I used Flash Player uninstaller for Mac 10.6.8
restart, go to folders to delete any plugins, only find cache, so delete it.
Go to Flash Status page and it says I still have 11.2.202.228 installed.
Run uninstaller again, same thing.
Ok, then this isn't related to Flash. You appear to be having a problem with YouTube's HTML5 player and I'd recommend posting over on YouTube's forums.
Could you pls do the following in the same order?
Download the appropriate uninstaller from the following page: Uninstall Flash Player | Mac
Yes, did that twice.
Here's the folders empty as well:
Could you check the Internet plug-ins folder in your user folder (~\Library\Internet Plug-Ins\) to see if there's a copy of Flash Player there? Also, what browser are you using? If it's Chrome, then Flash Player is built in and you'll need to do different steps to disable the plugin.
There I have fbplugin_1_0_3.plugin
I'm using Chrome, yes.
Ok, Chrome has Flash Player built in. Are you trying to uninstall Flash Player, update it, or downgrade it?
It is not playing audio on some videos in YouTube.
So I was going to uninstall it, and reinstall it.
You can't do that with Chrome (other than uninstalling Chrome and reinstalling). You can however try and clear the Flash cache to see if that helps. If it doesn't please post back with a URL that causes this to happen and I'll give it a try on my Mac.
Interesting. If you right click on the video does it show a Flash Player menu or is the last menu item "About HTML5". In my case, on both Mac and Win I'm seeing the YouTube HTML5 video player (and sound is working)
I see "About HTML5"
Okay thanks.
