When attempt to download Flash Player 11 I get the following message
"The procedure entry point AlphaBlend could not be located in the dynamic link library."
How do I fix this?
What OS are you using? Can you post the filename you're attempting to install? Finally, do you notice any difference if you use the appropriate installer from this link?
Stand alone installers (Windows)
Chris
Thank you for your response. I am using Windows 7 Enterprise and I am trying to install Adobe Flash Player 11(the newest version). I didn't notice a difference installing from the link you sent me.
Garrett Eggert
Hmm, I'll forward this along to our installer team. I've never seen this error before. Are you trying to install the Active X control or plugin?
In the meantime, let's try using the MSI based installers.
Chris
Shortly after I sent you the message somehow the flash player 11 installed on its own. It seems to be working fine now, but thank you for your help.
Garrett Eggert
Hi Garrett,
Great to hear and thanks for letting me know.
Chris
I am having this exact same problem. I have tried many times to install v 11 and I always get this same error message. I've tried "clean installation" and still no success.
What is your Windows version?
What is the full error message you are getting?
Additionally, what is the name of the installer you are running?
