f() duplicated
Contributor ,
Apr 07, 2012 Apr 07, 2012
Hello
I have the same f() in frame 1 and frame 2, and when I play the movie again, it says f() dupliicated.
How can change it in the second frame, not to be the same. Here is the f()
function onEnterFrame(event:Event):void
domystuff;
ActionScript
731
LEGEND , Apr 07, 2012 Apr 07, 2012
Don't use the same function name, or just use the one from frame 1 if they both do the same thing... just have frame 1 extend thru frame 2
Contributor ,
How can I keep the same function doing the same thing by changing the name ? Particularly this function, how can I do it ?
dosamestuff;
Contributor ,
I just changed the name of the f(). Problem solved. Thank you.
You can use a function that is in frame 1 even in frame 2 if you extend it along the layer.  Just like if you wanted an object to span across frames, you can do the same with code elements like functions and variables.
Contributor ,
Apr 08, 2012 Apr 08, 2012
Thank you Ned. You are right, both ways. Thanks to your input, now I can make my record  flip to side number 2 and play the second song.
