5 Replies Latest reply on Apr 5, 2012 11:20 PM by Gang Cai
    Problem with SelectionState, plase help
    anton.zhuk
      Hi
      I've tried create list and convert it to plain text at runtime.
      With creating text evrething is ok
           var tf:TextLayoutFormat = editor.getFormatOfRange(null, editor.selectionAnchorPosition, editor.selectionActivePosition);
           var selState : SelectionState = new SelectionState(editor.textFlow, editor.selectionAnchorPosition, editor.selectionActivePosition);
           var listFormar : TextLayoutFormat = tf;
           listFormar.listStyleType = ListStyleType.DISC;
           listFormar.listStylePosition = ListStylePosition.OUTSIDE;
           var operation : CreateListOperation = new CreateListOperation(selState, null, listFormar);
           operation.doOperation();
      With this evtething is ok - list was created.
      But when I've tried to convert selected text from list to plain text I have problem. I've selected list but SelectedState return all textFlow from editor (RichEditableText), and I can't receive root list element. Please help to select list in textFlow.
        • 1. Re: Problem with SelectionState, plase help
          anton.zhuk Level 1
          Tell me please, how to determine the DOM elements in TextFlow in RichEditableText by MouseClick?
          • 2. Re: Problem with SelectionState, plase help
            Gang Cai
            I pasted a code scrap of how to enumerate the listElements. Hope it will be helpful
            //this test case will check up to three level nested lists
                                          //create three lists
                                          SelManager.createList();
                                          var tf:TextFlow = SelManager.textFlow;
                                          var listsFound:int = 0;
                                          var elem:FlowElement = tf.getChildAt(0);
                                          while (elem)
                                                    if (elem as ListElement)
                                                              var listElement:ListElement = elem as ListElement;
                                                              var allListElement:Array = [];
                                                              var a:int = 0;
                                                              allListElement[a] = listElement;
                                                              var elem2:FlowElement = listElement.getChildAt(0);
                                                              var e:FlowGroupElement = FlowGroupElement (elem2);
                                                              var i:int=0;
                                                              while (i < e.mxmlChildren.length)
        if (e.mxmlChildren[i] as ListElement)
        var listElement1:ListElement = e.mxmlChildren[i] as ListElement;
        var elem3:FlowElement = listElement1.getChildAt(0);
        var e1:FlowGroupElement = FlowGroupElement (elem3);
        var j:int=0;
        while (j < e1.mxmlChildren.length)
        if (e1.mxmlChildren[j] as ListElement)
        listsFound++;
        a++;
        allListElement[a] = e1.mxmlChildren[j] as ListElement;
        j++;
        listsFound++;
        a++;
        allListElement[a] = e.mxmlChildren[i] as ListElement;
        i++;
                                                              listsFound++;
                                                    elem = elem.getNextSibling();
                                          // determine what the bullet text should be
                                          var listItem:ListItemElement = new ListItemElement();
                                          var bulletText:String = "";
                                          var markerLength:int = 0;
                                          var listStartIndex:int = 0;
                                          var listFlowLine:TextFlowLine;
                                          var listLine:TextLine;
                                          var bulletLine:TextLine;
                                          for (i=0; i<listsFound; i++)
                                                    listElement = allListElement[i] as ListElement;
                                                    listItem = listElement.getChildAt(0) as ListItemElement;
                                                    bulletText = listElement.computeListItemText(listItem, listItem.computedListMarkerFormat());
                                                    markerLength = bulletText.length + 1;
                                                    // find the TextFlowLine for the list start
                                                    listStartIndex = listElement.getElementRelativeStart(tf);
                                                    listFlowLine = tf.flowComposer.findLineAtPosition(listStartIndex);
                                                    listLine = listFlowLine.getTextLine();
                                                    bulletLine = listLine.getChildAt(0) as TextLine;
            • 3. Re: Problem with SelectionState, plase help
              anton.zhuk Level 1
              Thanks for your answer, but I need something else
              for example I've had next text in RTF
              111
              *222
              *333
              *444
              555
              Where 222, 333, 444 are list element
              I've select from 222 to 444 and press button
              Next code are runing
              var elem:FlowElement = selState.textFlow.getChildAt(0);
              So, I've expect get first item from selection, but I've got first item of the textflow - paragraph 111.
              Where did I wrong?
              • 4. Re: Problem with SelectionState, plase help
                anton.zhuk Level 1
                As I see SelectionState doesn't work correctly
                The SelectionState class represents a selection in a text flow.
                But in any case SelectionState return all textFlow. So, this is bug
                • 5. Re: Problem with SelectionState, plase help
                  Gang Cai Level 2
                  There will be only one textFlow in your case. It's the container of all the text elements. The selection state represents the selection in 'that' text flow.
                  The selection state will record the position information of your selection. You should get use the position information to retrieve your text flow elements
