16 Replies Latest reply on Apr 11, 2012 5:12 PM by elcee52
    images "not found" in Develop module
    elcee52
      After successful import, when switching to the Develop module, I receive 'image not found.'
      The filmstrip at the bottom of the module shows no images. The images are there when I
      switch back to Library. I have to quit LR4. When I repon the catalog, LR opens to the first
      image in the Develop module.
      Mac OS 10.6.8
        • 1. Re: images "not found" in Develop module
          gaksland
          I'm using LR4, the Develop module is very slow. The latest problem has presented real concern. In Develop Module I removed a photo and the whole file was deleated. I found the deleted file in the Windows recycle bin. I restored the file then reimported the file into LR4.
          Now I'm concerned about doing work in LR4, I don't what will happen next.
          • 2. Re: images "not found" in Develop module
            dj_paige Level 9
            When you try to delete a photo, you have two options: "Remove" or "Delete From Disk". Sounds like you clicked on Delete From Disk, that's the only way to have a photo wind up in the recycle bin.
            • 3. Re: images "not found" in Develop module
              dj_paige Level 9
              How did you do the import? What disk was the photo on before the import, and what disk was the photo on after the import?
              • 4. Re: images "not found" in Develop module
                gaksland Level 1
                Just happened to think to look in the Windows Recycle bin. I searched the bin for the file name I used in LR4. The search found the file (Storyland). I clicked restore file. I found the restored file in the LR4 directory in Windows right, were it should be. I then went into LR4 and used Import to bring the file in to LR4. I have just gone through the file and everything is there and I have been able to work with the file in Develop Module. This time I have used the flag for deletion option and that worked.
                I did not want to lose any of the Grand kids images at Story Land!
                Gene
                • 5. Re: images "not found" in Develop module
                  gaksland Level 1
                  Yes, I have used the delete from disk before with no problem. This time Delete removed the whole file not just the selected image.
                  Gene
                  • 6. Re: images "not found" in Develop module
                    elcee52 Level 1
                    I imported the files directly from the card reader into a  sub-folder, as I have from 1.0.
                    I think the problem happens only when I have an existing catalog open, then start a new catalog
                    for new images. LR4 gets confused, but the images are where I expect them on the hard drive.
                    • 7. Re: images "not found" in Develop module
                      dj_paige Level 9
                      This is one of many  many mnay reasons why you should use one catalog for all your photos.
                      • 8. Re: images "not found" in Develop module
                        dj_paige Level 9
                        THere are multiple different types of selections in the Lightroom Library Module, unlike Windows where a file is either selected or not. You need to be careful to make sure only the file you want is selected (light grey) and others are not selected (medium gray) ... if you have photos selected with both light and medium gray when you do a delete, both selection will be deleted in that situation.
                        • 9. Re: images "not found" in Develop module
                          elcee52 Level 1
                          I never had a problem until now! I consider one catalog to be a Single Point Of Failure.
                          • 10. Re: images "not found" in Develop module
                            dj_paige Level 9
                            Not only are there bazillions of Lightroom users who haven't had a problem using a single catalog (okay, so thats an exaggeration, but I would guess there are hundreds of thousands of Lightroom users who haven't had a problem with a single catalog); but the solution is to make regular backups of your catalog. If my catalog goes bad today, I still have yesterday's catalog, and the day before -- not that my catalog has ever gone bad.
                            There are many many many benefits to having a single catalog; and many many many disadvantages to multiple catalogs. You have already come across one problem (human error) caused by multiple catalogs, something that will happen over and over again because us humans aren't perfect; but you are avoiding a failure mode that very rarely happens, and can be easily protected against.
                            It's your choice.
                            • 11. Re: images "not found" in Develop module
                              elcee52 Level 1
                              Let me ask dj a question: in your workflow, do you really meant to say that you import photos and immediately back up, therefore not experiencing human errors?? I have done nothing different than the other 448 times I have imported files since December 2007. I am to believe that my catalog was corrupted in the time between import to moving directly to the Develop module? Wow. I guess it could happen.
                              • 12. Re: images "not found" in Develop module
                                Geoff the kiwi Adobe Community Professional & MVP
                                I does sound like it could be a previews issue possibly. Is this an upgraded catalog? If so try deleting the previews folder and generating new ones through being in All Photographs, selecting all then Library>Previews>Render Standard.
                                Let us know if that works please.
                                • 13. Re: images "not found" in Develop module
                                  elcee52 Level 1
                                  not an upgraded catalog
                                  It's a new catalog
                                  As I said, this is the 2nd time this has happened
                                  may have something to do with 1) opening the previous catalog ii) starting a new catalog as stated previously.
                                  These are probably the only catalogs with which I have done this (and the only catalogs with which I have had trouble) since installing v4. I had no such trouble under v3.
                                  I'll see if I can reproduce a 3rd time with photos I take later today.
                                  • 14. Re: images "not found" in Develop module
                                    elcee52 Level 1
                                    Import session #1
                                    1. started LR4, which opened in previously viewed catalog.
                                    2. File>New catalog, named catalog
                                    3. used new catalog as import destination
                                    4. after import, switched to Develop model: "no image selected" (none in filmstrip; switch back to Library to see)
                                    Import session #2
                                    1. quit LR
                                    2. start LR, clicked on 'create new catalog' button
                                    4. after import, switched to Develop model: all images available for editing.
                                    It's not a corrupt catalog, it' a reproducible bug. Starting to think I need to reload LR or OS.
                                    • 15. Re: images "not found" in Develop module
                                      Let's see what the Lr team think. I'll make them aware of this issue.
                                      • 16. Re: images "not found" in Develop module
                                        elcee52 Level 1
                                        Thank you, Mr. the Kiwi!!
