1. Re: Invalid version: InstanceManager does not have property...
BarlaeDC Apr 4, 2012 2:27 AM (in response to nvdm1)Hi,
Can you post the PDF form to a sharing site so that we can see the error and code?
Best to use acrobat.com, that way other people can take a look at it as well if I can't figure it out.
Steps to share a document...
(Thanks Srini for the instruction text!)
1. Go to URL http://Acrobat.com
2. Create an account if you don't have one.
3. Then login to the website.
4. In top left corner you will see a button called Upload.
5. Click on browse and select the file you want to upload.
6. After Uploading, mouse over on the uploaded file. Click the down arrow button and choose Share document.
7. Then you will be prompted a popup window at the lower left corner. Choose "Publish it" option.
8. In the next pop up window choose "Copy Link" option.
9. You can paste the link in the forum thread.
Hope this helps
Malcolm
2. Re: Invalid version: InstanceManager does not have property...
nvdm1 Apr 4, 2012 7:13 AM (in response to BarlaeDC)Hello Malcolm,
Sorry for the late reply, But I had other important stuff to to do.
Here is the link to my form: https://acrobat.com/#d=ZH1MXCMRfd8PJ3Vi9FUgLw
Kind regards,
Niels
3. Re: Invalid version: InstanceManager does not have property...
BarlaeDC Apr 5, 2012 2:22 AM (in response to nvdm1)Hi,
Running the form in Acrobat X 10.1 I do not see the error, which version are you seeing the error in ?
Regards
Malcolm
4. Re: Invalid version: InstanceManager does not have property...
nvdm1 Apr 5, 2012 5:24 AM (in response to BarlaeDC)Hi Malcolm,
I'm running on Acrobat X 10.1.2. If you open the form, there is an icon of paperclip (top left corner). If you click on this icon, you'll see a pdf named: error.pdf. There you can see the error.
This error.pdf is created when the form is generated.
Kind regards,
Niels
5. Re: Invalid version: InstanceManager does not have property...
nvdm1 Apr 6, 2012 12:36 AM (in response to nvdm1)Hi Malcolm,
I want to thank you for helping me. I didn't solve the problem, but I managed to find a workaround (specific for my form) for instancemanager.count warning. I've rewritten my code without using the instancemanager.count.
I think that because the code on the initialize event is run at the client, the instancemanager.count property simply isn't available when the form is generated on the ADS server (SAP).
I won't close the discussion so that someone who has an answer can still reply.
KInd regards,
Niels
