1. Re: Is Photoshop worth it?
Barbara B. Apr 8, 2012 9:13 AM (in response to hank131md)1 person found this helpfulI cant enlarge the image to work on like I can with DPP
Why not? What happens when you try?
I'm not sure what you're doing to make this so complicated, but this:
the edges of the rings took on a red shade
sounds like maybe you're working on the same layer for the conversion and the color and using too large of a feather value for the selection.
You shouldn't have to keep sending an image back and forth to DPP. Maybe if you can tell us the steps you're following, it would be easier to help you figure out where you're going wrong.
But you should definitely be able to zoom way in to work, so maybe start by explaining how you're trying to zoom the view that isn't working for you.
2. Re: Is Photoshop worth it?
hank131md Apr 8, 2012 11:00 AM (in response to Barbara B.)Hi Barbara,
When I open the image in editor it comes in a 6x4ish size. If I click on the square icon on the top right of the box it doesnt get any bigger and I dont know where the icon is to make the image larger.
I open what I do get, use the lasso/marching ants around the edges of the two rings and invert the image so i can then make everything but the two gold rings B&W. When I save it though I get red edging/shadows between the B&W and some of the retained colour area.
I also have problems getting the colour to do the stamping, where in DPP you grab a colour and can put it anywhere in the image, in PSE7 it seems to only work part of the time and when it doesnt it comes out black.
I havent been able to send it back to DPP, I just thought that if I could invert the B&W and colour in PSE I could then work on the stamping and fine tuning in DPP which I find easy to use.
Leigh
3. Re: Is Photoshop worth it?
Barbara B. Apr 8, 2012 12:05 PM (in response to hank131md)1 person found this helpfulYou don't use an icon to zoom the view. Use the magnifying glass tool (the zoom tool) or just press ctrl + the equal sign key. You can think of it as command plus the plus sign but since you don't need shift adobe prefers to think of it as command plus the equal sign these days.
I don't understand at all what you mean by "color stamping", sorry, and I have DPP, but it should not be necessary.
Here's a simple way to do this in PSE 7:
1. Open your image and press Ctrl+J to duplicate the background layer.
2. In the layers palette, click the new layer to make sure it's active, then go to Enhance>Convert to Black and White to turn that layer black and white.
3. Get out the eraser tool and erase the rings to let the color show through from the underlying layer.
4. Re: Is Photoshop worth it?
photodrawken Apr 8, 2012 12:05 PM (in response to hank131md)1 person found this helpfulYou'll get some targetted advice for this specific image if you would include the image in your post.
In general, with PSE7, you could make a duplicate of your colour background layer, convert the duplicated layer to B&W, then use the Eraser tool on that B&W image to carefully erase areas of the B&W layer to reveal the colour image below. Zoom in to get an accurate view of your erasing.
Ken
5. Re: Is Photoshop worth it?
hank131md Apr 8, 2012 12:54 PM (in response to Barbara B.)Thanks Barbara I shall give that a try. By colour stamping I mean choosing a sample area in DPP stamp tool and transfering that sample to the area I want to stamp. Cheers Ken, I hadnt realised I could add pics so you can see I am having trouble smoothing the edges of the rings but I shall try your advice
6. Re: Is Photoshop worth it?
Barbara B. Apr 8, 2012 1:04 PM (in response to hank131md)1 person found this helpfulIn PSE you would use the clone stamp for that. You will need to first alt-click the spot where you want the stamp to sample from.
EDIT for your trouble with getting the edges, you need to zoom in more and use a smaller brush in those spots.
8. Re: Is Photoshop worth it?
hatstead Apr 8, 2012 1:35 PM (in response to Barbara B.)If I understand correctly, you wish to convert the picture to b/w, yet retain the gold rings and diamonds unaltered. Please correct me if indicated.
I would use a mask for this purpose. You have PSEv.7. You posted a picture which has been altered partially, hence I restricted my effort the ring on the viewer's left:
- Open picture
- Duplicate background layer
- Convert the background copy layer to b/w
- Open a levels adjustment layer between the background and background copy layers. Do nothing with the levels sliders. We shall hijack the layer mask
- Clip the background copy layer to the levels adjustment layer with CTRL+G on the keyboard
- Left click the mask (the white rectangle) and paint with a black brush to reveal the gold color. If you go too far, correct with a white brush
TIPS: The bracket keys next to the letter P decrease and increase the size of the cursor for the brush tool
x will allow you to toggle between white and black (color chips, lower left)
9. Re: Is Photoshop worth it?
hatstead Apr 8, 2012 1:44 PM (in response to hatstead)Further to above, it is even easier to do the following:
- Open picture
Open a Hue/saturation adjustment layer above the background copy layer. Slide the saturation slider all the way to the left
- Paint with a black brush to reveal the gold color, correct with white
10. Re: Is Photoshop worth it?
hank131md Apr 8, 2012 2:13 PM (in response to hatstead)Thanks for the help, the second picture posted is the one I wanted, the ring colours are as taken and the background is now B&W but it is interesting to see the number of variations on how to get the same result.
Leigh
11. Re: Is Photoshop worth it?
photodrawken Apr 8, 2012 2:26 PM (in response to hank131md)Glad to help. You're absolutely right about PSE usually having more than one way of achieving an effect. With PSE10, you not only gain all the bug fixes since PSE7, but also features (specifically the ability to create a layer mask) that make your example very easy to do.
Ken
12. Re: Is Photoshop worth it?
hatstead Apr 8, 2012 4:19 PM (in response to photodrawken)You're welcome. Use of a layer mask is the way to go here. You can make small corrections easily.
13. Re: Is Photoshop worth it?
hank131md Apr 9, 2012 1:06 AM (in response to hatstead)Cheers, I might need to get back to you for some tips on that as well, the guide books I bought dont seem to always relate to whats on my screen!
14. Re: Is Photoshop worth it?
hank131md Apr 9, 2012 1:08 AM (in response to photodrawken)If I buy PSE10 will it just 'blend' into PSE7 or do I need to remove PSE7 first?
15. Re: Is Photoshop worth it?
hatstead Apr 9, 2012 3:51 AM (in response to hank131md)You can have both programs on your computer. Don't be in a hurry to remove v.7, esp.if you utilize the organizer.
16. Re: Is Photoshop worth it?
hank131md Apr 20, 2012 3:47 PM (in response to photodrawken)i have just tried doing the (what i think is) the same thing to another picture and cant get it to work, all the bruch is doing to the B&W is removing everything
17. Re: Is Photoshop worth it?
snyder2201 Apr 21, 2012 5:50 AM (in response to hank131md)In reply to the original question if you are a Mac user this program is not ready for prime time. Still to many bugs and also things which you can do on a PC you will not be able to do on a Mac.
18. Re: Is Photoshop worth it?
photodrawken Apr 21, 2012 11:56 AM (in response to hank131md)Post a screenshot of your layers, you're probably working on the background image.
Ken
