I posted this in the wrong forum I think - so I am reposting this here. Mods please on or the other if this a problem.
I have a form where I have a text box on a positioned page that is set up in the following way
- allow multiple lines - object>field options
- expand to fit - Layout options.
- I do have a height specified as a default.
- this.maxH - ""; - is scripted to shrink the box to the smallest size possible based on the text value.
- this is a dynamic form
It works as designed when test the PDF in reader or acrobat. I have enabled user rights to save the document in acrobat.
The problem is that when I add some text to the textbox, save the document, then reopen it - it collapses the text to one line and shifts the position up. I have wrapped this in subfrom and set it to flowed, but that made no chance. I wonder if there is a conflict with the this.maxH script and auto height.
Any ideas - thanks in advance to any all help.
Total Likes
Have you got the script-based state changes on under Form Properties->Defaults->Scripting->Automatically? Otherwise do you have scripting on any initialise event which would interfere with the state of the save form?
Total Likes
HI and thank you for a response...
I do have automatically checked. Enforced strict scripting is also checked.
PDF render is set format is set to - dyunamic xml form.
I do not have anything the initalize section that speaks to save state... anything else?
Total Likes
