-4F24-DA7D-0927-C3321A65D743> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
                    0x8345000 -  0x8345ff7  com.apple.Accelerate 1.6 (Accelerate 1.6) <3891A689-4F38-FACD-38B2-4BF937DE30CF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
                    0x8348000 -  0x8391fe7  libTIFF.dylib ??? (???) <4A3EF156-D4FE-95E2-FA05-7BD76FF27CEC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libTIFF.dylib
                    0x839c000 -  0x83a0ff7  libGIF.dylib ??? (???) <3B4E6D0B-89EB-251F-3693-5187254D5BE2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libGIF.dylib
                    0x83a5000 -  0x83c0ff7  libPng.dylib ??? (???) <05445692-8AF7-CAB6-EBF5-1F7B3A906CCB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libPng.dylib
                    0x83c8000 -  0x83caff7  libRadiance.dylib ??? (???) <41E5C5F4-A4C6-0416-08D0-422C88088558> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libRadiance.dylib
                    0x83ce000 -  0x83f2ff7  libJPEG.dylib ??? (???) <7EBC924F-B2EE-68B0-4EA0-F99EF54F0306> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJPEG.dylib
                    0x83f9000 -  0x84d9fe7  com.apple.vImage 4.1 (4.1) <D029C515-08E1-93A6-3705-DD062A3A672C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
                    0x84e7000 -  0x84e7ff7  com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <ABF97DA4-3BDF-6FFD-6239-B023CA1F7974> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
                    0x84ea000 -  0x852cff7  libvDSP.dylib 268.0.1 (compatibility 1.0.0) <8A4721DE-25C4-C8AA-EA90-9DA7812E3EBA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
                    0x8535000 -  0x85a4ff7  libvMisc.dylib 268.0.1 (compatibility 1.0.0) <595A5539-9F54-63E6-7AAC-C04E1574B050> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
                    0x85ad000 -  0x89c3ff7  libBLAS.dylib 219.0.0 (compatibility 1.0.0) <C4FB303A-DB4D-F9E8-181C-129585E59603> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
                    0x8a05000 -  0x8e3aff7  libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
                    0x8fc0000 -  0x90c2fe7  libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <015563C4-81E2-8C8A-82AC-31B38D904A42> /usr/lib/libcrypto.0.9.8.dylib
                    0x9116000 -  0x9117ff7  com.apple.TrustEvaluationAgent 1.1 (1) <2D970A9B-77E8-EDC0-BEC6-7580D78B2843> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
                    0x911b000 -  0x91d3feb  libFontParser.dylib ??? (???) <D2D0C922-5ED1-3AE9-6F99-707C74DF3E62> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
                    0x9263000 -  0x929dff7  libcups.2.dylib 2.8.0 (compatibility 2.0.0) <6875335E-0993-0D77-4E80-41763A8477CF> /usr/lib/libcups.2.dylib
                    0x92aa000 -  0x92cafe7  libresolv.9.dylib 41.1.0 (compatibility 1.0.0) <8C2B5FA8-2469-21C7-D297-F95A0FFE5F19> /usr/lib/libresolv.9.dylib
                    0x92d4000 -  0x9318ff3  com.apple.coreui 2 (114) <2234855E-3BED-717F-0BFA-D1A289ECDBDA> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
                    0x9337000 -  0x96a2ff7  com.apple.QuartzCore 1.6.3 (227.37) <E323A5CC-499E-CA9E-9BC3-537231449CAA> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
                    0x9772000 -  0x984cfff  com.apple.DesktopServices 1.5.11 (1.5.11) <800F2040-9211-81A7-B438-7712BF51DEE3> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
                    0x9897000 -  0x99d4fe7  com.apple.audio.toolbox.AudioToolbox 1.6.7 (1.6.7) <423BDE4D-5082-B6CA-BB2C-E22A037235A4> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
                    0x9a44000 -  0x9a94ff7  com.apple.framework.familycontrols 2.0.2 (2020) <C96C8A99-A40C-8B9C-1FBA-A0F46AC92F17> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
                    0x9aac000 -  0x9abeff7  com.apple.MultitouchSupport.framework 207.11 (207.11) <6FF4F2D6-B8CD-AE13-56CB-17437EE5B741> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
                    0x9acb000 -  0x9aeaff7  com.apple.CoreVideo 1.6.2 (45.6) <EB53CAA4-5EE2-C356-A954-5775F7DDD493> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
                    0x9b01000 -  0x9b0fff7  com.apple.opengl 1.6.14 (1.6.14) <82622F67-E032-0BF6-A78D-50B346E8D0FD> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
                    0x9b17000 -  0x9b48ff7  libGLImage.dylib ??? (???) <D18E2E76-DBF4-6930-039A-F66CA0D120B3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
                    0x9b50000 -  0x9b71fe7  com.apple.opencl 12.3.6 (12.3.6) <B4104B80-1CB3-191C-AFD3-697843C6BCFF> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
                    0x9b7a000 -  0x9b7eff7  IOSurface ??? (???) <F9E6DFC1-8DD9-7C7E-CA85-B80735586E05> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
                    0x9b86000 -  0x9bc9ff7  libGLU.dylib ??? (???) <6CC3CE6A-7024-C685-EADA-7F9DC27128E2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
                    0x9bd7000 -  0x9be2ff7  libGL.dylib ??? (???) <3E34468F-E9A7-8EFB-FF66-5204BD5B4E21> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
                    0x9bf1000 -  0x9cfdfe7  libGLProgrammability.dylib ??? (???) <6167CEB0-D8D6-C4D9-DD74-49755ADB540F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
                    0x9d1c000 -  0x9d1fff7  libCoreVMClient.dylib ??? (???) <37F56237-4ABA-E5B5-968D-70FFE357E8E0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
                    0x9d24000 -  0x9d28ff7  libGFXShared.dylib ??? (???) <09540618-2ED1-72C4-61CB-938B35927568> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
                    0x9d2d000 -  0x9d2eff7  com.apple.audio.units.AudioUnit 1.6.7 (1.6.7) <93EC71F1-4D4E-F456-8EFE-32E7EFD7A064> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
                    0x9d33000 -  0x9d33ff7  com.apple.vecLib 3.6 (vecLib 3.6) <FF4DC8B6-0AB0-DEE8-ADA8-7B57645A1F36> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
                    0x9d36000 -  0x9db8ffb  SecurityFoundation ??? (???) <BFE377A4-C830-3ECA-E69F-8A8094CDA0A6> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
                    0x9def000 -  0x9df4ff7  com.apple.OpenDirectory 10.6 (10.6) <0603680A-A002-D294-DE83-0D028C6BE884> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
                    0x9dfc000 -  0x9e02fe7  com.apple.CommerceCore 1.0 (9.1) <521D067B-3BDA-D04E-E1FA-CFA526C87EB5> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCor e.framework/Versions/A/CommerceCore
                    0x9e09000 -  0x9e21ff7  com.apple.CFOpenDirectory 10.6 (10.6) <D1CF5881-0AF7-D164-4156-9E9067B7FA37> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
                    0x9e32000 -  0x9e7ffeb  com.apple.DirectoryService.PasswordServerFramework 6.1 (6.1) <136BFA48-D456-B677-3B5D-40A6946C3A09> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
                    0x9e9b000 -  0x9ebdfef  com.apple.DirectoryService.Framework 3.6 (621.11) <CA979EAC-9537-43B6-CD69-C144ACB75E09> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
                    0x9ec7000 -  0x9ed7ff7  libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <C8744EA3-0AB7-CD03-E639-C4F2B910BE5D> /usr/lib/libsasl2.2.dylib
                    0x9ede000 -  0xa7c1ff7  com.apple.AppKit 6.6.8 (1038.36) <A353465E-CFC9-CB75-949D-786F6F7732F6> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                    0xac5d000 -  0xad8bfe7  com.apple.CoreData 102.1 (251) <87FE6861-F2D6-773D-ED45-345272E56463> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
                    0xadef000 -  0xadefff7  liblangid.dylib ??? (???) <B99607FC-5646-32C8-2C16-AFB5EA9097C2> /usr/lib/liblangid.dylib
                    0xadf3000 -  0xb0edfef  com.apple.QuickTime 7.6.6 (1789) <38255AA2-8087-5AE0-CA4B-1DDE611540B1> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
                    0xb199000 -  0xb393fcf +AdobeOwl ??? (???) <F209A9B2-9606-4182-93D8-84B349CFBE48> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
                    0xb40e000 -  0xb502ff7  libiconv.2.dylib 7.0.0 (compatibility 7.0.0) <061ABF36-8BA9-79C1-6CE7-EC69A4998F51> /usr/lib/libiconv.2.dylib
                    0xb510000 -  0xb550ff7  com.apple.vmutils 4.2 (106) <834EA6B0-C91B-4CF1-ED3C-229C26459578> /System/Library/PrivateFrameworks/vmutils.framework/Versions/A/vmutils
                    0xb569000 -  0xb61efe7  libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <AACC86C0-86B4-B1A7-003F-2A0AF68973A2> /usr/lib/libcrypto.0.9.7.dylib
                    0xb664000 -  0xb66bff7  com.apple.agl 3.0.12 (AGL-3.0.12) <37255DC6-9FD1-45CC-AC80-A84FD2B5450A> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
                    0xc418000 -  0xc419ff7  ATSHI.dylib ??? (???) <56F243F1-C341-86EA-2BCC-31E75D46EBBC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/ATSHI.dylib
                    0xc430000 -  0xc43efe7  libSimplifiedChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <B408E41B-D90F-4A04-DB72-D61C8C52BFBC> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
                    0xc481000 -  0xc484ff7  libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) <4D766435-EB76-C384-0127-1D20ACD74076> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
                    0xc49b000 -  0xc49bfff +com.adobe.illustrator.plugins.PlugInRes Localizer version 14.0.0 (14.0.0) <CFE61490-698E-4FAE-988C-C238AC6CAAF8> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Required/Resources/en_US/PlugInRes.aip/Contents/MacOS/PlugInRes
                    0xc4a3000 -  0xc4b5ff7  libTraditionalChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <EA696A00-4054-6F65-0F86-7901EAB5969F> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
                    0xc5f1000 -  0xc5f3ff7  com.apple.printingprivate.framework.PrintingPrivate 6.1 (15.2) <1A6E0614-420C-1E2B-43DA-722639B1FBCB> /System/Library/PrivateFrameworks/PrintingPrivate.framework/PrintingPrivate
                    0xc60e000 -  0xc61bffb +com.adobe.illustrator.plugins.Navigator Adobe Navigator Plugin version 14.0.0 (14.0.0) <EEF23D08-D8F5-4F7D-96AC-D9E422E78B90> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/Navigator.aip/Contents/MacOS/Navigator
                    0xc6c1000 -  0xc708fc7 +com.adobe.adobe_caps adobe_caps 2.0.99.0 (2.0.99.0) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
                    0xc718000 -  0xc725ff7 +com.adobe.asneu.framework asneu version 1.6.2f01 (1.6.2) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/asneu.framework/Versions/A/asneu
                    0xc733000 -  0xc733ff7  libmx.A.dylib 315.0.0 (compatibility 1.0.0) <01401BF8-3FC7-19CF-ACCE-0F292BFD2F25> /usr/lib/libmx.A.dylib
                    0xc7b1000 -  0xc7b2fff +com.adobe.illustrator.plugins.ASLib ASLib version 14.0.0 (14.0.0) <F08F7B7D-86A2-462E-AB7B-B706FEE4B955> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/ASLib.aip/Contents/MacOS/ASLib
                    0xc7e1000 -  0xc7ecff7  libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <287DECA3-7821-32B6-724D-AE03A9A350F9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
                    0x1159e000 - 0x115c0fc7 +com.adobe.illustrator.plugins.TracingUI TracingUI version 14.0.0 (14.0.0) <406A33F8-F301-4540-9A22-A01E2CA0CBE1> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/TracingUI.aip/Contents/MacOS/TracingUI
                    0x115c8000 - 0x115d3ff7 +com.adobe.illustrator.plugins.Find Find version 14.0.0 (14.0.0) <DE59DC7B-5D9B-4483-83B9-67D8682B4CD1> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Illustrator Filters.localized/Find.aip/Contents/MacOS/Find
                    0x115ee000 - 0x115f5fff +com.adobe.illustrator.plugins.Action Action version 14.0.0 (14.0.0) <C884784D-9646-47C7-917D-2F6B65521B57> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/Action.aip/Contents/MacOS/Action
                    0x115f9000 - 0x115fcfff +com.adobe.illustrator.plugins.GeometryS  Geometry Suite version 14.0.0 (14.0.0) <B30D9BE4-9735-4704-AD8A-467E7C25B9A9> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/Geometry.aip/Contents/MacOS/GeometryS
                    0x117c0000 - 0x117f3fff  libTrueTypeScaler.dylib ??? (???) <8ADB7D19-413E-4499-C874-13C383F97685> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resourc es/libTrueTypeScaler.dylib
                    0x12200000 - 0x122d1fe3  ColorSyncDeprecated.dylib 4.6.0 (compatibility 1.0.0) <C618942F-BC01-0565-18CF-477B63C02181> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/Resources/ColorSyncDeprecated.dylib
                    0x1286f000 - 0x12878fff +com.adobe.illustrator.plugins.FrameworkServer Framework Server version 14.0.0 (14.0.0) <04B2DA5B-B84C-487C-A70E-76163D14D08F> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Required/Plug-ins/FrameworkServer.aip/Contents/MacOS/FrameworkServer
                    0x1287c000 - 0x12882ff7 +com.adobe.illustrator.plugins.ArtConverters  ArtConverters version 14.0.0 (14.0.0) <0EA7F2D8-904D-4AFC-A177-8569F3E2286A> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Required/Plug-ins/ArtConverters.aip/Contents/MacOS/ArtConverters
                    0x12886000 - 0x128affff +com.adobe.illustrator.plugins.BRSPencilTool  Pencil Tool version 14.0.0 (14.0.0) <EF43DD3A-A797-450D-9FF7-4EFD246811A5> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Required/Plug-ins/BRSPencilTool.aip/Contents/MacOS/BRSPencilTool
                    0x128b5000 - 0x128b6ff7  com.apple.textencoding.unicode 2.3 (2.3) <78A61FD5-70EE-19EA-48D4-3481C640B70D> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
                    0x128bb000 - 0x128fcfd0 +com.adobe.illustrator.plugins.SVGFilterEffect SVG Filter Effect version 14.0.0 (14.0.0) <1EE0CFC5-C24B-45D2-8354-84A81D3894F4> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/SVGFilterEffect.aip/Contents/MacOS/SVGFilterE ffect
                    0x12913000 - 0x12973fd2 +com.adobe.illustrator.plugins.CharParaStyles CharParaStyles version 14.0.0 (14.0.0) <077E031D-6226-44B2-AF1E-A5DA6320CF91> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/CharParaStyles.aip/Contents/MacOS/CharParaSty les
                    0x12ab6000 - 0x12af2fef +com.adobe.illustrator.plugins.Print Print version 14.0.0 (14.0.0) <0D612170-363B-4D37-9BC2-8A8638A9BC19> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/Print.aip/Contents/MacOS/Print
                    0x12b8b000 - 0x12b9bff7  com.apple.DSObjCWrappers.Framework 10.6 (134) <81A0B409-3906-A98F-CA9B-A49E75007495> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
                    0x12ba6000 - 0x12bacff7  libCGXCoreImage.A.dylib 545.0.0 (compatibility 64.0.0) <6EE825E7-CBA5-2AD2-0336-244D45A1A834> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
                    0x12d5c000 - 0x12d75033 +com.adobe.illustrator.plugins.FindReplaceUI  FindReplaceUI version 14.0.0 (14.0.0) <223D8BC9-8098-45A4-BD15-17AB5C6C2E0D> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Text Filters.localized/FindReplaceUI.aip/Contents/MacOS/FindReplaceUI
                    0x12d7c000 - 0x12d90fc7 +com.adobe.illustrator.plugins.Flare Flare version 14.0.0 (14.0.0) <0C996E6A-8A83-441C-ABB4-EE621B25CA3F> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Tools.localized/Flare.aip/Contents/MacOS/Flare
                    0x12d96000 - 0x12da5fd3 +com.adobe.illustrator.plugins.Flatten Transparency  Flatten Transparency version 14.0.0 (14.0.0) <66929E97-D63A-46F2-9ADC-F8C10995DFC3> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Required/Plug-ins/Flatten Transparency.aip/Contents/MacOS/Flatten Transparency
                    0x12dac000 - 0x12dc1fef +com.adobe.illustrator.plugins.Rasterize Rasterize version 14.0.0 (14.0.0) <20A55512-33F0-4669-BE49-F3ED9E2C1CC5> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Required/Plug-ins/Rasterize.aip/Contents/MacOS/Rasterize
                    0x12dc5000 - 0x12dc6fff +com.adobe.illustrator.plugins.MPSCommon MPSCommon version 14.0.0 (14.0.0) <4CBB7829-A13E-41B3-9273-2223506DE716> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Illustrator Formats.localized/MPSCommon.aip/Contents/MacOS/MPSCommon
                    0x12e5a000 - 0x12e83fe3  com.apple.audio.CoreAudioKit 1.6.1 (1.6.1) <7FFBD485-5251-776A-CC44-4470DD84112B> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
                    0x12e94000 - 0x12eadfcb +com.adobe.illustrator.plugins.AssetMgmt Asset Management version 14.0.0 (14.0.0) <27CE4290-30DD-477C-9DD4-D46D6022D8D5> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/AssetMgmt.aip/Contents/MacOS/AssetMgmt
                    0x12f26000 - 0x12f29fef +com.adobe.illustrator.plugins.KnifeTool Knife Tool version 14.0.0 (14.0.0) <79C5F1A2-6CF0-4A1D-9B50-7BE467DD80A6> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Tools.localized/KnifeTool.aip/Contents/MacOS/KnifeTool
                    0x12f2d000 - 0x12f6eff7  libRIP.A.dylib 545.0.0 (compatibility 64.0.0) <80998F66-0AD7-AD12-B9AF-3E8D2CE6DE05> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
                    0x12f7d000 - 0x12fb8ffb  libFontRegistry.dylib ??? (???) <19ED5DE0-D3AF-B229-9193-35D58FE377E5> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resourc es/libFontRegistry.dylib
                    0x12fd3000 - 0x12ffbfcb +com.adobe.illustrator.plugins.FOConversionSuite FOConversionSuite version 14.0.0 (14.0.0) <D2E6328E-B072-4F58-A8F4-191C1E7A3111> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Required/Plug-ins/FOConversionSuite.aip/Contents/MacOS/FOConversionSuite
                    0x1300b000 - 0x1300ffeb +com.adobe.illustrator.plugins.ToolSelector Tool Selector version 14.0.0 (14.0.0) <72429655-649D-4EFF-A0AF-DE2BE54FFDC6> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/ToolSelector.aip/Contents/MacOS/ToolSelector
                    0x13013000 - 0x13059fe0 +com.adobe.illustrator.plugins.JPEG JPEGFormat version 14.0.0 (14.0.0) <2278DB92-A7A8-4D59-9754-237467F6179C> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Illustrator Formats.localized/JPEG.aip/Contents/MacOS/JPEG
                    0x13097000 - 0x130deff7 +MultiProcessor Support ??? (???) <F3BFBFC8-1EE7-419A-AAD4-EABD31CCECD1> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/MacOS/multiprocessor support.plugin/Contents/MacOS/MultiProcessor Support
                    0x132b2000 - 0x132bdff7  com.apple.CrashReporterSupport 10.6.7 (258) <8F3E7415-1FFF-0C20-2EAB-6A23B9728728> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporter Support
                    0x132d6000 - 0x132ebff0 +com.adobe.illustrator.plugins.ControlPalette ControlPalette version 14.0.0 (14.0.0) <65ADF72A-2398-43F7-9B05-52D7D592BA0E> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/Control Panel.aip/Contents/MacOS/ControlPalette
                    0x132f1000 - 0x132f6fef +com.adobe.illustrator.plugins.ShapeS Shape Construction Suite version 14.0.0 (14.0.0) <A8E06D3D-22EB-4391-A488-39435E80F204> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Required/Plug-ins/ShapeS.aip/Contents/MacOS/ShapeS
                    0x132fa000 - 0x132fbfff +com.adobe.illustrator.plugins.FlattenS Flatten Suite version 14.0.0 (14.0.0) <34B0A010-1099-474C-9B2B-4D923FB10287> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/FlattenS.aip/Contents/MacOS/FlattenS
                    0x14100000 - 0x14551fef  com.apple.RawCamera.bundle 3.7.1 (570) <AF94D180-5E0F-10DF-0CB2-FD8EDB110FA2> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
                    0x1479f000 - 0x147eefe6 +com.adobe.illustrator.plugins.Photoshop Adapter Photoshop Adapter version 14.0.0 (14.0.0) <897C80A3-5E5D-4156-8C80-38FE67F5F275> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Photoshop Filters.localized/Photoshop Adapter.aip/Contents/MacOS/Photoshop Adapter
                    0x14900000 - 0x149d3fef +com.adobe.coretech.adm 3.10x04 (3.1) <369EAA04-C054-40EB-AC03-92CE99C7260C> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Required/Plug-ins/AdobeADM.bundle/Contents/MacOS/AdobeADM
                    0x14af1000 - 0x14b25fc3 +com.adobe.illustrator.plugins.BrushManager Brush Manager version 14.0.0 (14.0.0) <45B1E4C5-0AEC-4C31-BF6E-ECC0888F9386> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/BrushManager.aip/Contents/MacOS/BrushManager
                    0x14b2e000 - 0x14bdcfc8 +com.adobe.illustrator.plugins.ColorHarmony ColorHarmony version 14.0.0 (14.0.0) <11C2EC2C-29D3-462D-B3A2-771D85D66917> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/ColorHarmony.aip/Contents/MacOS/ColorHarmony
                    0x14bfa000 - 0x14c25ff0 +com.adobe.illustrator.plugins.KinsokuDlg  KinsokuDlg version 14.0.0 (14.0.0) <0B0B227F-AA5B-46FB-A6B6-60AE2BFAD347> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/KinsokuDlg.aip/Contents/MacOS/KinsokuDlg
                    0x14c36000 - 0x14caefdb +com.adobe.illustrator.plugins.PaintStyle Paint Style Palettes version 14.0.0 (14.0.0) <FDFCF271-25E0-46B9-812C-EFB4E49B61A8> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/Paint Style Panel.aip/Contents/MacOS/PaintStyle
                    0x14cba000 - 0x14f68fe7 +com.adobe.illustrator.plugins.Scripting Support Scripting Support version 14.0.0 (14.0.0) <00ED474E-DA84-421D-A0BA-AC17357B1FED> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/ScriptingSupport.aip/Contents/MacOS/Scripting Support
                    0x1522c000 - 0x15405fff  libType1Scaler.dylib ??? (???) <04AF2B34-81D4-97E9-BD56-387D37C16F46> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resourc es/libType1Scaler.dylib
                    0x15537000 - 0x155b2fde +com.adobe.illustrator.plugins.SwatchLibraries Swatch Libraries version 14.0.0 (14.0.0) <CB45F4C6-5333-417D-8997-C124973041FE> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/SwatchLibraries.aip/Contents/MacOS/SwatchLibr aries
                    0x155c3000 - 0x155f1068 +com.adobe.illustrator.plugins.SymbolPalette Symbol Palette version 14.0.0 (14.0.0) <DD7DBC72-EF5E-4F52-A102-794BF21F2498> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/Symbol Panel.aip/Contents/MacOS/SymbolPalette
                    0x155fa000 - 0x15613fef +com.adobe.illustrator.plugins.Workspaces Workspaces version 14.0.0 (14.0.0) <E065EBE1-AEF1-47B8-9933-EEB543767C5C> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/Workspaces.aip/Contents/MacOS/Workspaces
                    0x1561a000 - 0x1562d04f +com.adobe.illustrator.plugins.Mojikumi  MojiKumiUI version 14.0.0 (14.0.0) <E32A6710-064A-4731-8844-E63F5DC4094F> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Illustrator Formats.localized/Mojikumi.aip/Contents/MacOS/Mojikumi
                    0x15634000 - 0x1565bfe8 +com.adobe.illustrator.plugins.slicingAttributes Slicing version 14.0.0 (14.0.0) <3A3FCCB7-D888-4949-94FB-74EA1892F2DE> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Required/Plug-ins/sliceAttributes.aip/Contents/MacOS/slicingAttributes
                    0x15663000 - 0x1568ffff +com.adobe.illustrator.plugins.PathfinderS Pathfinder Suite version 14.0.0 (14.0.0) <D0D9CCD1-0AEC-4C46-9AA3-F7F97ACCDEF1> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Required/Plug-ins/PathFinderS.aip/Contents/MacOS/PathfinderS
                    0x15698000 - 0x1569fff3 +com.adobe.illustrator.plugins.ExpandS Expand Suite version 14.0.0 (14.0.0) <29196393-E41C-43EA-8C0C-6260FD7F61FC> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Required/Plug-ins/ExpandS.aip/Contents/MacOS/ExpandS
                    0x156a3000 - 0x156b3fff +com.adobe.illustrator.plugins.DocInfo Document Info version 14.0.0 (14.0.0) <4314802B-CE2E-4AF5-9460-5809DEFF7360> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/DocInfo.aip/Contents/MacOS/DocInfo
                    0x156ba000 - 0x156f2fef +com.adobe.illustrator.plugins.Snap Snap version 14.0.0 (14.0.0) <29FC35B5-A5D5-4F0C-B721-49E267315B13> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/Snap.aip/Contents/MacOS/Snap
                    0x15702000 - 0x15712ff2 +com.adobe.illustrator.plugins.DropShadow Drop Shadow version 14.0.0 (14.0.0) <50DC2482-540D-4817-8D0E-158E626298DA> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Illustrator Filters.localized/DropShadow.aip/Contents/MacOS/DropShadow
                    0x15718000 - 0x1571ffc0 +com.adobe.illustrator.plugins.ADMTP Tool Palette version 14.0.0 (14.0.0) <7E1766B5-2D51-4E83-B515-6F5149B134B2> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Tools.localized/Tool Panel.aip/Contents/MacOS/ADMTP
                    0x15723000 - 0x15732ff3 +com.adobe.illustrator.plugins.Segment Tools Segment Tools version 14.0.0 (14.0.0) <5ADD1377-AC2A-43E7-A418-FA83F4E7DF2F> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Tools.localized/Segment Tools.aip/Contents/MacOS/Segment Tools
                    0x15737000 - 0x15754fda +com.adobe.illustrator.plugins.ScatterBrushTool Adobe Scatter Brush Tool version 14.0.0 (14.0.0) <8BEBD742-F42F-49C5-A3F0-FA1C5285A7DA> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Tools.localized/ScatterBrushTool.aip/Contents/MacOS/ScatterBrushTo ol
                    0x1575b000 - 0x1575ffef +com.adobe.illustrator.plugins.GlobalAdjust Reshape Tool version 14.0.0 (14.0.0) <D6B5A699-E443-4D3A-87AA-FC7D8E2CB319> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Tools.localized/Reshape Tool.aip/Contents/MacOS/GlobalAdjust
                    0x15763000 - 0x15782fcb +com.adobe.illustrator.plugins.ParticlePaint Symbolism version 14.0.0 (14.0.0) <4A4D97AA-0B5C-4311-83FE-288839029DA7> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Tools.localized/ParticleSystem.aip/Contents/MacOS/ParticlePaint
                    0x1578b000 - 0x15794fe7 +com.adobe.illustrator.plugins.Magic Wand Magic Wand version 14.0.0 (14.0.0) <93E02FBC-89CC-4486-B643-7F7B01E3C149> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Tools.localized/Magic Wand.aip/Contents/MacOS/Magic Wand
                    0x15798000 - 0x157afff3 +com.adobe.illustrator.plugins.Liquify Liquify version 14.0.0 (14.0.0) <C16C9B41-5869-4A14-A5B7-8AC978B5FDFD> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Tools.localized/Liquify.aip/Contents/MacOS/Liquify
                    0x157b3000 - 0x157bafeb +com.adobe.illustrator.plugins.Lasso Lasso version 14.0.0 (14.0.0) <7C893464-927E-4EFC-B6FB-2F3E10F9A199> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Tools.localized/Lasso.aip/Contents/MacOS/Lasso
                    0x157bf000 - 0x157f3fdf +com.adobe.illustrator.plugins.EraserTool EraserTool version 14.0.0 (14.0.0) <1744EECA-69F1-4C93-AA06-B89075F3EEBE> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Tools.localized/EraserTool.aip/Contents/MacOS/EraserTool
                    0x157fb000 - 0x15823fec +com.adobe.illustrator.plugins.CalligBrushTool Calligraphic Brush Tool version 14.0.0 (14.0.0) <FA25241B-421C-49D6-BE9D-8BC1430E9828> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Tools.localized/CalligBrushTool.aip/Contents/MacOS/CalligBrushTool
                    0x1582a000 - 0x1583dff7 +com.adobe.illustrator.plugins.BoundingBox BoundingBox version 14.0.0 (14.0.0) <D05C0C30-D456-4E98-9BC4-92C2294FB49F> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Tools.localized/BoundingBox.aip/Contents/MacOS/BoundingBox
                    0x15841000 - 0x1586cfd6 +com.adobe.illustrator.plugins.ArtBrushTool Art Brush Tool version 14.0.0 (14.0.0) <89FE2B11-D5DD-4DEA-966C-E1A85FB4CBAC> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Tools.localized/ArtBrushTool.aip/Contents/MacOS/ArtBrushTool
                    0x15873000 - 0x1587effe +com.adobe.illustrator.plugins.ai-cut ai-cut version 13 . 0 . 0 . 0 (13 . 0 . 0 . 0) <F00FBE64-CF94-901F-6977-7B648B643B4F> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Tools.localized/ai-cut.aip/Contents/MacOS/ai-cut
                    0x15888000 - 0x158e7fcf +com.adobe.illustrator.plugins.PhotoshopImport Photoshop Import version 14.0.0 (14.0.0) <861DD58E-6EA7-4715-B877-5C75B596C85A> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Photoshop Formats.localized/PhotoshopImport.aip/Contents/MacOS/PhotoshopImport
                    0x158fe000 - 0x16630fff +com.adobe.psl AdobePSL 11.0.0.1724 (11.0.0.1724) <6BE27A60-E0F9-4483-8E57-2A7A5227D878> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
                    0x16964000 - 0x16990fff +com.adobe.illustrator.plugins.ExpressView Support OS Express Views version 14.0.0 (14.0.0) <4D362918-5276-46B4-9825-5CAE899E9EE5> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Photoshop Filters.localized/ExpressView Support.aip/Contents/MacOS/ExpressView Support
                    0x1699b000 - 0x169e4ff4 +com.adobe.illustrator.plugins.MPSParser MPSParser version 14.0.0 (14.0.0) <67607461-914F-440E-8624-381CC2A0079E> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Illustrator Formats.localized/MPSParser.aip/Contents/MacOS/MPSParser
                    0x16b00000 - 0x16b30fcc +com.adobe.illustrator.plugins.MPSExport MPSExport version 14.0.0 (14.0.0) <DD69AB2F-78AB-4225-9DCE-2141648F6E1E> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Illustrator Formats.localized/MPSExport.aip/Contents/MacOS/MPSExport
                    0x16b40000 - 0x16b5eff4 +com.adobe.illustrator.plugins.Scribble Scribble version 14.0.0 (14.0.0) <66F69AF3-2A26-4B2A-88E8-64568F71EA80> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Illustrator Filters.localized/Scribble.aip/Contents/MacOS/Scribble
                    0x16b65000 - 0x16b71ff3 +com.adobe.illustrator.plugins.Pathfinder Pathfinder Plugin version 14.0.0 (14.0.0) <7288F843-177B-43CE-9876-AB66A84A2F69> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Illustrator Filters.localized/Pathfinder.aip/Contents/MacOS/Pathfinder
                    0x16b75000 - 0x16b8afc4 +com.adobe.illustrator.plugins.WelcomeScreen WelcomeScreenn version 14.0.0 (14.0.0) <780173AB-6EAA-4EF6-9D79-99CE78F0BF06> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/WelcomeScreen.aip/Contents/MacOS/WelcomeScree n
                    0x16b90000 - 0x16ba3fd7 +com.adobe.illustrator.plugins.TransparencyPalette Transparency Palette version 14.0.0 (14.0.0) <2FC5A6F7-E157-4BE3-9490-657B1198825D> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/Transparency Panel.aip/Contents/MacOS/TransparencyPalette
                    0x16ba7000 - 0x16bb8ff6 +com.adobe.illustrator.plugins.SeparationPreview Separation Preview version 14.0.0 (14.0.0) <F0B42349-86B6-489E-A1ED-62DAB50BB12F> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/SeparationPreview.aip/Contents/MacOS/Separati onPreview
                    0x16bbf000 - 0x16bc4fff +com.adobe.illustrator.plugins.PathSuite PathConstruction Suite version 14.0.0 (14.0.0) <667209A1-821D-468E-B3F5-67ADCC0A5B59> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/PathSuite.aip/Contents/MacOS/PathSuite
                    0x16bc8000 - 0x16beefdf +com.adobe.illustrator.plugins.LiveBlends Live Blends version 14.0.0 (14.0.0) <5949CA4F-0265-4001-827A-FDF67CE6E1C4> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/LiveBlends.aip/Contents/MacOS/LiveBlends
                    0x16bf3000 - 0x16c21fcf +com.adobe.illustrator.plugins.Layers Layers Palette version 14.0.0 (14.0.0) <F13985B8-7110-4AC4-A93B-30A650274B81> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/Layers Panel.aip/Contents/MacOS/Layers
                    0x16c29000 - 0x16c3ffef +com.adobe.illustrator.plugins.KBSCPlugin Keyboard Shortcuts version 14.0.0 (14.0.0) <8BA6912E-AC74-4FCE-97FF-02BF2F81958D> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/Keyboard Shortcuts.aip/Contents/MacOS/KBSCPlugin
                    0x16c46000 - 0x16c4cfeb +com.adobe.illustrator.plugins.FileClipboardPref FileClipboardPref version 14.0.0 (14.0.0) <A968F7DC-F8B2-46A3-8C78-1D129B37588E> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/FileClipboardPref.aip/Contents/MacOS/FileClip boardPref
                    0x16c50000 - 0x16cacfd2 +com.adobe.illustrator.plugins.ArtStyle Art Style version 14.0.0 (14.0.0) <DAA8C2E9-65A7-40ED-B8D5-FF78F297EDA6> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/ArtStyle.aip/Contents/MacOS/ArtStyle
                    0x16cb8000 - 0x16cc7ff3 +com.adobe.illustrator.plugins.AppBarControlsPlugin NewPlugin version 14.0.0 (14.0.0) <C50066DB-5E97-4C95-AECB-BD0A1BBD2769> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/AppBarControlsPlugin.aip/Contents/MacOS/AppBa rControlsPlugin
                    0x16ccd000 - 0x16cfdffb +com.adobe.illustrator.plugins.AltGlyphPal AdobeAltGlyphPalette version 14.0.0 (14.0.0) <FC1467B2-2A62-408E-A38D-A1F8EC209A52> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/AltGlyphPal.aip/Contents/MacOS/AltGlyphPal
                    0x16d0e000 - 0x16d1fff6 +com.adobe.illustrator.plugins.Align AdobeAlignObjects version 14.0.0 (14.0.0) <1E8046C8-EAE8-445B-83F3-B2AF0F4D3452> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/Align.aip/Contents/MacOS/Align
                    0x16d24000 - 0x16d5bfff +com.adobe.illustrator.plugins.ActionPalette  Action Palette version 14.0.0 (14.0.0) <49FF537C-26F4-450A-B7DE-59859F5A6DC0> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/Action Panel.aip/Contents/MacOS/ActionPalette
                    0x16d65000 - 0x16dfafc1 +com.adobe.illustrator.plugins.PDF Format PDF Format version 14.0.0 (14.0.0) <C88425A7-C3DA-493B-AC3E-48AB988A3CD4> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Required/Plug-ins/PDF Format.aip/Contents/MacOS/PDF Format
                    0x16e18000 - 0x16e67ff3 +FilterPort ??? (???) <7CF9F9BD-8C11-4F4C-A56F-D02923DA26C4> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/FilterPort.framework/Versions/A/FilterPort
                    0x16f06000 - 0x16f49fef +ADMEveParserCarbon ??? (???) <E2B97059-2ECE-46E3-B0FA-E99EA7035CEC> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Required/Plug-ins/ADMEveParserCarbon.bundle/Contents/MacOS/ADMEveParserCa rbon
                    0x16f63000 - 0x16f6bfeb +com.adobe.illustrator.plugins.TextWrapDlg TextWrapDlg version 14.0.0 (14.0.0) <98A0EA55-C4D8-4204-9573-61592D2660A1> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Illustrator Filters.localized/TextWrapDlg.aip/Contents/MacOS/TextWrapDlg
                    0x16f6f000 - 0x16f7cfff +com.adobe.illustrator.plugins.Advanced Select Advanced Select version 14.0.0 (14.0.0) <C0673233-D6ED-4333-B8DC-1EDB6B9436B0> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Tools.localized/Advanced Select.aip/Contents/MacOS/Advanced Select
                    0x16f91000 - 0x16f95fff +com.adobe.illustrator.plugins.TypeCase Change Case version 14.0.0 (14.0.0) <7DF88FF2-4C03-499F-A390-0C4D9C17B27D> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Text Filters.localized/TypeCase.aip/Contents/MacOS/TypeCase
                    0x16fa9000 - 0x16fb3ff7  com.apple.HelpData 2.0.5 (34.1.1) <A9CF754F-B254-5D40-B8B5-F35414DFD875> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
                    0x16fef000 - 0x16ffafdb +com.adobe.illustrator.plugins.TransformPalette Transform Palette version 14.0.0 (14.0.0) <18E00D0B-F2EB-4046-B764-7953DFBFD55E> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/Transform Panel.aip/Contents/MacOS/TransformPalette
                    0x17200000 - 0x17231fef +com.adobe.illustrator.plugins.VariablesPalette Variables Palette version 14.0.0 (14.0.0) <4E4DB42A-52B9-4A3E-AE56-4044DDF2B0C5> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/Variables Panel.aip/Contents/MacOS/VariablesPalette
                    0x17463000 - 0x174befe7 +com.adobe.illustrator.plugins.PDF Suite PDF Suite version 14.0.0 (14.0.0) <586E2428-342D-4C78-89F0-56A0FD10246A> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Required/Plug-ins/PDF Suite.aip/Contents/MacOS/PDF Suite
                    0x176ce000 - 0x176f5fd7 +com.adobe.illustrator.plugins.LinkPalette Links Palette version 14.0.0 (14.0.0) <0CAE26A1-C07B-422B-831E-679A59CB9EC0> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/Links Panel.aip/Contents/MacOS/LinkPalette
                    0x17a40000 - 0x17a71fe3 +com.adobe.amt.registration AMTRegistration 2.0.1.10077 (BuildVersion: 53.352460; BuildDate: Tue Jul 29 2008 16:31:09) (2 . 0) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/registration.framework/Versions/A/registration
                    0x17aaa000 - 0x17b06ff2 +AdobeUpdater ??? (???) <064CFAA4-1CAF-46E3-BEBF-04948641C927> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobeUpdater.framework/Versions/A/AdobeUpdater
                    0x17b45000 - 0x17b78fc4 +com.adobe.illustrator.plugins.CropAreaTool CropAreaTool version 14.0.0 (14.0.0) <ACC7FD5D-26E1-463B-9688-2EE97ECCE728> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Tools.localized/Crop Area Tool.aip/Contents/MacOS/CropAreaTool
                    0x18268000 - 0x1890afef +com.macromedia.Flash Player.authplaylib 10.0.2.31 (1.0.1d333) <E0851D48-16C9-4BDC-B3A7-7BAC9E7638F5> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobeOwl.framework/Resources/AuthPlayLib.bundle/Conte nts/MacOS/AuthPlayLib
                    0x1a500000 - 0x1a600fcf +com.adobe.versioncue ??? (4.0.0.344) /Library/Application Support/Adobe/Adobe Version Cue CS4/Client/4.0.0/VersionCue.framework/VersionCue
                    0x1a745000 - 0x1a770fc7 +com.adobe.illustrator.plugins.FlatteningPreview Flattening Preview version 14.0.0 (14.0.0) <743A204F-DFC7-4D1B-8370-08E7BD4556E2> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/FlatteningPreview.aip/Contents/MacOS/Flatteni ngPreview
                    0x1a780000 - 0x1a7d3fcc +com.adobe.illustrator.plugins.Deform Envelope and Warp version 14.0.0 (14.0.0) <907BD2FF-7D35-4774-8D10-2C5D8AD8BE56> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/Envelope and Warp.aip/Contents/MacOS/Deform
                    0x1b000000 - 0x1b482fe3 +AdobeLM_libFNP.dylib ??? (???) <02E9AC76-9CC6-4974-AF05-48E737C2CC20> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/amtlib.framework/Versions/A/AdobeLM_libFNP.dylib
                    0x1ca5e000 - 0x1cb3afe6 +com.adobe.illustrator.plugins.PlanetX Live Paint version 14.0.0 (14.0.0) <2A336A35-9CF2-41DF-852A-97C0CC9BB42F> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/Live Paint.aip/Contents/MacOS/PlanetX
                    0x1d3b0000 - 0x1d485fd8 +com.adobe.illustrator.plugins.SWFExport FlashFileFormat version 14.0.0 (14.0.0) <84ABF2FA-488F-4BED-9FD6-C0BD16364A80> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Illustrator Formats.localized/SWFExport.aip/Contents/MacOS/SWFExport
                    0x1d4a7000 - 0x1d587ff7 +com.adobe.illustrator.plugins.SVG Format  SVG Format version 14.0.0 (14.0.0) <3E3CB7B9-3AEA-459D-86F2-3022F43437A4> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Illustrator Formats.localized/SVG File Format.aip/Contents/MacOS/SVG Format
                    0x1d7eb000 - 0x1d874ff4 +com.adobe.illustrator.plugins.TracingSuite TracingSuite version 14.0.0 (14.0.0) <A48CF41E-B678-40D8-9FC2-69289C07B309> /Applications/Adobe Illustrator CS4/Plug-ins.localized/Extensions.localized/TracingSuite.aip/Contents/MacOS/TracingSuite
                    0x20000000 - 0x20098fe7  edu.mit.Kerberos 6.5.11 (6.5.11) <F36DB665-A88B-7F5B-6244-6A2E7FFFF668> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
                    0x40000000 - 0x400ae030 +AdobeJP2K ??? (???) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
                    0x5a100000 - 0x5a142ff7  com.apple.print.framework.Print.Private 6.4 (305.4) <97FD461E-ACFC-6F2B-9E48-5A22D1537422> /System/Library/PrivateFrameworks/PrintingPrivate.framework/Versions/Current/Plugins/Prin tCocoaUI.bundle/Contents/MacOS/PrintCocoaUI
                    0x5a156000 - 0x5a188fe7  com.apple.print.PrintingCocoaPDEs 6.4 (305.4) <CFF55F65-133F-A1DD-67A1-7D08C53FDFBF> /System/Library/PrivateFrameworks/PrintingPrivate.framework/Versions/A/Plugins/PrintingCo coaPDEs.bundle/Contents/MacOS/PrintingCocoaPDEs
                    0x5a197000 - 0x5a39efeb  com.apple.AddressBook.framework 5.0.4 (883) <E26855A0-8CEF-8C81-F963-A2BF9E47F5C8> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
                    0x5a471000 - 0x5a4a9ff7  com.apple.LDAPFramework 2.0 (120.1) <131ED804-DD88-D84F-13F8-D48E0012B96F> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
                    0x5a4b4000 - 0x5a52bff3  com.apple.backup.framework 1.2.2 (1.2.2) <D65F2FCA-15EB-C200-A08F-7DC4089DA6A2> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
                    0x5a544000 - 0x5a584ff3  com.apple.securityinterface 4.0.1 (40418) <FED0C1B5-469E-ADFF-308E-C10B6A68AE45> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
                    0x5a5a5000 - 0x5a5dffe7  libssl.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <C62A7753-99A2-6782-92E7-6628A6190A90> /usr/lib/libssl.0.9.8.dylib
                    0x5a87e000 - 0x5a8a8ff7  com.apple.shortcut 1.1 (1.1) <B0514FA9-7CAE-AD94-93CA-7B2A2C5F7B8A> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
                    0x5a8c1000 - 0x5a8f7fff  libtidy.A.dylib ??? (???) <0FD72C68-4803-4C5B-3A63-05D7394BFD71> /usr/lib/libtidy.A.dylib
                    0x64b00000 - 0x64b07ff3  com.apple.print.framework.Print 6.1 (237.1) <F5AAE53D-5530-9004-A9E3-2C1690C5328E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
                    0x8fe00000 - 0x8fe4162b  dyld 132.1 (???) <1C06ECD9-A2D7-BB10-AF50-0F2B598A7DEC> /usr/lib/dyld
                    0xb0000000 - 0xb0006ff8  com.apple.carbonframeworktemplate 1.3 (1.3.11) /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
                    0xb0b35000 - 0xb0b9afe3 +MMXCore ??? (???) <F9B1B4ED-E3A5-4629-B79D-6077319ED4DB> /Applications/Adobe Illustrator CS4/Adobe Illustrator.app/Contents/MacOS/mmxcore.plugin/Contents/MacOS/MMXCore
                    0xba900000 - 0xba916ff7  libJapaneseConverter.dylib 49.0.0 (compatibility 1.0.0) <A6FD4184-1017-59F6-990E-785BDF6202BE> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
                    0xbab00000 - 0xbab21fe7  libKoreanConverter.dylib 49.0.0 (compatibility 1.0.0) <59936EB5-5FA4-EEEB-9858-E9BF50AB1776> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
                    0xfa100000 - 0xfa192fe7  com.apple.print.framework.PrintCore 6.3 (312.7) <7410D1B2-655D-68DA-D4B9-2C65747B6817> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
                    0xffff0000 - 0xffff1fff  libSystem.B.dylib ??? (???) <2DCD13E3-1BD1-6F25-119A-3863A3848B90> /usr/lib/libSystem.B.dylib
                    Model: MacPro1,1, BootROM MP11.005C.B08, 4 processors, Dual-Core Intel Xeon, 2.66 GHz, 12 GB, SMC 1.7f10
                    Graphics: ATI Radeon X1900 XT, ATY,RadeonX1900, PCIe, 512 MB
                    Memory Module: global_name
                    Network Service: Ethernet 1, Ethernet, en0
                    PCI Card: ATY,RadeonX1900, sppci_displaycontroller, Slot-1
                    Serial ATA Device: ST3500630AS P, 465.76 GB
                    Parallel ATA Device: ATAPI   iHAP322   8
                    USB Device: U3 Cruzer Micro, 0x0781  (SanDisk Corporation), 0x5406, 0xfd200000 / 2
                    USB Device: Apple Optical USB Mouse, 0x05ac  (Apple Inc.), 0x0306, 0x1d100000 / 2
                    USB Device: Generic USB K/B Hub, 0x05c7  (Qtronix Corp), 0x7002, 0x3d100000 / 2
                    USB Device: Generic USB K/B Hub, 0x05c7  (Qtronix Corp), 0x7001, 0x3d130000 / 3
                    FireWire Device: built-in_hub, Up to 800 Mb/sec
                    FireWire Device: d2 quadra (button), LaCie, Up to 800 Mb/sec
                    • 9. Re: Problems printing a postscript in Illustrator CS4
                      John Danek Champion
                      The Wasatch RIP processes .eps, .tiff; .ai; pdf; etc. files.  I see no need to send it a Postscript code file.  Why not Distill your original file into PDF and send that to the RIP?  Or just do what most people on this forum do, save-as-pdf?  I worked with Wasatch 5 to RIP files to a non-Postscript printer.  I sent it .eps and .pdf files without a hitch.  Please explain why it is you see a need to send Postscript to the RIP?  How many layers?  What color space are you using?  When you say "print to a postscript"; what do you mean?  Are you using the Print dialog?  Print > Save PDF as Postscript?
                      • 10. Re: Problems printing a postscript in Illustrator CS4
                        creativesurfacesamanda Newcomer
                        We print RGB files to a rare photo processor called a LightJet. (I am not certain what the brand is at the moment, but they do not make these anymore.)  The files get imaged (printed, or more so, "developed") onto translucent film to be  backlit prints for lighted signs. Due to the photographic nature of the process, we bring in .eps files, from this particular client, pre-press (lay them out & nest them) in Illustrator, then go into the print dialoge box & save as a .ps file.  The wasatch RIP software brings in the PS file, rips it & then converts the file to a .tif.  This process allows for proper resolution/sizing/scaling/photo image quality, as our files sizes are 50" x  97" at maxium size.  We nest the files together because the overall print will get stuck to acrylic or polycarbonate (plexiglass or lexan) & then gets lasered out on an industrial laser.
                        There are in upwards of 100 layers in these files, if not more.  (Don't really have time to "count" them )
                        When I worked for a newspaper office, we did the distiller thing. ..saved as a PDF, then Distilled the file, then dropped it into the rip.  That process was on a MUCH smaller scale than what we deal with here.  That process doesn't work well, when dealing with large signage files.
                        • 11. Re: Problems printing a postscript in Illustrator CS4
                          I also found a suggestion on a Graphic Design forum. They had suggested that I not  "delete/reinstall preferences" but rather just "Reset" them. Ctrl+shift+alt+cmnd... hold these down while starting up Illustrator. That seems to be working thus far.
