19 Replies Latest reply on Apr 6, 2012 6:32 AM by Peter Spier
    Can open multiple copies of single document at same time; is there a way to stop this?
    JeffCoMatPro Level 1
      We are running, Mac Pros with OS10.6.8 and CS5.5 . In the past with CS5 if you tried to open an InDesign document that was already open, it would take you to the open document. Since we upgraded to 5.5, if someone tries to open a document already open, it opens a second window of the same document (happens when preference is set to open in tabs also). This is causing problems with saving changes in one version and not the other. Sometimes when the second copy of the document is closed (changes were not made in this copy) it gets copied over the one with the changes.  Is there a setting somewhere to stop this?
