This is greate, it kind of work but how do I manipulate this
information.
This is the error code I am getting trying to evaluate the IP
result with a conditional value:
Complex object types cannot be converted to simple values.
The expression has requested a variable or an intermediate
expression result as a simple value, however, the result cannot be
converted to a simple value. Simple values are strings, numbers,
boolean values, and date/time values. Queries, arrays, and COM
objects are examples of complex values.
The most likely cause of the error is that you are trying to
use a complex value as a simple one. For example, you might be
trying to use a query variable in a <CFIF> tag. This was
possible in ColdFusion 2.0 but creates an error in later versions.
<cfif IsDefined ("aHostIPs") and aHostIPs EQ
"myLookingIP"> Test passed </cfif>
