5 Replies Latest reply on Apr 7, 2012 10:52 AM by Ned Murphy
    removin bullets from stage after game over
    mr.shumi Newcomer
      in my game enemy Planes shoot at my plane and everything is working fine
      enemy bullets are inside an array
      the problem is when my plane gets destroyed by enemy Planes ,the last bullets shot by the enemyPlanes still shows on the screen
      eventhough i called a removelistener function and added a game over screen
      enemy planes use timer which i have a listener for it
      how can i remove the last bullets that still shows on the screen?
        • 1. Re: removin bullets from stage after game over
          Ned Murphy Legend
          If the bullets are stored in an array, then use removeChild to remove them and set any references to them as null.  Empty the array when you are done.
          • 2. Re: removin bullets from stage after game over
            mr.shumi Newcomer
            // responsible for making an enemy plane shoot when the timer start
            public function e1ShootBullet(event:TimerEvent):void
                        //Create a bullet and add it to the stage
                        enemyBullet1 = new Bullets(getAngle2(enemyPlane1));
                        stage.addChild(enemyBullet1);
                        //Set the bullet's starting position
                        var radius:int = 30;
                        var angle:Number = enemyPlane1.rotation * Math.PI / 180;
                        enemyBullet1.x = enemyPlane1.x + radius * Math.cos(angle);
                        enemyBullet1.y = enemyPlane1.y + radius * Math.sin(angle);
                        //Set the bullet's velocity based
                        //on the angle
                        enemyBullet1.vx = Math.cos(angle) * 5;
                        enemyBullet1.vy = Math.sin(angle) * 5;
                        //Push the bullet into the _bullets array
                        _eBullet.push(enemyBullet1);
                        //Find a random start time for the next bullet
                        var randomFireTime:Number = Math.round(Math.random() * 1000) + 200;
                        //_timer1.delay = randomFireTime;
            // responsible for moving the enemy Planes bullets called from an enter frame function
            private function moveEnemyBullet( enemyPlane :MovieClip)
                        if (enemyPlane == enemyPlane1)
                            for (var i:int = 0; i < _eBullet.length; i++)
                                enemyBullet1 = _eBullet[i];
                                enemyBullet1.x +=  enemyBullet1.vx;
                                enemyBullet1.y +=  enemyBullet1.vy;
                                if (enemyBullet1.y < 0 || enemyBullet1.x < 0 || enemyBullet1.x > stage.stageWidth || enemyBullet1.y > 609)
                                    //Remove the bullet from the stage
                                    stage.removeChild(enemyBullet1);
                                    bullethit.play();
                                    //Remove the bullet from the _bullets;
                                    //array
                                    _eBullet.splice(i,1);
                                    enemyBullet1 = null;
                                    //Reduce the loop counter
                                    //by one to compensate
                                    //for the removed bullet
            // end Game function
            private function endGame( endMessage:String):void
                        endScreen = new winLoose();
                        endScreen.end_txt.text = endMessage;
                        //endScreen.score_txt.text = String(_PlaneScoreDisplay);
                        addChild(endScreen);
                        endScreen.x = 0;
                        endScreen.y = 0;
                        _timer1.removeEventListener(TimerEvent.TIMER, e1ShootBullet);
                        _timer2.removeEventListener(TimerEvent.TIMER, e2ShootBullet);
                        _timer1.stop();
                        _timer2.stop();
                        _PlaneScoreDisplay.text = "";
                        bombsLeftDisplay.text = "";
                        endScreen.playAgain_btn.addEventListener(MouseEvent.CLICK, startGame);
            • 3. Re: removin bullets from stage after game over
              Ned Murphy Legend
              I am not sure why you are showing the code without any explanation, but I do not see where you are removing any of the bullets in your endGame function, which is where you say you wanted them to go away... you only do it in your moveEnemyBullet function
              • 4. Re: removin bullets from stage after game over
                mr.shumi Newcomer
                damn i missed that  ^^ damn i just get lost in my own code
                i should do the same
                • 5. Re: removin bullets from stage after game over
                  Ned Murphy Legend
                  yep, and clear the array
