7 Replies Latest reply on Apr 6, 2012 5:38 AM by Nitin Goel
    Publish an audio-only stream (HLS)
    nnmk Level 1
      the documentation says this:
      "To serve streams over a cellular network, one of the streams must be audio-only. For more information, see HTTP Live Streaming Overview.
      To publish an audio-only stream, enter the following in the Flash Media Encoder Stream field:
      If the encoder specifies individual query strings for each stream, use individual stream names instead of the variable %i:
      To generate a set-level variant playlist when using an audio-only stream, specify the audio codec of the audio-only stream. Specify the audio and the video codec of the streams that contain audio and video. For more information about using the Set-level F4M/M3U8 File Generator, see Publish and play live multi-bitrate streams over HTTP.
      Does this mean that using one FMLE encoder (with the installed AAC plugin) i can stream BOTH audio+video AND audio only stream via HLS to iOS clients?
      If yes, how to connect to a+v stream and how to connect audio only stream in iOS  ? (To be more precise - i would need two m3u8 files, how do i create them in the provided generator)
      What about the need to provide multiple bitrates (for the audio), surely 64 isn't enough - multiple encoder machines or multiple encoder instances?
