2. Re: Table of Contents Style Issue
Peter Spier Apr 5, 2012 7:45 AM (in response to jclarke2)Do you have dedicatedTOC styles for the listings, or are you using the same styles as used in the text? It looks like there are some manual overrides or stray characters that are showing up, and they might be in the text itself and getting picked up by the TOC.
3. Re: Table of Contents Style Issue
jclarke2 Apr 5, 2012 11:23 AM (in response to Peter Spier)I do have dedicated TOC styles. I can't find any manual overrides either. When I update the TOC the software gives me a warning asking if I want to include items in Overset Text. What does that mean?
I just noticed that if I change the problem text to "Filter Tool" from "Filter" then I get a valide TOC entry. Is there something that prevents one word entries in the TOC? I notided that all of the places where I have problems are where the entry is just one word.
4. Re: Table of Contents Style Issue
Peter Spier Apr 5, 2012 2:13 PM (in response to jclarke2)The overset text question means do you want to include text that is part of the story, but didn't fit into any frame so is invisible and not on your pages.
No reason why single words shouldn't work.
Select a listing with a problem by triple-clicking to select the whole paragraph. Is there a plus sign showing after the style name? If you show non-printing characters, do you see things like forced line breaks that don't belong?
5. Re: Table of Contents Style Issue
Manish-SharmaApr 5, 2012 2:33 PM (in response to Peter Spier)
Check the prefilght panel on the Bottom left , it will be the green button or the red ,
Double click on it and preflight panel will poen up , and will show the list of the overset text with the page number.
Check on that page from the overset text , check do you have the style applied on any of that text which is included in TOC
6. Re: Table of Contents Style Issue
jclarke2 Apr 6, 2012 1:21 PM (in response to Manish-Sharma)Thanks all for your help. It seems, for whatever reason, that if I chance my section titles to multiple words then they appear as expected in the TOC. I am sure that a combination of the things you all suggested are contributing, but this seems to fix it for me. I appreciate the rapid responses!
