the picture above is the installation process coz i already downloaded it then i install it and thats what happen in both internet explorer 9 and mozilla firefox after that the installer disappeared in my downloading folder
then i try it again and same problem occur
i have a good internet connection and my computer fresh from formatting
what should i do ?
Download the current 32 uninstaller Uninstaller for 32 bit Operating Systems
Close all browser windows and run the uninstaller
Restart Windows
Delete all remaining files and folders located in the following directories. (tip: copy and paste these paths into the path bar in a Windows Explorer window)
Verify that the file “FlashPlayerCPLApp.cpl” in C:\Window\system32\ for 32 bit systems has been
...Copy link to clipboard
Download the full installers from http://helpx.adobe.com/flash-player/kb/installation-problems-flash-player-windows.html#Install_in_a_...
didnt work in windows 7 32bit(new windows update)
Sorry, I don't understand "didnt work" - what exactly happened?
What files do you have in C:\Windows\system32\Macromed\Flash ?
Please post the contents of the FlashInstall.log file in that folder.
this is what happen
i already downloaded the adobe flash player 11(download folder when you download using firefox)
then i double click it and run to install that flash player then the next happen is in the picture above sir
What is the name of the downloaded installer? It should be (if downloaded from my link)
here what ive download and trying to install
try to give other link to download the adobe flash player 11
Restart Windows
Verify that the file “FlashPlayerCPLApp.cpl” in C:\Window\system32\ for 32 bit systems has been deleted.
Download the following files:
Physically disconnect from the Internet and run the files.
w0w... thanks carl you 100% solved my problem
thanks to you also pat
