CFGRID is not working in CF 9.0.1.274733
Guest
Apr 05, 2012 Apr 05, 2012
Hello,
I have problems with the tag cfgrid, locally works fine, but in the server in CF 9.0.1.274733 doesn't work, it displays:
document.write("
I think that is a server problem, but the hosting company tell me that is a code-related error.
I appreciate if somebody can help me.
Thank you
The piece of .cfm code is this, it works fine locally in CF 8 but not in CF 9.0.1.274733
<cfquery name="seeChains" datasource="ds1" username="***" password="***">
SELECT *
FROM chain
    </cfquery>
    <cfquery name="catalogueRFC" datasource="ds1" username="***" password="***">
SELECT distinct rfc_c
FROM chain
    </cfquery>
<cfform name="chains" format="flash" width="100%" height="500">
  <cfformgroup type="panel" label="Our Chains">
<cfselect query="catalogueRFC" queryposition="below" label="RFC" name="myselect1" value="rfc_c" display="rfc_c" width="200">
         <option value="All">All</option>
      </cfselect>
   <cfgrid name="listChains" query="seeChains" >
         <cfgridcolumn header="ID" name="idcadena" />
         <cfgridcolumn header="Nombre" name="nombre_c" />
         <cfgridcolumn header="RFC" name="rfc_c" />
         <cfgridcolumn header="Teléfono principal" name="telefono1_c" />
         <cfgridcolumn header="Teléfono alternativo" name="telefono2_c" />
         <cfgridcolumn header="Correo electrónico" name="correo_c" />
      </cfgrid>
   </cfformgroup>
</cfform>
2.6K
Deleted User
Apr 06, 2012 Apr 06, 2012
Of course, I don't get any JS error neither HTTP errors.
The problem was solved, CFIDE directory was not created properly during enabling of Coldfusion. So we've added it manually.
Thanks a lot.
Participant ,
I never use cfgrid but have you checked all the mappings and virtual directories are the same on the server and locally.
Do you have cfgrid or cf..anything  working on any other pages on the server?
Guest
Thank you for your response cjdunkerley.
I have CFanything working on the server, at the moment the only tag that is not working is cfgrid.
Unoftunately the hosting company do not give me access to the CF configuration.
Any ideas?
Do you get any JS errors?  Or HTTP errors on any <script> requests being made?
It seems unlikely that it would simply not work and give no indication as to why.
Adam
Guest
Hi Adam, thak you for your response.
Locally I don't get any error, it works fine.
You can get a look to the .cfm in the server:
http://www.retaileader.com.mx/sistemarl/ejemploOrdenaFiltraCadenas.cfm
http://www.retaileader.com.mx/sistemarl/ejemplo2OrdenaFiltraCadenas.cfm
The only message from the server is
document.write("
Really I don´t know whats wrong in the server.
Right, lovely.
Can you pls answer the questions I asked.
Adam
Guest
Thanks a lot.
Apr 07, 2012 Apr 07, 2012
Right, so if that was the case you'd've been getting HTTP errors, surely?  As the page tried to load in script resources from the CFIDE dir, and it wasn't found..?
Adam
Documentation
