11 Replies Latest reply on Apr 11, 2012 7:14 AM by Curt Y
    CS5 bridge Crashes Consistently
    nuharjegfaaetnok Level 1
      After the latest update to Windows XP Bridge in CS5 crashes consistently each and every time I move a number of files from one folder to the next.
      The files get moved all right, but then Bridge vanishes.
      The behavior is the same when I drag files and when I use Edit Cut - Paste.
      I cleared the preview/thumbnail cache for all images in the hope that it was a caching issue but that made no difference.
      Until this recent update Bridge was very reliable and never crashed.
      I thought I could file a problem report with Adobe but there is no option for that. I hope someone here can help.
        • 1. Re: CS5 bridge Crashes Consistently
          Noel Carboni Level 7
          Did the Windows Update by chance deliver an updated display driver?  Sometimes they deliver drivers that are actually not as stable as what you may have had installed before.
          Usually if you visit the web site of the maker of your video card and download their latest release yourself you'll be better off.  For example, you could get the Catalyst 12.3 software from ATI, and it's quite good.
          -Noel
          • 2. Re: CS5 bridge Crashes Consistently
            I have the latest display driver installed. And it was installed a while back.
            It is only Bridge that crashes when moving files around, not Photoshop, which stays open.
            • 3. Re: CS5 bridge Crashes Consistently
              Seems unlikely, depending on your definition of "a while".  Display driver updates are released almost every month.
              Check your Windows Application Log for the specifics of why Bridge is crashing.  You may turn up information there that helps narrow down the cause.
              -Noel
              • 4. Re: CS5 bridge Crashes Consistently
                Good idea.
                Here is what I get:
                Application exception occurred:
                        App: C:\Program Files\Adobe\Adobe Bridge CS5\Bridge.exe (pid=2164)
                        When: 2012-04-08 @ 12:09:04.732
                        Exception number: c0000005 (access violation)
                Followed by a lot of stuff that doesn't tell me anything about what the problem might be (task list, module list, thread information).
                Access violation usually indicates that the application is trying to write where it shouldn't. This is really weird.
                • 5. Re: CS5 bridge Crashes Consistently
                  Level 7
                  The rest of the crash report might tell us something, or at least tell the Bridge engineers where it is crashing.
                  • 6. Re: CS5 bridge Crashes Consistently
                    Anything in there about "Faulting Module"?  That's sometimes helpful.
                    -Noel
                    • 7. Re: CS5 bridge Crashes Consistently
                      Chris,
                      I don't see a way to attache a file so you get the entire log here:
                      Microsoft (R) DrWtsn32
                      Copyright (C) 1985-2001 Microsoft Corp. All rights reserved.
                      *----> System Information <----*
                              Computer Name: VAIOPC
                              User Name: Owner
                              Terminal Session Id: 0
                              Number of Processors: 2
                              Processor Type: x86 Family 15 Model 6 Stepping 2
                              Windows Version: 5.1
                              Current Build: 2600
                              Service Pack: 3
                              Current Type: Multiprocessor Free
                              Registered Organization:
                              Registered Owner: Owner
                      *----> Task List <----*
                         0 System Process
                         4 System
                      840 smss.exe
                      892 csrss.exe
                      920 winlogon.exe
                      972 services.exe
                      988 lsass.exe
                      1152 svchost.exe
                      1256 svchost.exe
                      1300 svchost.exe
                      1444 svchost.exe
                      1492 svchost.exe
                      1732 ccSetMgr.exe
                      1760 ccEvtMgr.exe
                      2028 spoolsv.exe
                      268 svchost.exe
                      304 svchost.exe
                      420 ALUSchedulerSvc.exe
                      472 ehRecvr.exe
                      488 ehSched.exe
                      604 svchost.exe
                      624 iaantmon.exe
                      872 jqs.exe
                      1676 LxrSII1s.exe
                      1704 sqlservr.exe
                      1908 ccSvcHst.exe
                      1252 NPROTECT.EXE
                      2180 StartManSvc.exe
                      2456 RMSvc.exe
                      2624 SonicStageMonitoring.exe
                      2672 NOPDB.EXE
                      2760 svchost.exe
                      2788 svchost.exe
                      2812 symlcsvc.exe
                      3140 USBDLM.exe
                      3204 VESMgr.exe
                      3400 VCSW.exe
                      3476 VzCdbSvc.exe
                      3608 wmccds.exe
                      668 McrdSvc.exe
                      880 VzFw.exe
                      2488 dllhost.exe
                      2772 alg.exe
                      3192 ccSvcHst.exe
                      2716 Explorer.EXE
                      1412 atiptaxx.exe
                      3904 iaanotif.exe
                      3956 fppdis2a.exe
                      484 EEventManager.exe
                      648 ccApp.exe
                      3584 hpztsb04.exe
                      1248 RIMBBLaunchAgent.exe
                      3784 jusched.exe
                      3496 ctfmon.exe
                      3780 TrueCrypt.exe
                      2164 Bridge.exe
                      2380 SwitchBoard.exe
                      2332 Photoshop.exe
                      3624 CS5ServiceManager.exe
                      636 wmiprvse.exe
                      884 drwtsn32.exe
                      *----> Module List <----*
                      (0000000000360000 - 0000000000373000: C:\Program Files\Adobe\Adobe Bridge CS5\Symlib.dll
                      (00000000003b0000 - 00000000003fc000: C:\Program Files\Adobe\Adobe Bridge CS5\AdobeXMP.dll
                      (0000000000400000 - 0000000000fa3000: C:\Program Files\Adobe\Adobe Bridge CS5\Bridge.exe
                      (0000000000fb0000 - 000000000109f000: C:\Program Files\Adobe\Adobe Bridge CS5\icuin36.dll
                      (00000000010a0000 - 0000000001346000: C:\Program Files\Adobe\Adobe Bridge CS5\LIBMYSQLD.dll
                      (0000000001350000 - 00000000013e5000: C:\Program Files\Adobe\Adobe Bridge CS5\AdobeXMPFiles.dll
                      (0000000001400000 - 00000000014fb000: C:\Program Files\Adobe\Adobe Bridge CS5\ACE.dll
                      (0000000001510000 - 0000000001559000: C:\Program Files\Adobe\Adobe Bridge CS5\BIB.dll
                      (0000000001570000 - 0000000001616000: C:\Program Files\Adobe\Adobe Bridge CS5\ExtendScript.dll
                      (0000000001630000 - 00000000016c1000: C:\Program Files\Adobe\Adobe Bridge CS5\ScCore.dll
                      (00000000016e0000 - 0000000001720000: C:\Program Files\Adobe\Adobe Bridge CS5\BIBUtils.dll
                      (0000000001730000 - 0000000001a27000: C:\Program Files\Adobe\Adobe Bridge CS5\CoolType.dll
                      (0000000001a40000 - 0000000001a6e000: C:\Program Files\Adobe\Adobe Bridge CS5\AXE8SharedExpat.dll
                      (00000000026f0000 - 000000000275a000: C:\Program Files\Adobe\Adobe Bridge CS5\adobe_caps.dll
                      (00000000027c0000 - 00000000027cc000: C:\Program Files\Adobe\Adobe Bridge CS5\Plug-Ins\FastCore.8BX
                      (0000000002af0000 - 0000000002e5a000: C:\Program Files\Adobe\Adobe Bridge CS5\AGM.dll
                      (0000000002e60000 - 0000000002ec5000: C:\Program Files\Adobe\Adobe Bridge CS5\Required\PhotoShopAdapter.apl
                      (0000000002ed0000 - 0000000002f78000: C:\Program Files\Adobe\Adobe Bridge CS5\Plug-Ins\MMXCore.8BX
                      (0000000002f90000 - 0000000003253000: C:\Program Files\Adobe\Adobe Bridge CS5\libmmd.dll
                      (0000000003270000 - 00000000032c3000: C:\Program Files\Adobe\Adobe Bridge CS5\Plug-Ins\MultiProcessor Support.8BX
                      (00000000032e0000 - 00000000032ee000: C:\Program Files\Adobe\Adobe Bridge CS5\PLUGIN.dll
                      (0000000003400000 - 0000000004757000: C:\Program Files\Common Files\Adobe\Plug-Ins\CS5\File Formats\Camera Raw.8bi
                      (0000000005030000 - 0000000005039000: C:\Program Files\Adobe\Adobe Bridge CS5\adbeape.dll
                      (0000000005050000 - 000000000506b000: C:\Program Files\Common Files\Adobe\APE\3.1\adbeapecore.dll
                      (000000000eac0000 - 000000000eb70000: C:\Program Files\Adobe\Adobe Bridge CS5\SwitchBoardClient.dll
                      (000000000ef50000 - 000000000ef59000: C:\WINDOWS\system32\Normaliz.dll
                      (000000000f6f0000 - 000000000f784000: C:\Program Files\Adobe\Adobe Bridge CS5\FileInfo.dll
                      (000000000fce0000 - 000000000fcf7000: C:\WINDOWS\system32\odbcint.dll
                      (000000000fd40000 - 000000000ff80000: C:\WINDOWS\system32\WMVCore.DLL
                      (000000000ff80000 - 000000000ffbb000: C:\WINDOWS\system32\WMASF.DLL
                      (0000000010000000 - 00000000100e6000: C:\Program Files\Adobe\Adobe Bridge CS5\amtlib.dll
                      (00000000101f0000 - 00000000104b5000: C:\WINDOWS\system32\xpsp2res.dll
                      (0000000014120000 - 0000000014234000: C:\Program Files\Adobe\Adobe Bridge CS5\amtservices.dll
                      (0000000014490000 - 0000000014523000: C:\Program Files\Adobe\Adobe Bridge CS5\updaternotifications.dll
                      (000000003d930000 - 000000003da16000: C:\WINDOWS\system32\WININET.dll
                      (000000003dfd0000 - 000000003e1bb000: C:\WINDOWS\system32\iertutil.dll
                      (000000003e1c0000 - 000000003ec56000: C:\WINDOWS\system32\ieframe.dll
                      (0000000040000000 - 0000000040079000: C:\WINDOWS\system32\audiodev.dll
                      (000000004a800000 - 000000004a904000: C:\Program Files\Adobe\Adobe Bridge CS5\icuuc36.dll
                      (000000004ad00000 - 000000004b6b2000: C:\Program Files\Adobe\Adobe Bridge CS5\icudt36.dll
                      (000000004d4f0000 - 000000004d549000: C:\WINDOWS\system32\WINHTTP.dll
                      (000000004ec50000 - 000000004edfb000: C:\WINDOWS\WinSxS\x86_Microsoft.Windows.GdiPlus_6595b64144ccf1df_1.0.6002.22509_x-ww_c7da d023\gdiplus.dll
                      (000000004fdd0000 - 000000004ff76000: C:\WINDOWS\system32\d3d9.dll
                      (00000000593f0000 - 0000000059482000: C:\WINDOWS\system32\wiashext.dll
                      (000000005ad70000 - 000000005ada8000: C:\WINDOWS\system32\uxtheme.dll
                      (000000005b860000 - 000000005b8b5000: C:\WINDOWS\system32\netapi32.dll
                      (0000000060d20000 - 0000000060d88000: C:\PROGRAM FILES\NORTON INTERNET SECURITY\ENGINE\18.7.1.3\ASOEHOOK.DLL
                      (0000000061880000 - 00000000618ba000: C:\WINDOWS\system32\OLEACC.dll
                      (00000000662b0000 - 0000000066308000: C:\WINDOWS\system32\hnetcfg.dll
                      (0000000068000000 - 0000000068036000: C:\WINDOWS\system32\rsaenh.dll
                      (0000000069450000 - 0000000069466000: C:\WINDOWS\system32\faultrep.dll
                      (000000006bc00000 - 000000006bc1a000: C:\WINDOWS\system32\DrvTrNTm.dll
                      (000000006bc20000 - 000000006bc46000: C:\WINDOWS\system32\DrvTrNTl.dll
                      (000000006d990000 - 000000006d996000: C:\WINDOWS\system32\d3d8thk.dll
                      (0000000071a50000 - 0000000071a8f000: C:\WINDOWS\System32\mswsock.dll
                      (0000000071a90000 - 0000000071a98000: C:\WINDOWS\System32\wshtcpip.dll
                      (0000000071aa0000 - 0000000071aa8000: C:\WINDOWS\system32\WS2HELP.dll
                      (0000000071ab0000 - 0000000071ac7000: C:\WINDOWS\system32\WS2_32.dll
                      (0000000071ad0000 - 0000000071ad9000: C:\WINDOWS\system32\WSOCK32.dll
                      (0000000071b20000 - 0000000071b32000: C:\WINDOWS\system32\MPR.dll
                      (0000000071bf0000 - 0000000071c03000: C:\WINDOWS\system32\SAMLIB.dll
                      (0000000071c10000 - 0000000071c1e000: C:\WINDOWS\System32\ntlanman.dll
                      (0000000071c80000 - 0000000071c87000: C:\WINDOWS\System32\NETRAP.dll
                      (0000000071c90000 - 0000000071cd0000: C:\WINDOWS\System32\NETUI1.dll
                      (0000000071cd0000 - 0000000071ce7000: C:\WINDOWS\System32\NETUI0.dll
                      (0000000073000000 - 0000000073026000: C:\WINDOWS\system32\WINSPOOL.DRV
                      (0000000073b30000 - 0000000073b45000: C:\WINDOWS\system32\mscms.dll
                      (0000000073ba0000 - 0000000073bb3000: C:\WINDOWS\system32\sti.dll
                      (0000000073bc0000 - 0000000073bc6000: C:\WINDOWS\system32\dciman32.dll
                      (0000000073d70000 - 0000000073d83000: C:\WINDOWS\system32\shgina.dll
                      (0000000074320000 - 000000007435d000: C:\WINDOWS\system32\ODBC32.dll
                      (0000000074720000 - 000000007476c000: C:\WINDOWS\system32\MSCTF.dll
                      (0000000074ae0000 - 0000000074ae7000: C:\WINDOWS\system32\CFGMGR32.dll
                      (0000000074ed0000 - 0000000074ede000: C:\WINDOWS\system32\wbem\wbemsvc.dll
                      (0000000074ef0000 - 0000000074ef8000: C:\WINDOWS\system32\wbem\wbemprox.dll
                      (0000000075290000 - 00000000752c7000: C:\WINDOWS\system32\wbem\wbemcomn.dll
                      (00000000755c0000 - 00000000755ee000: C:\WINDOWS\system32\msctfime.ime
                      (0000000075690000 - 0000000075706000: C:\WINDOWS\system32\wbem\fastprox.dll
                      (0000000075830000 - 0000000075875000: C:\WINDOWS\system32\mstask.dll
                      (0000000075970000 - 0000000075a68000: C:\WINDOWS\system32\MSGINA.dll
                      (0000000075cf0000 - 0000000075d81000: C:\WINDOWS\system32\MLANG.dll
                      (0000000075f60000 - 0000000075f67000: C:\WINDOWS\System32\drprov.dll
                      (0000000075f70000 - 0000000075f7a000: C:\WINDOWS\System32\davclnt.dll
                      (0000000076080000 - 00000000760e5000: C:\WINDOWS\system32\MSVCP60.dll
                      (0000000076360000 - 0000000076370000: C:\WINDOWS\system32\WINSTA.dll
                      (0000000076380000 - 0000000076385000: C:\WINDOWS\system32\MSIMG32.dll
                      (0000000076390000 - 00000000763ad000: C:\WINDOWS\system32\IMM32.DLL
                      (00000000763b0000 - 00000000763f9000: C:\WINDOWS\system32\comdlg32.dll
                      (0000000076600000 - 000000007661d000: C:\WINDOWS\System32\CSCDLL.dll
                      (00000000767a0000 - 00000000767b3000: C:\WINDOWS\system32\NTDSAPI.dll
                      (0000000076980000 - 0000000076988000: C:\WINDOWS\system32\LINKINFO.dll
                      (0000000076990000 - 00000000769b5000: C:\WINDOWS\system32\ntshrui.dll
                      (00000000769c0000 - 0000000076a74000: C:\WINDOWS\system32\USERENV.dll
                      (0000000076b20000 - 0000000076b31000: C:\WINDOWS\system32\ATL.DLL
                      (0000000076b40000 - 0000000076b6d000: C:\WINDOWS\system32\WINMM.dll
                      (0000000076c30000 - 0000000076c5e000: C:\WINDOWS\system32\WINTRUST.dll
                      (0000000076c90000 - 0000000076cb8000: C:\WINDOWS\system32\IMAGEHLP.dll
                      (0000000076d60000 - 0000000076d79000: C:\WINDOWS\system32\iphlpapi.dll
                      (0000000076f20000 - 0000000076f47000: C:\WINDOWS\system32\DNSAPI.dll
                      (0000000076f50000 - 0000000076f58000: C:\WINDOWS\system32\WTSAPI32.dll
                      (0000000076f60000 - 0000000076f8c000: C:\WINDOWS\system32\WLDAP32.dll
                      (0000000076fb0000 - 0000000076fb8000: C:\WINDOWS\System32\winrnr.dll
                      (0000000076fc0000 - 0000000076fc6000: C:\WINDOWS\system32\rasadhlp.dll
                      (0000000076fd0000 - 000000007704f000: C:\WINDOWS\system32\CLBCATQ.DLL
                      (0000000077050000 - 0000000077115000: C:\WINDOWS\system32\COMRes.dll
                      (0000000077120000 - 00000000771ab000: C:\WINDOWS\system32\OLEAUT32.dll
                      (00000000773d0000 - 00000000774d3000: C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.6028_x- ww_61e65202\comctl32.dll
                      (00000000774e0000 - 000000007761e000: C:\WINDOWS\system32\ole32.dll
                      (0000000077690000 - 00000000776b1000: C:\WINDOWS\system32\NTMARTA.DLL
                      (0000000077920000 - 0000000077a13000: C:\WINDOWS\system32\SETUPAPI.dll
                      (0000000077a20000 - 0000000077a74000: C:\WINDOWS\System32\cscui.dll
                      (0000000077a80000 - 0000000077b15000: C:\WINDOWS\system32\CRYPT32.dll
                      (0000000077b20000 - 0000000077b32000: C:\WINDOWS\system32\MSASN1.dll
                      (0000000077b40000 - 0000000077b62000: C:\WINDOWS\system32\appHelp.dll
                      (0000000077c00000 - 0000000077c08000: C:\WINDOWS\system32\VERSION.dll
                      (0000000077c10000 - 0000000077c68000: C:\WINDOWS\system32\msvcrt.dll
                      (0000000077dd0000 - 0000000077e6b000: C:\WINDOWS\system32\ADVAPI32.dll
                      (0000000077e70000 - 0000000077f03000: C:\WINDOWS\system32\RPCRT4.dll
                      (0000000077f10000 - 0000000077f59000: C:\WINDOWS\system32\GDI32.dll
                      (0000000077f60000 - 0000000077fd6000: C:\WINDOWS\system32\SHLWAPI.dll
                      (0000000077fe0000 - 0000000077ff1000: C:\WINDOWS\system32\Secur32.dll
                      (0000000078130000 - 0000000078263000: C:\WINDOWS\system32\urlmon.dll
                      (0000000078480000 - 000000007850e000: C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.6161_x-ww_31a54e43\MS VCP90.dll
                      (0000000078520000 - 00000000785c3000: C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.6161_x-ww_31a54e43\MS VCR90.dll
                      (000000007c800000 - 000000007c8f6000: C:\WINDOWS\system32\kernel32.dll
                      (000000007c900000 - 000000007c9b2000: C:\WINDOWS\system32\ntdll.dll
                      (000000007c9c0000 - 000000007d1d7000: C:\WINDOWS\system32\SHELL32.dll
                      (000000007e410000 - 000000007e4a1000: C:\WINDOWS\system32\USER32.dll
                      *----> State Dump for Thread Id 0x948 <----*
                      eax=00000000 ebx=00000001 ecx=000005be edx=00000000 esi=0224153c edi=0224153c
                      eip=7c90e514 esp=0012fd88 ebp=0012fda4 iopl=0         nv up ei pl zr na po nc
                      cs=001b  ss=0023  ds=0023  es=0023  fs=003b  gs=0000             efl=00000246
                      *** ERROR: Symbol file could not be found.  Defaulted to export symbols for C:\WINDOWS\system32\ntdll.dll -
                      function: ntdll!KiFastSystemCallRet
                              7c90e4fa e829000000       call    ntdll!RtlRaiseException (7c90e528)
                              7c90e4ff 8b0424           mov     eax,[esp]
                              7c90e502 8be5             mov     esp,ebp
                              7c90e504 5d               pop     ebp
                              7c90e505 c3               ret
                              7c90e506 8da42400000000   lea     esp,[esp]
                              7c90e50d 8d4900           lea     ecx,[ecx]
                              ntdll!KiFastSystemCall:
                              7c90e510 8bd4             mov     edx,esp
                              7c90e512 0f34             sysenter
                              ntdll!KiFastSystemCallRet:
                              7c90e514 c3               ret
                              7c90e515 8da42400000000   lea     esp,[esp]
                              7c90e51c 8d642400         lea     esp,[esp]
                              ntdll!KiIntSystemCall:
                              7c90e520 8d542408         lea     edx,[esp+0x8]
                              7c90e524 cd2e             int     2e
                              7c90e526 c3               ret
                              7c90e527 90               nop
                              ntdll!RtlRaiseException:
                              7c90e528 55               push    ebp
                              7c90e529 8bec             mov     ebp,esp
                      *----> Stack Back Trace <----*
                      *** ERROR: Symbol file could not be found.  Defaulted to export symbols for C:\Program Files\Adobe\Adobe Bridge CS5\Bridge.exe -
                      WARNING: Stack unwind information not available. Following frames may be wrong.
                      *** ERROR: Symbol file could not be found.  Defaulted to export symbols for C:\WINDOWS\system32\kernel32.dll -
                      ChildEBP RetAddr  Args to Child
                      0012fda4 00715805 0224153c 00000000 00000000 ntdll!KiFastSystemCallRet
                      0012fe48 0070f362 00000000 c5048224 00000000 Bridge!CTJPEGRotateOptions__operator=+0xc9765
                      0012fe80 0070f254 c5048208 00000000 022414e0 Bridge!CTJPEGRotateOptions__operator=+0xc32c2
                      0012feac 00743bee c50483a0 00000000 022414e0 Bridge!CTJPEGRotateOptions__operator=+0xc31b4
                      0012ff04 00743d19 c5048394 fffffffe 00000000 Bridge!CTJPEGRotateOptions__operator=+0xf7b4e
                      0012ff30 006f7c8b 00400000 00000000 00152345 Bridge!CTJPEGRotateOptions__operator=+0xf7c79
                      0012ffc0 7c817077 00350034 00310038 7ffdc000 Bridge!CTJPEGRotateOptions__operator=+0xabbeb
                      0012fff0 00000000 006f7cf6 00000000 78746341 kernel32!RegisterWaitForInputIdle+0x49
                      *----> Raw Stack Dump <----*
                      000000000012fd88  be 91 41 7e f1 91 41 7e - 3c 15 24 02 00 00 00 00  ..A~..A~<.$.....
                      000000000012fd98  00 00 00 00 00 00 00 00 - e0 14 24 02 48 fe 12 00  ..........$.H...
                      000000000012fda8  05 58 71 00 3c 15 24 02 - 00 00 00 00 00 00 00 00  .Xq.<.$.........
                      000000000012fdb8  00 00 00 00 ec 82 04 c5 - e0 14 24 02 e0 14 24 02  ..........$...$.
                      000000000012fdc8  00 00 00 00 47 00 00 00 - 77 00 00 00 00 00 00 00  ....G...w.......
                      000000000012fdd8  e9 f1 70 00 cf f7 53 e3 - 45 5b c2 40 e4 09 2a 02  ..p...S.E[.@..*.
                      000000000012fde8  10 f1 70 00 00 00 00 00 - 00 00 00 00 00 27 2f 02  ..p..........'/.
                      000000000012fdf8  21 f1 70 00 00 00 00 00 - 50 fe 12 00 47 00 00 00  !.p.....P...G...
                      000000000012fe08  77 00 00 00 cf f7 53 e3 - 45 5b c2 40 00 27 2f 02  w.....S.E[.@.'/.
                      000000000012fe18  00 00 00 00 bf f5 70 00 - 00 00 00 00 e0 14 24 02  ......p.......$.
                      000000000012fe28  20 fe 12 00 0c fe 12 00 - 00 00 00 00 01 01 01 00   ...............
                      000000000012fe38  bc fd 12 00 74 fe 12 00 - 28 b4 a5 00 01 00 00 00  ....t...(.......
                      000000000012fe48  80 fe 12 00 62 f3 70 00 - 00 00 00 00 24 82 04 c5  ....b.p.....$...
                      000000000012fe58  00 00 00 00 e0 14 24 02 - 01 00 00 00 50 fe 12 00  ......$.....P...
                      000000000012fe68  00 00 00 00 a0 fe 12 00 - 54 fe 12 00 a0 fe 12 00  ........T.......
                      000000000012fe78  00 b1 a5 00 00 00 00 00 - ac fe 12 00 54 f2 70 00  ............T.p.
                      000000000012fe88  08 82 04 c5 00 00 00 00 - e0 14 24 02 01 00 00 00  ..........$.....
                      000000000012fe98  e0 14 24 02 88 fe 12 00 - f8 fe 12 00 e0 b0 a5 00  ..$.............
                      000000000012fea8  00 00 00 00 04 ff 12 00 - ee 3b 74 00 a0 83 04 c5  .........;t.....
                      000000000012feb8  00 00 00 00 e0 14 24 02 - 01 00 00 00 db 65 40 00  ......$......e@.
                      *----> State Dump for Thread Id 0x59c <----*
                      eax=0222fec8 ebx=00000000 ecx=0222fec8 edx=ffffffff esi=00000088 edi=00000000
                      eip=7c90e514 esp=0222fe94 ebp=0222fef8 iopl=0         nv up ei ng nz ac po cy
                      cs=001b  ss=0023  ds=0023  es=0023  fs=003b  gs=0000             efl=00000297
                              7c90e504 5d               pop     ebp
                              7c90e505 c3               ret
                              7c90e514 c3               ret
                              7c90e526 c3               ret
                              7c90e527 90               nop
                      *** ERROR: Symbol file could not be found.  Defaulted to export symbols for C:\WINDOWS\system32\DrvTrNTm.dll -
                      0222fef8 7c802542 00000088 0000012c 00000000 ntdll!KiFastSystemCallRet
                      0222ff0c 6bc04eb2 00000088 0000012c 87f2da28 kernel32!WaitForSingleObject+0x12
                      0222ffb4 7c80b729 00000000 7c912228 00000000 DrvTrNTm+0x4eb2
                      0222ffec 00000000 6bc04e5c 00000000 00000000 kernel32!GetModuleFileNameA+0x1ba
                      000000000222fe94  5a df 90 7c db 25 80 7c - 88 00 00 00 00 00 00 00  Z..|.%.|........
                      000000000222fea4  c8 fe 22 02 28 22 91 7c - 00 00 00 00 00 00 00 00  ..".(".|........
                      000000000222feb4  14 00 00 00 01 00 00 00 - 00 00 00 00 00 00 00 00  ................
                      000000000222fec4  10 00 00 00 40 39 d2 ff - ff ff ff ff 00 c0 fd 7f  ....@9..........
                      000000000222fed4  00 e0 fd 7f c8 fe 22 02 - 02 01 00 00 a8 fe 22 02  ......".......".
                      000000000222fee4  00 00 00 00 dc ff 22 02 - d8 9a 83 7c 08 26 80 7c  ......"....|.&.|
                      000000000222fef4  00 00 00 00 0c ff 22 02 - 42 25 80 7c 88 00 00 00  ......".B%.|....
                      000000000222ff04  2c 01 00 00 00 00 00 00 - b4 ff 22 02 b2 4e c0 6b  ,........."..N.k
                      000000000222ff14  88 00 00 00 2c 01 00 00 - 28 da f2 87 b8 d9 f2 87  ....,...(.......
                      000000000222ff24  78 b0 4f 80 24 db f2 87 - b8 d9 f2 87 ec d9 f2 87  x.O.$...........
                      000000000222ff34  01 00 00 00 f2 43 64 80 - a8 76 c4 87 b8 d9 f2 87  .....Cd..v......
                      000000000222ff44  00 00 00 00 88 5c 70 a8 - 8c 2f 50 80 00 00 00 00  .....\p../P.....
                      000000000222ff54  03 00 00 00 9a 27 00 00 - 00 00 00 00 00 00 00 00  .....'..........
                      000000000222ff64  c4 f8 4f 80 60 5c 70 a8 - ec d9 f2 87 80 f9 4f 80  ..O.`\p.......O.
                      000000000222ff74  27 74 6e 80 b8 d9 f2 87 - 50 5d 70 a8 00 00 00 00  'tn.....P]p.....
                      000000000222ff84  a0 da f2 87 01 5c 70 a8 - 00 00 00 00 a8 76 c4 87  .....\p......v..
                      000000000222ff94  64 2f 50 80 00 00 00 00 - 00 00 00 00 00 00 00 00  d/P.............
                      000000000222ffa4  74 2f 50 80 a0 5c 70 a8 - 00 00 00 00 74 08 00 00  t/P..\p.....t...
                      000000000222ffb4  ec ff 22 02 29 b7 80 7c - 00 00 00 00 28 22 91 7c  ..".)..|....(".|
                      000000000222ffc4  00 00 00 00 00 00 00 00 - 00 e0 fd 7f 00 76 83 8a  .............v..
                      *----> State Dump for Thread Id 0x234 <----*
                      eax=00000000 ebx=00000000 ecx=02247948 edx=02247ae4 esi=000001b8 edi=00000000
                      eip=7c90e514 esp=029efe8c ebp=029efef0 iopl=0         nv up ei ng nz ac po cy
                              7c90e504 5d               pop     ebp
                              7c90e505 c3               ret
                              7c90e514 c3               ret
                              7c90e526 c3               ret
                              7c90e527 90               nop
                      029efef0 7c802542 000001b8 00000064 00000000 ntdll!KiFastSystemCallRet
                      029eff04 009b509a 000001b8 00000064 009b2337 kernel32!WaitForSingleObject+0x12
                      029eff48 009b4ff7 c78883d4 02230000 0224eeb8 Bridge!CTJPEGRotateOptions__operator=+0x368ffa
                      029eff70 00a1e844 0224ee20 c788830c 02230000 Bridge!CTJPEGRotateOptions__operator=+0x368f57
                      029effa8 00a1e8ec 02247b68 029effec 7c80b729 Bridge!CTJPEGRotateOptions__operator=+0x3d27a4
                      029effb4 7c80b729 0224eeb8 02230000 02247b68 Bridge!CTJPEGRotateOptions__operator=+0x3d284c
                      029effec 00000000 00a1e86a 0224eeb8 00000000 kernel32!GetModuleFileNameA+0x1ba
                      00000000029efe8c  5a df 90 7c db 25 80 7c - b8 01 00 00 00 00 00 00  Z..|.%.|........
                      00000000029efe9c  c0 fe 9e 02 38 ee 24 02 - 20 ee 24 02 00 00 00 00  ....8.$. .$.....
                      00000000029efeac  14 00 00 00 01 00 00 00 - 00 00 00 00 00 00 00 00  ................
                      00000000029efebc  10 00 00 00 c0 bd f0 ff - ff ff ff ff 00 c0 fd 7f  ................
                      00000000029efecc  00 b0 fd 7f c0 fe 9e 02 - ff ff ff ff a0 fe 9e 02  ................
                      00000000029efedc  d0 fe 9e 02 3c ff 9e 02 - d8 9a 83 7c 08 26 80 7c  ....<......|.&.|
                      00000000029efeec  00 00 00 00 04 ff 9e 02 - 42 25 80 7c b8 01 00 00  ........B%.|....
                      00000000029efefc  64 00 00 00 00 00 00 00 - 48 ff 9e 02 9a 50 9b 00  d.......H....P..
                      00000000029eff0c  b8 01 00 00 64 00 00 00 - 37 23 9b 00 64 00 00 00  ....d...7#..d...
                      00000000029eff1c  ec 83 88 c7 b5 08 83 7c - 20 ee 24 02 00 00 00 00  .......| .$.....
                      00000000029eff2c  c0 8f b2 00 20 ee 24 02 - c0 8f b2 00 20 ee 24 02  .... .$..... .$.
                      00000000029eff3c  64 ff 9e 02 ea 12 a8 00 - ff ff ff ff 70 ff 9e 02  d...........p...
                      00000000029eff4c  f7 4f 9b 00 d4 83 88 c7 - 00 00 23 02 b8 ee 24 02  .O........#...$.
                      00000000029eff5c  b8 ee 24 02 50 ff 9e 02 - 98 ff 9e 02 ef 1a a8 00  ..$.P...........
                      00000000029eff6c  00 00 00 00 a8 ff 9e 02 - 44 e8 a1 00 20 ee 24 02  ........D... .$.
                      00000000029eff7c  0c 83 88 c7 00 00 23 02 - b8 ee 24 02 b8 ee 24 02  ......#...$...$.
                      00000000029eff8c  7c ff 9e 02 7c ff 9e 02 - dc ff 9e 02 dc ff 9e 02  |...|...........
                      00000000029eff9c  00 8d 6f 00 7c b0 d4 c5 - 00 00 00 00 b4 ff 9e 02  ..o.|...........
                      00000000029effac  ec e8 a1 00 68 7b 24 02 - ec ff 9e 02 29 b7 80 7c  ....h{$.....)..|
                      00000000029effbc  b8 ee 24 02 00 00 23 02 - 68 7b 24 02 b8 ee 24 02  ..$...#.h{$...$.
                      *----> State Dump for Thread Id 0x5ec <----*
                      eax=02aeb200 ebx=022694b4 ecx=0000003c edx=00000000 esi=000001c8 edi=00000000
                      eip=7c90e514 esp=02aeff08 ebp=02aeff6c iopl=0         nv up ei pl zr na po nc
                              7c90e504 5d               pop     ebp
                              7c90e505 c3               ret
                              7c90e514 c3               ret
                              7c90e526 c3               ret
                              7c90e527 90               nop
                      *** ERROR: Symbol file could not be found.  Defaulted to export symbols for C:\Program Files\Adobe\Adobe Bridge CS5\ACE.dll -
                      02aeff6c 7c802542 000001c8 ffffffff 00000000 ntdll!KiFastSystemCallRet
                      02aeff80 014816ca 000001c8 ffffffff 014ab2a8 kernel32!WaitForSingleObject+0x12
                      02aeffb0 0148160c 7c80b729 022694b4 014ab2a8 ACE+0x816ca
                      02aeffec 00000000 01481603 022694b4 00000000 ACE+0x8160c
                      0000000002aeff08  5a df 90 7c db 25 80 7c - c8 01 00 00 00 00 00 00  Z..|.%.|........
                      0000000002aeff18  00 00 00 00 30 25 80 7c - b4 94 26 02 b4 94 26 02  ....0%.|..&...&.
                      0000000002aeff28  14 00 00 00 01 00 00 00 - 00 00 00 00 00 00 00 00  ................
                      0000000002aeff38  10 00 00 00 f4 b3 4b 01 - 00 00 00 00 00 c0 fd 7f  ......K.........
                      0000000002aeff48  00 a0 fd 7f 00 00 00 00 - fc 51 26 02 1c ff ae 02  .........Q&.....
                      0000000002aeff58  8a 00 00 00 dc ff ae 02 - d8 9a 83 7c 08 26 80 7c  ...........|.&.|
                      0000000002aeff68  00 00 00 00 80 ff ae 02 - 42 25 80 7c c8 01 00 00  ........B%.|....
                      0000000002aeff78  ff ff ff ff 00 00 00 00 - b0 ff ae 02 ca 16 48 01  ..............H.
                      0000000002aeff88  c8 01 00 00 ff ff ff ff - a8 b2 4a 01 b4 94 26 02  ..........J...&.
                      0000000002aeff98  db 1b 48 01 88 b2 4a 01 - 02 00 00 00 01 2f 50 80  ..H...J....../P.
                      0000000002aeffa8  a0 ff ae 02 00 fc 01 00 - ec ff ae 02 0c 16 48 01  ..............H.
                      0000000002aeffb8  29 b7 80 7c b4 94 26 02 - a8 b2 4a 01 88 b2 4a 01  )..|..&...J...J.
                      0000000002aeffc8  b4 94 26 02 00 a0 fd 7f - 00 96 83 8a c0 ff ae 02  ..&.............
                      0000000002aeffd8  80 67 19 88 ff ff ff ff - d8 9a 83 7c 30 b7 80 7c  .g.........|0..|
                      0000000002aeffe8  00 00 00 00 00 00 00 00 - 00 00 00 00 03 16 48 01  ..............H.
                      0000000002aefff8  b4 94 26 02 00 00 00 00 - 4d 5a 90 00 03 00 00 00  ..&.....MZ......
                      0000000002af0008  04 00 00 00 ff ff 00 00 - b8 00 00 00 00 00 00 00  ................
                      0000000002af0018  40 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  @...............
                      0000000002af0028  00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                      0000000002af0038  00 00 00 00 f0 00 00 00 - 0e 1f ba 0e 00 b4 09 cd  ................
                      *----> State Dump for Thread Id 0xfb4 <----*
                      eax=0000008a ebx=7c80a0db ecx=13914b52 edx=13914b52 esi=000001f0 edi=00000000
                      eip=7c90e514 esp=033fff18 ebp=033fff7c iopl=0         nv up ei pl zr na po nc
                              7c90e504 5d               pop     ebp
                              7c90e505 c3               ret
                              7c90e514 c3               ret
                              7c90e526 c3               ret
                              7c90e527 90               nop
                      *** ERROR: Symbol file could not be found.  Defaulted to export symbols for C:\Program Files\Adobe\Adobe Bridge CS5\Plug-Ins\MultiProcessor Support.8BX -
                      033fff7c 7c802542 000001f0 ffffffff 00000000 ntdll!KiFastSystemCallRet
                      033fff90 032b6afc 000001f0 ffffffff 032b6a9e kernel32!WaitForSingleObject+0x12
                      033fffb4 7c80b729 00000000 001ad090 001ad8d0 MultiProcessor Support+0x46afc
                      033fffec 00000000 032b6a80 00000000 00000000 kernel32!GetModuleFileNameA+0x1ba
                      00000000033fff18  5a df 90 7c db 25 80 7c - f0 01 00 00 00 00 00 00  Z..|.%.|........
                      00000000033fff28  00 00 00 00 30 25 80 7c - 00 00 00 00 db a0 80 7c  ....0%.|.......|
                      00000000033fff38  14 00 00 00 01 00 00 00 - 00 00 00 00 00 00 00 00  ................
                      00000000033fff48  10 00 00 00 8a 00 00 00 - 88 00 00 00 00 c0 fd 7f  ................
                      00000000033fff58  00 90 fd 7f 00 00 00 00 - db a0 80 7c 2c ff 3f 03  ...........|,.?.
                      00000000033fff68  30 25 80 7c dc ff 3f 03 - d8 9a 83 7c 08 26 80 7c  0%.|..?....|.&.|
                      00000000033fff78  00 00 00 00 90 ff 3f 03 - 42 25 80 7c f0 01 00 00  ......?.B%.|....
                      00000000033fff88  ff ff ff ff 00 00 00 00 - b4 ff 3f 03 fc 6a 2b 03  ..........?..j+.
                      00000000033fff98  f0 01 00 00 ff ff ff ff - 9e 6a 2b 03 90 d0 1a 00  .........j+.....
                      00000000033fffa8  d0 d8 1a 00 00 00 00 00 - 37 c5 3f 03 ec ff 3f 03  ........7.?...?.
                      00000000033fffb8  29 b7 80 7c 00 00 00 00 - 90 d0 1a 00 d0 d8 1a 00  )..|............
                      00000000033fffc8  00 00 00 00 00 90 fd 7f - 00 00 00 00 c0 ff 3f 03  ..............?.
                      00000000033fffd8  d0 8b f5 87 ff ff ff ff - d8 9a 83 7c 30 b7 80 7c  ...........|0..|
                      00000000033fffe8  00 00 00 00 00 00 00 00 - 00 00 00 00 80 6a 2b 03  .............j+.
                      00000000033ffff8  00 00 00 00 00 00 00 00 - 4d 5a 90 00 03 00 00 00  ........MZ......
                      0000000003400008  04 00 00 00 ff ff 00 00 - b8 00 00 00 00 00 00 00  ................
                      0000000003400018  40 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  @...............
                      0000000003400028  00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                      0000000003400038  00 00 00 00 10 01 00 00 - 0e 1f ba 0e 00 b4 09 cd  ................
                      0000000003400048  21 b8 01 4c cd 21 54 68 - 69 73 20 70 72 6f 67 72  !..L.!This progr
                      *----> State Dump for Thread Id 0x278 <----*
                      eax=037860b4 ebx=0477ee18 ecx=00000007 edx=7c910222 esi=00000210 edi=00000000
                      eip=7c90e514 esp=0497ff08 ebp=0497ff6c iopl=0         nv up ei pl zr na po nc
                              7c90e504 5d               pop     ebp
                              7c90e505 c3               ret
                              7c90e514 c3               ret
                              7c90e526 c3               ret
                              7c90e527 90               nop
                      *** ERROR: Symbol file could not be found.  Defaulted to export symbols for C:\Program Files\Common Files\Adobe\Plug-Ins\CS5\File Formats\Camera Raw.8bi -
                      0497ff6c 7c802542 00000210 ffffffff 00000000 ntdll!KiFastSystemCallRet
                      0497ff80 0378617d 00000210 ffffffff 00000000 kernel32!WaitForSingleObject+0x12
                      0497ffb0 037860bd 7c80b729 0477ee18 00000000 Camera Raw!CTJPEGDecoderCreateUsingData+0x9295d
                      0497ffec 00000000 037860b4 0477ee18 00000000 Camera Raw!CTJPEGDecoderCreateUsingData+0x9289d
                      000000000497ff08  5a df 90 7c db 25 80 7c - 10 02 00 00 00 00 00 00  Z..|.%.|........
                      000000000497ff18  00 00 00 00 30 25 80 7c - 18 ee 77 04 18 ee 77 04  ....0%.|..w...w.
                      000000000497ff28  14 00 00 00 01 00 00 00 - 00 00 00 00 00 00 00 00  ................
                      000000000497ff38  10 00 00 00 a8 76 c4 87 - 20 e0 b5 87 00 c0 fd 7f  .....v.. .......
                      000000000497ff48  00 80 fd 7f 00 00 00 00 - 8c e1 b5 87 1c ff 97 04  ................
                      000000000497ff58  54 e0 b5 87 dc ff 97 04 - d8 9a 83 7c 08 26 80 7c  T..........|.&.|
                      000000000497ff68  00 00 00 00 80 ff 97 04 - 42 25 80 7c 10 02 00 00  ........B%.|....
                      000000000497ff78  ff ff ff ff 00 00 00 00 - b0 ff 97 04 7d 61 78 03  ............}ax.
                      000000000497ff88  10 02 00 00 ff ff ff ff - 00 00 00 00 18 ee 77 04  ..............w.
                      000000000497ff98  a1 66 78 03 50 f0 12 00 - 02 00 00 00 01 2f 50 80  .fx.P......../P.
                      000000000497ffa8  a0 ff 97 04 00 fc 01 00 - ec ff 97 04 bd 60 78 03  .............`x.
                      000000000497ffb8  29 b7 80 7c 18 ee 77 04 - 00 00 00 00 50 f0 12 00  )..|..w.....P...
                      000000000497ffc8  18 ee 77 04 00 80 fd 7f - 00 96 83 8a c0 ff 97 04  ..w.............
                      000000000497ffd8  80 67 19 88 ff ff ff ff - d8 9a 83 7c 30 b7 80 7c  .g.........|0..|
                      000000000497ffe8  00 00 00 00 00 00 00 00 - 00 00 00 00 b4 60 78 03  .............`x.
                      000000000497fff8  18 ee 77 04 00 00 00 00 - 00 00 00 00 00 00 00 00  ..w.............
                      0000000004980008  00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                      0000000004980018  00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                      0000000004980028  00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                      0000000004980038  00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                      *----> State Dump for Thread Id 0x4c4 <----*
                      eax=04a7ff00 ebx=7c901000 ecx=04a7ff43 edx=001b36f0 esi=00000220 edi=00000000
                      eip=7c90e514 esp=04a7fe2c ebp=04a7fe90 iopl=0         nv up ei pl zr na po nc
                              7c90e504 5d               pop     ebp
                              7c90e505 c3               ret
                              7c90e514 c3               ret
                              7c90e526 c3               ret
                              7c90e527 90               nop
                      04a7fe90 7c802542 00000220 ffffffff 00000000 ntdll!KiFastSystemCallRet
                      04a7fea4 037ee872 00000220 ffffffff 042d55d4 kernel32!WaitForSingleObject+0x12
                      04a7fee0 037ee90a 042c76e0 ffffffff 00201344 Camera Raw!CTJPEGDecoderCreateUsingData+0xfb052
                      04a7ff1c 036c03d7 042c76dc 00000000 bff00000 Camera Raw!CTJPEGDecoderCreateUsingData+0xfb0ea
                      04a7ff50 035bdfaa 037eebaa 00201330 0018f7d8 Camera Raw!CTJPEGRotateOptions__operator=+0xfb225
                      04a7ff70 03820017 0018f7d8 8159f852 0000021a Camera Raw!EntryFM+0x15dadf
                      04a7ffa8 038200bf 00000000 04a7ffec 7c80b729 Camera Raw!CTJPEGDecoderCreateUsingData+0x12c7f7
                      04a7ffb4 7c80b729 047f0e80 0000021a 00000000 Camera Raw!CTJPEGDecoderCreateUsingData+0x12c89f
                      04a7ffec 00000000 0382003d 047f0e80 00000000 kernel32!GetModuleFileNameA+0x1ba
                      0000000004a7fe2c  5a df 90 7c db 25 80 7c - 20 02 00 00 00 00 00 00  Z..|.%.| .......
                      0000000004a7fe3c  00 00 00 00 e0 10 90 7c - 50 13 20 00 00 10 90 7c  .......|P. ....|
                      0000000004a7fe4c  14 00 00 00 01 00 00 00 - 00 00 00 00 00 00 00 00  ................
                      0000000004a7fe5c  10 00 00 00 78 0e 7f 04 - 30 ff a7 04 00 c0 fd 7f  ....x...0.......
                      0000000004a7fe6c  00 70 fd 7f 00 00 00 00 - b8 00 91 7c 40 fe a7 04  .p.........|@...
                      0000000004a7fe7c  48 ff a7 04 44 ff a7 04 - d8 9a 83 7c 08 26 80 7c  H...D......|.&.|
                      0000000004a7fe8c  00 00 00 00 a4 fe a7 04 - 42 25 80 7c 20 02 00 00  ........B%.| ...
                      0000000004a7fe9c  ff ff ff ff 00 00 00 00 - e0 fe a7 04 72 e8 7e 03  ............r.~.
                      0000000004a7feac  20 02 00 00 ff ff ff ff - d4 55 2d 04 dc 76 2c 04   ........U-..v,.
                      0000000004a7febc  00 00 00 00 00 00 00 00 - 00 00 00 00 20 02 00 00  ............ ...
                      0000000004a7fecc  00 00 00 00 00 00 00 00 - d4 55 2d 04 f0 36 1b 00  .........U-..6..
                      0000000004a7fedc  20 02 00 00 1c ff a7 04 - 0a e9 7e 03 e0 76 2c 04   .........~..v,.
                      0000000004a7feec  ff ff ff ff 44 13 20 00 - b8 be 7d 03 44 13 20 00  ....D. ...}.D. .
                      0000000004a7fefc  e0 76 2c 04 30 13 20 00 - 30 13 20 00 80 0e 7f 04  .v,.0. .0. .....
                      0000000004a7ff0c  f4 fe a7 04 44 ff a7 04 - 44 13 20 00 ff ff ff 00  ....D...D. .....
                      0000000004a7ff1c  50 ff a7 04 d7 03 6c 03 - dc 76 2c 04 00 00 00 00  P.....l..v,.....
                      0000000004a7ff2c  00 00 f0 bf aa f8 59 81 - 30 13 20 00 a1 df 5b 03  ......Y.0. ...[.
                      0000000004a7ff3c  80 0e 7f 04 30 13 20 01 - 98 ff a7 04 75 49 88 03  ....0. .....uI..
                      0000000004a7ff4c  00 00 00 00 70 ff a7 04 - aa df 5b 03 aa eb 7e 03  ....p.....[...~.
                      0000000004a7ff5c  30 13 20 00 d8 f7 18 00 - 1a 02 00 00 00 00 00 00  0. .............
                      *----> State Dump for Thread Id 0x19c <----*
                      eax=0e2ebd80 ebx=04e2fdfc ecx=00000002 edx=00000000 esi=00000000 edi=7ffdc000
                      eip=7c90e514 esp=04e2fdd4 ebp=04e2fe70 iopl=0         nv up ei pl zr na po nc
                              7c90e504 5d               pop     ebp
                              7c90e505 c3               ret
                              7c90e514 c3               ret
                              7c90e526 c3               ret
                              7c90e527 90               nop
                      *** ERROR: Symbol file could not be found.  Defaulted to export symbols for C:\WINDOWS\system32\USER32.dll -
                      04e2fe70 7e4195f9 00000002 04e2fe98 00000000 ntdll!KiFastSystemCallRet
                      04e2fecc 7e4196a8 00000001 04e2ff30 ffffffff USER32!GetLastInputInfo+0x105
                      04e2fee8 00855cde 00000001 04e2ff30 00000000 USER32!MsgWaitForMultipleObjects+0x1f
                      04e2ff80 0074f58e c1f48314 3ffffffd 0012faf0 Bridge!CTJPEGRotateOptions__operator=+0x209c3e
                      04e2ffb0 0074f67f 7c80b729 022586a8 3ffffffd Bridge!CTJPEGRotateOptions__operator=+0x1034ee
                      04e2ffec 00000000 0074f670 022586a8 00000000 Bridge!CTJPEGRotateOptions__operator=+0x1035df
                      0000000004e2fdd4  4a df 90 7c 90 95 80 7c - 02 00 00 00 fc fd e2 04  J..|...|........
                      0000000004e2fde4  01 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                      0000000004e2fdf4  02 00 00 00 00 00 00 00 - bc 01 00 00 2c 02 00 00  ............,...
                      0000000004e2fe04  38 84 b9 04 18 fc a8 0f - 00 00 00 00 d0 56 42 00  8............VB.
                      0000000004e2fe14  78 fe e2 04 04 fe e2 04 - 14 00 00 00 01 00 00 00  x...............
                      0000000004e2fe24  00 00 00 00 00 00 00 00 - 10 00 00 00 a8 86 25 02  ..............%.
                      0000000004e2fe34  00 00 00 00 4c a5 bc 00 - 00 c0 fd 7f 00 60 fd 7f  ....L........`..
                      0000000004e2fe44  00 01 e2 04 00 00 00 00 - fc fd e2 04 00 00 00 00  ................
                      0000000004e2fe54  02 00 00 00 f0 fd e2 04 - 02 00 00 00 48 ff e2 04  ............H...
                      0000000004e2fe64  d8 9a 83 7c 80 96 80 7c - 00 00 00 00 cc fe e2 04  ...|...|........
                      0000000004e2fe74  f9 95 41 7e 02 00 00 00 - 98 fe e2 04 00 00 00 00  ..A~............
                      0000000004e2fe84  ff ff ff ff 00 00 00 00 - 89 96 41 7e ff ff ff ff  ..........A~....
                      0000000004e2fe94  00 00 00 00 bc 01 00 00 - 2c 02 00 00 00 00 00 00  ........,.......
                      0000000004e2fea4  2a dc 90 00 00 00 00 00 - 00 00 00 00 00 00 00 00  *...............
                      0000000004e2feb4  00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                      0000000004e2fec4  00 60 fd 7f 2c 02 00 00 - e8 fe e2 04 a8 96 41 7e  .`..,.........A~
                      0000000004e2fed4  01 00 00 00 30 ff e2 04 - ff ff ff ff bf 04 00 00  ....0...........
                      0000000004e2fee4  98 fe e2 04 80 ff e2 04 - de 5c 85 00 01 00 00 00  .........\......
                      0000000004e2fef4  30 ff e2 04 00 00 00 00 - ff ff ff ff bf 04 00 00  0...............
                      0000000004e2ff04  6c ff e2 04 a8 86 25 02 - 00 00 00 00 18 fc a8 0f  l.....%.........
                      *----> State Dump for Thread Id 0xee4 <----*
                      eax=11610480 ebx=04f2fdfc ecx=04f2f880 edx=0000feba esi=00000000 edi=7ffdc000
                      eip=7c90e514 esp=04f2fdd4 ebp=04f2fe70 iopl=0         nv up ei pl zr na po nc
                              7c90e504 5d               pop     ebp
                              7c90e505 c3               ret
                              7c90e514 c3               ret
                              7c90e526 c3               ret
                              7c90e527 90               nop
                      04f2fe70 7e4195f9 00000002 04f2fe98 00000000 ntdll!KiFastSystemCallRet
                      04f2fecc 7e4196a8 00000001 04f2ff30 ffffffff USER32!GetLastInputInfo+0x105
                      04f2fee8 00855cde 00000001 04f2ff30 00000000 USER32!MsgWaitForMultipleObjects+0x1f
                      04f2ff80 0074f58e c1e48314 3ffffffd 0012faf0 Bridge!CTJPEGRotateOptions__operator=+0x209c3e
                      04f2ffb0 0074f67f 7c80b729 02258890 3ffffffd Bridge!CTJPEGRotateOptions__operator=+0x1034ee
                      04f2ffec 00000000 0074f670 02258890 00000000 Bridge!CTJPEGRotateOptions__operator=+0x1035df
                      0000000004f2fdd4  4a df 90 7c 90 95 80 7c - 02 00 00 00 fc fd f2 04  J..|...|........
                      0000000004f2fde4  01 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                      0000000004f2fdf4  02 00 00 00 00 00 00 00 - c0 01 00 00 34 02 00 00  ............4...
                      0000000004f2fe04  00 00 23 02 00 00 00 00 - 01 00 00 00 60 fa be 04  ..#.........`...
                      0000000004f2fe14  f8 fd f2 04 00 00 23 02 - 14 00 00 00 01 00 00 00  ......#.........
                      0000000004f2fe24  00 00 00 00 00 00 00 00 - 10 00 00 00 fc fe f2 04  ................
                      0000000004f2fe34  41 00 91 7c 38 08 23 02 - 00 c0 fd 7f 00 50 fd 7f  A..|8.#......P..
                      0000000004f2fe44  18 21 a2 0f 00 00 00 00 - fc fd f2 04 5d 00 91 7c  .!..........]..|
                      0000000004f2fe54  02 00 00 00 f0 fd f2 04 - 00 00 00 00 48 ff f2 04  ............H...
                      0000000004f2fe64  d8 9a 83 7c 80 96 80 7c - 00 00 00 00 cc fe f2 04  ...|...|........
                      0000000004f2fe74  f9 95 41 7e 02 00 00 00 - 98 fe f2 04 00 00 00 00  ..A~............
                      0000000004f2fe84  ff ff ff ff 00 00 00 00 - 89 96 41 7e ff ff ff ff  ..........A~....
                      0000000004f2fe94  00 00 00 00 c0 01 00 00 - 34 02 00 00 01 00 00 00  ........4.......
                      0000000004f2fea4  04 ea 30 02 d4 fe f2 04 - 49 9e a7 00 9d ef 74 00  ..0.....I.....t.
                      0000000004f2feb4  34 ea 30 02 a1 15 88 00 - 00 00 00 00 00 00 00 00  4.0.............
                      0000000004f2fec4  00 50 fd 7f 34 02 00 00 - e8 fe f2 04 a8 96 41 7e  .P..4.........A~
                      0000000004f2fed4  01 00 00 00 30 ff f2 04 - ff ff ff ff bf 04 00 00  ....0...........
                      0000000004f2fee4  98 fe f2 04 80 ff f2 04 - de 5c 85 00 01 00 00 00  .........\......
                      0000000004f2fef4  30 ff f2 04 00 00 00 00 - ff ff ff ff bf 04 00 00  0...............
                      0000000004f2ff04  6c ff f2 04 90 88 25 02 - 00 00 00 00 98 83 e4 c1  l.....%.........
                      *----> State Dump for Thread Id 0xcfc <----*
                      eax=0519ff90 ebx=0519fe7c ecx=0519ff00 edx=7c90e514 esi=00000000 edi=7ffdc000
                      eip=7c90e514 esp=0519fe54 ebp=0519fef0 iopl=0         nv up ei pl zr na po nc
                              7c90e504 5d               pop     ebp
                              7c90e505 c3               ret
                              7c90e514 c3               ret
                              7c90e526 c3               ret
                              7c90e527 90               nop
                      *** ERROR: Symbol file could not be found.  Defaulted to export symbols for C:\WINDOWS\WinSxS\x86_Microsoft.Windows.GdiPlus_6595b64144ccf1df_1.0.6002.22509_x-ww_c7da d023\gdiplus.dll -
                      0519fef0 7e4195f9 00000002 0519ff18 00000000 ntdll!KiFastSystemCallRet
                      0519ff4c 7e4196a8 00000001 0519ffac ffffffff USER32!GetLastInputInfo+0x105
                      0519ff68 4ec674b2 00000001 0519ffac 00000000 USER32!MsgWaitForMultipleObjects+0x1f
                      0519ffb4 7c80b729 00000000 beef0010 00000011 gdiplus!GdipGetVisibleClipBoundsI+0xad4
                      0519ffec 00000000 4ec67456 00000000 00000000 kernel32!GetModuleFileNameA+0x1ba
                      000000000519fe54  4a df 90 7c 90 95 80 7c - 02 00 00 00 7c fe 19 05  J..|...|....|...
                      000000000519fe64  01 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                      000000000519fe74  02 00 00 00 00 00 00 00 - 3c 02 00 00 44 02 00 00  ........<...D...
                      000000000519fe84  90 ff 19 05 02 01 00 00 - 01 00 00 00 00 00 00 00  ................
                      000000000519fe94  00 00 00 00 00 00 00 00 - 14 00 00 00 01 00 00 00  ................
                      000000000519fea4  00 00 00 00 00 00 00 00 - 10 00 00 00 e0 ac 42 7e  ..............B~
                      000000000519feb4  e4 fe 19 05 74 94 45 7e - 00 c0 fd 7f 00 40 fd 7f  ....t.E~.....@..
                      000000000519fec4  08 0c 2b 00 00 00 00 00 - 7c fe 19 05 84 94 45 7e  ..+.....|.....E~
                      000000000519fed4  02 00 00 00 70 fe 19 05 - 00 00 00 00 dc ff 19 05  ....p...........
                      000000000519fee4  d8 9a 83 7c 80 96 80 7c - 00 00 00 00 4c ff 19 05  ...|...|....L...
                      000000000519fef4  f9 95 41 7e 02 00 00 00 - 18 ff 19 05 00 00 00 00  ..A~............
                      000000000519ff04  ff ff ff ff 00 00 00 00 - 40 a3 42 7e a4 72 dd 4e  ........@.B~.r.N
                      000000000519ff14  00 00 00 00 3c 02 00 00 - 44 02 00 00 00 00 00 00  ....<...D.......
                      000000000519ff24  00 00 00 00 00 00 00 00 - 01 00 00 00 00 45 cb 01  .............E..
                      000000000519ff34  00 40 fd 7f 00 00 00 00 - 00 00 00 00 00 00 00 00  .@..............
                      000000000519ff44  00 40 fd 7f 44 02 00 00 - 68 ff 19 05 a8 96 41 7e  .@..D...h.....A~
                      000000000519ff54  01 00 00 00 ac ff 19 05 - ff ff ff ff ff 04 00 00  ................
                      000000000519ff64  18 ff 19 05 b4 ff 19 05 - b2 74 c6 4e 01 00 00 00  .........t.N....
                      000000000519ff74  ac ff 19 05 00 00 00 00 - ff ff ff ff ff 04 00 00  ................
                      000000000519ff84  10 00 ef be 11 00 00 00 - 00 00 00 00 a8 76 c4 87  .............v..
                      *----> State Dump for Thread Id 0x2fc <----*
                      eax=04f32080 ebx=04bc4901 ecx=00000030 edx=fffffff8 esi=00000001 edi=04bc481c
                      eip=7c90e514 esp=0e57fd04 ebp=0e57fd24 iopl=0         nv up ei pl nz na po nc
                      cs=001b  ss=0023  ds=0023  es=0023  fs=003b  gs=0000             efl=00000206
                              7c90e504 5d               pop     ebp
                              7c90e505 c3               ret
                              7c90e514 c3               ret
                              7c90e526 c3               ret
                              7c90e527 90               nop
                      0e57fd24 006efdbc 00008001 04bc481c 04bc47c8 ntdll!KiFastSystemCallRet
                      0e57fd88 00830f23 04bc47d8 0e57fe0c 0e57fe08 Bridge!CTJPEGRotateOptions__operator=+0xa3d1c
                      04bc47d8 00000000 04bc46c0 00000100 00000001 Bridge!CTJPEGRotateOptions__operator=+0x1e4e83
                      000000000e57fd04  aa dc 90 7c e1 ac 80 7c - ff ff ff ff 0c 00 00 00  ...|...|........
                      000000000e57fd14  20 fd 57 0e 04 00 00 00 - c8 47 bc 04 00 80 00 00   .W......G......
                      000000000e57fd24  88 fd 57 0e bc fd 6e 00 - 01 80 00 00 1c 48 bc 04  ..W...n......H..
                      000000000e57fd34  c8 47 bc 04 01 49 bc 04 - 98 fc 01 00 03 00 00 00  .G...I..........
                      000000000e57fd44  2c 1b af 00 78 48 28 13 - 1a 00 00 00 01 00 00 00  ,...xH(.........
                      000000000e57fd54  60 00 91 7c ff ff ff ff - 5d 00 91 7c 10 5d 6f 00  `..|....]..|.]o.
                      000000000e57fd64  00 00 23 02 00 00 00 00 - 2f 5d 6f 00 38 81 41 cb  ..#...../]o.8.A.
                      000000000e57fd74  a4 78 bc 04 78 fa be 04 - b0 fe 57 0e f8 8d ab 00  .x..x.....W.....
                      000000000e57fd84  00 00 00 00 d8 47 bc 04 - 23 0f 83 00 d8 47 bc 04  .....G..#....G..
                      000000000e57fd94  0c fe 57 0e 08 fe 57 0e - 00 00 00 00 00 00 00 00  ..W...W.........
                      000000000e57fda4  da fd 57 0e d3 fd 57 0e - fc fd 57 0e 03 00 00 00  ..W...W...W.....
                      000000000e57fdb4  e0 3d a6 0f 38 9a b4 04 - 00 00 00 00 38 00 00 00  .=..8.......8...
                      000000000e57fdc4  00 01 00 00 00 00 00 00 - ba 15 cd 01 01 00 00 00  ................
                      000000000e57fdd4  00 00 00 00 01 00 00 00 - 38 3a bc 04 f0 3a bc 04  ........8:...:..
                      000000000e57fde4  00 00 23 02 f8 fd 57 0e - 00 00 00 00 b8 00 91 7c  ..#...W........|
                      000000000e57fdf4  d8 3d a6 0f c4 fe 57 0e - 00 00 00 00 00 00 00 00  .=....W.........
                      000000000e57fe04  c4 49 bc 04 00 00 00 00 - 00 00 00 00 41 00 91 7c  .I..........A..|
                      000000000e57fe14  18 07 23 02 5d 00 91 7c - 03 00 00 00 03 00 00 00  ..#.]..|........
                      000000000e57fe24  00 00 00 00 d0 07 bd 04 - f8 fe 57 0e 4c a5 bc 00  ..........W.L...
                      000000000e57fe34  00 00 00 00 00 00 00 00 - 00 00 bd 04 02 00 00 00  ................
                      *----> State Dump for Thread Id 0xf80 <----*
                      eax=00000a24 ebx=0e67f84c ecx=0020e002 edx=0e67f774 esi=0e67f734 edi=002300a8
                      eip=03454722 esp=0e67de10 ebp=0e67de30 iopl=0         nv up ei pl nz na pe nc
                      cs=001b  ss=0023  ds=0023  es=0023  fs=003b  gs=0000             efl=00010202
                      function: Camera Raw
                              03454706 55               push    ebp
                              03454707 6319             arpl    [ecx],ebx
                              03454709 008a4d0c888c     add     [edx+0x8c880c4d],cl
                              0345470f 3020             xor     [eax],ah
                              03454711 0002             add     [edx],al
                              03454713 008db8022200     add     [ebp+0x2202b8],cl
                              03454719 00c1             add     cl,al
                              0345471b e704             out     04,eax
                              0345471d 03fe             add     edi,esi
                              0345471f 8b7510           mov     esi,[ebp+0x10]
                              03454722 a5               movsd     ds:0e67f734=00000000 es:002300a8=00000000
                              03454723 a5               movsd
                              03454724 a5               movsd
                              03454725 a5               movsd
                              03454726 834dfcff         or      dword ptr [ebp-0x4],0xffffffff
                              0345472a 8d4df0           lea     ecx,[ebp-0x10]
                              0345472d e8e3763800 call Camera Raw!CTJPEGDecoderCreateUsingData+0xe85f5 (037dbe15)
                              03454732 e8274c3c00 call Camera Raw!CTJPEGDecoderCreateUsingData+0x125b3e (0381935e)
                              03454737 c20c00           ret     0xc
                              0345473a 6a04             push    0x4
                              0345473c b88da68503       mov     eax,0x385a68d
                      0e67de30 03458f93 0e67f764 0e67de02 0e67f734 Camera Raw+0x54722
                      0e67dec4 0381a814 034db8de 352e6258 034d9c59 Camera Raw+0x58f93
                      fffffffe 00000000 00000000 00000000 00000000 Camera Raw!CTJPEGDecoderCreateUsingData+0x126ff4
                      000000000e67de10  ca d9 99 8b 00 00 00 00 - 74 f8 67 0e 4c f8 67 0e  ........t.g.L.g.
                      000000000e67de20  50 3e 22 00 b8 de 67 0e - 72 a6 85 03 00 00 00 00  P>"...g.r.......
                      000000000e67de30  c4 de 67 0e 93 8f 45 03 - 64 f7 67 0e 02 de 67 0e  ..g...E.d.g...g.
                      000000000e67de40  34 f7 67 0e 3e d9 99 8b - 02 00 00 00 00 00 00 00  4.g.>...........
                      000000000e67de50  2c f9 67 0e 00 00 15 00 - 5c 73 8c 03 c8 a4 8c 03  ,.g.....\s......
                      000000000e67de60  70 35 56 0f 62 00 00 00 - 01 00 00 00 0d 00 00 00  p5V.b...........
                      000000000e67de70  cc dd 67 0e 60 00 91 7c - b8 de 67 0e 20 e9 90 7c  ..g.`..|..g. ..|
                      000000000e67de80  60 00 91 7c ff ff ff ff - 5d 00 91 7c 4c f8 67 0e  `..|....]..|L.g.
                      000000000e67de90  40 c5 18 00 00 00 00 00 - 14 a8 81 03 00 00 00 00  @...............
                      000000000e67dea0  3c f9 67 0e 00 00 00 00 - 14 f9 67 0e 02 de 67 0e  <.g.......g...g.
                      000000000e67deb0  9c de 67 00 44 de 67 0e - 40 f8 67 0e 9c b1 85 03  ..g.D.g.@.g.....
                      000000000e67dec0  0a 00 00 00 fe ff ff ff - 14 a8 81 03 de b8 4d 03  ..............M.
                      000000000e67ded0  58 62 2e 35 59 9c 4d 03 - 58 62 2e 35 bc f6 67 0e  Xb.5Y.M.Xb.5..g.
                      000000000e67dee0  cb be 59 03 fe d8 99 8b - 3c f9 67 0e 78 f9 67 0e  ..Y.....<.g.x.g.
                      000000000e67def0  14 f9 67 0e bc f6 67 0e - 80 df 67 0e 24 45 87 03  ..g...g...g.$E..
                      000000000e67df00  ff ff ff ff cb be 59 03 - eb 97 45 03 76 d8 99 8b  ......Y...E.v...
                      000000000e67df10  02 00 00 00 00 00 00 00 - 07 98 45 03 00 00 00 00  ..........E.....
                      000000000e67df20  1c 74 8c 03 dc 96 8c 03 - 00 00 00 00 00 00 00 00  .t..............
                      000000000e67df30  01 00 00 00 00 00 00 00 - 01 00 00 00 65 6e 73 65  ............ense
                      000000000e67df40  73 5f 4d 69 70 e0 1b 28 - 28 77 3a 3f 0d 81 c4 f8  s_Mip..((w:?....
                      *----> State Dump for Thread Id 0x8c0 <----*
                      eax=0ec6f620 ebx=0ec6fd40 ecx=00000004 edx=00000024 esi=00000000 edi=7ffdc000
                      eip=7c90e514 esp=0ec6fd18 ebp=0ec6fdb4 iopl=0         nv up ei pl zr na po nc
                              7c90e504 5d               pop     ebp
                              7c90e505 c3               ret
                              7c90e514 c3               ret
                              7c90e526 c3               ret
                              7c90e527 90               nop
                      *** ERROR: Symbol file could not be found.  Defaulted to export symbols for C:\Program Files\Adobe\Adobe Bridge CS5\SwitchBoardClient.dll -
                      0ec6fdb4 7c80a115 00000002 0ec6fe1c 00000000 ntdll!KiFastSystemCallRet
                      0ec6fdd0 0eb2981f 00000002 0ec6fe1c 00000000 kernel32!WaitForMultipleObjects+0x18
                      00000002 00000000 00000000 00000000 00000000 SwitchBoardClient!createClient+0x1314f
                      000000000ec6fd18  4a df 90 7c 90 95 80 7c - 02 00 00 00 40 fd c6 0e  J..|...|....@...
                      000000000ec6fd28  01 00 00 00 00 00 00 00 - 74 fd c6 0e 00 00 00 00  ........t.......
                      000000000ec6fd38  fe ff ff ff 00 ff ff ff - 68 06 00 00 64 04 00 00  ........h...d...
                      000000000ec6fd48  00 00 00 00 e0 38 67 02 - a8 ad 01 00 02 00 00 00  .....8g.........
                      000000000ec6fd58  b4 fc c6 0e cc ad 00 02 - 14 00 00 00 01 00 00 00  ................
                      000000000ec6fd68  00 00 00 00 00 00 00 00 - 10 00 00 00 20 4e 00 00  ............ N..
                      000000000ec6fd78  f0 d8 ff ff 00 00 00 00 - 00 c0 fd 7f 00 d0 fa 7f  ................
                      000000000ec6fd88  02 00 00 00 74 fd c6 0e - 40 fd c6 0e 02 00 00 00  ....t...@.......
                      000000000ec6fd98  02 00 00 00 34 fd c6 0e - 47 dc b0 0e 48 fe c6 0e  ....4...G...H...
                      000000000ec6fda8  d8 9a 83 7c 80 96 80 7c - 00 00 00 00 d0 fd c6 0e  ...|...|........
                      000000000ec6fdb8  15 a1 80 7c 02 00 00 00 - 1c fe c6 0e 00 00 00 00  ...|............
                      000000000ec6fdc8  fe ff ff ff 00 00 00 00 - 02 00 00 00 1f 98 b2 0e  ................
                      000000000ec6fdd8  02 00 00 00 1c fe c6 0e - 00 00 00 00 fe ff ff ff  ................
                      000000000ec6fde8  a1 8c 0e 3a 7c fe c6 0e - d4 fe c6 0e c0 b0 68 02  ...:|.........h.
                      000000000ec6fdf8  01 00 00 00 00 00 00 00 - ff ff ff ff 00 00 00 00  ................
                      000000000ec6fe08  01 00 00 00 01 3f 66 02 - 91 09 b1 0e 01 3f 66 02  .....?f......?f.
                      000000000ec6fe18  fe ff ff ff 68 06 00 00 - 64 04 00 00 00 00 00 00  ....h...d.......
                      000000000ec6fe28  c0 b0 68 02 e4 11 b1 0e - f5 11 b1 0e 75 8f 0e 3a  ..h.........u..:
                      000000000ec6fe38  d4 fe c6 0e 28 ff c6 0e - b7 a0 80 7c 01 00 00 00  ....(......|....
                      000000000ec6fe48  a0 fe c6 0e ad 9f b3 0e - 00 00 00 00 07 18 b1 0e  ................
                      *----> State Dump for Thread Id 0xa34 <----*
                      eax=00000000 ebx=0ed6fd44 ecx=00000000 edx=00000000 esi=00000000 edi=7ffdc000
                      eip=7c90e514 esp=0ed6fd1c ebp=0ed6fdb8 iopl=0         nv up ei pl zr na po nc
                              7c90e504 5d               pop     ebp
                              7c90e505 c3               ret
                              7c90e514 c3               ret
                              7c90e526 c3               ret
                              7c90e527 90               nop
                      0ed6fdb8 7c80a115 00000002 0ed6fe20 00000000 ntdll!KiFastSystemCallRet
                      0ed6fdd4 0eb2981f 00000002 0ed6fe20 00000000 kernel32!WaitForMultipleObjects+0x18
                      000000000ed6fd1c  4a df 90 7c 90 95 80 7c - 02 00 00 00 44 fd d6 0e  J..|...|....D...
                      000000000ed6fd2c  01 00 00 00 00 00 00 00 - 78 fd d6 0e 00 00 00 00  ........x.......
                      000000000ed6fd3c  fe ff ff ff 00 ff ff ff - 8c 04 00 00 74 04 00 00  ............t...
                      000000000ed6fd4c  00 00 00 00 f8 33 68 02 - e8 fb 12 00 20 e9 90 7c  .....3h..... ..|
                      000000000ed6fd5c  10 00 00 00 00 00 00 7c - 14 00 00 00 01 00 00 00  .......|........
                      000000000ed6fd6c  00 00 00 00 00 00 00 00 - 10 00 00 00 20 4e 00 00  ............ N..
                      000000000ed6fd7c  f0 d8 ff ff db 01 91 7c - 00 c0 fd 7f 00 c0 fa 7f  .......|........
                      000000000ed6fd8c  00 00 00 00 78 fd d6 0e - 44 fd d6 0e 01 00 00 00  ....x...D.......
                      000000000ed6fd9c  02 00 00 00 38 fd d6 0e - 47 dc b0 0e 4c fe d6 0e  ....8...G...L...
                      000000000ed6fdac  d8 9a 83 7c 80 96 80 7c - 00 00 00 00 d4 fd d6 0e  ...|...|........
                      000000000ed6fdbc  15 a1 80 7c 02 00 00 00 - 20 fe d6 0e 00 00 00 00  ...|.... .......
                      000000000ed6fdcc  fe ff ff ff 00 00 00 00 - 02 00 00 00 1f 98 b2 0e  ................
                      000000000ed6fddc  02 00 00 00 20 fe d6 0e - 00 00 00 00 fe ff ff ff  .... ...........
                      000000000ed6fdec  bd 8c 1e 3a 80 fe d6 0e - d8 fe d6 0e d8 22 ba 05  ...:........."..
                      000000000ed6fdfc  01 00 00 00 00 00 00 00 - ff ff ff ff 00 00 00 00  ................
                      000000000ed6fe0c  01 00 00 00 01 00 00 00 - 91 09 b1 0e 01 00 00 00  ................
                      000000000ed6fe1c  fe ff ff ff 8c 04 00 00 - 74 04 00 00 00 00 00 00  ........t.......
                      000000000ed6fe2c  d8 22 ba 05 e4 11 b1 0e - f5 11 b1 0e 71 8f 1e 3a  ."..........q..:
                      000000000ed6fe3c  d8 fe d6 0e 28 ff d6 0e - 48 ff d6 0e 01 00 00 00  ....(...H.......
                      000000000ed6fe4c  a4 fe d6 0e ad 9f b3 0e - 00 00 00 00 07 18 b1 0e  ................
                      *----> State Dump for Thread Id 0xb84 <----*
                      eax=784818b4 ebx=05e98100 ecx=0f3efae4 edx=78507308 esi=7fffffff edi=ffffffff
                      eip=7c90e514 esp=0f3efb70 ebp=0f3efbac iopl=0         nv up ei ng nz ac po cy
                              7c90e504 5d               pop     ebp
                              7c90e505 c3               ret
                              7c90e514 c3               ret
                              7c90e526 c3               ret
                              7c90e527 90               nop
                      *** ERROR: Symbol file could not be found.  Defaulted to export symbols for C:\WINDOWS\System32\mswsock.dll -
                      *** ERROR: Symbol file could not be found.  Defaulted to export symbols for C:\WINDOWS\system32\WS2_32.dll -
                      0f3efbac 71a557c9 00000650 00000640 00000000 ntdll!KiFastSystemCallRet
                      0f3efc24 71ab4d16 00000640 0f3efc9c 00000001 mswsock+0x57c9
                      0f3efc60 0eb08ab0 00000640 0f3efc9c 00000001 WS2_32!WSARecv+0x61
                      00000640 00000000 00000000 00000000 00000000 SwitchBoardClient+0x48ab0
                      000000000f3efb70  5a df 90 7c 2b 40 a5 71 - 50 06 00 00 01 00 00 00  Z..|+@.qP.......
                      000000000f3efb80  98 fb 3e 0f 50 06 00 00 - 03 01 00 00 03 01 00 00  ..>.P...........
                      000000000f3efb90  f0 b1 e7 d9 b3 15 cd 01 - ff ff ff ff ff ff ff 7f  ................
                      000000000f3efba0  00 81 e9 05 00 00 00 00 - 00 00 00 00 24 fc 3e 0f  ............$.>.
                      000000000f3efbb0  c9 57 a5 71 50 06 00 00 - 40 06 00 00 00 00 00 00  .W.qP...@.......
                      000000000f3efbc0  06 00 00 00 bc fe 3e 0f - 00 7d fe 01 00 10 00 00  ......>..}......
                      000000000f3efbd0  9c fc 3e 0f 01 00 00 00 - 00 00 00 00 20 00 00 00  ..>......... ...
                      000000000f3efbe0  f4 fb 3e 0f af 59 48 78 - 03 01 00 00 58 09 c2 05  ..>..YHx....X...
                      000000000f3efbf0  50 06 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  P...............
                      000000000f3efc00  e8 fb 3e 0f 00 81 e9 05 - 00 00 00 00 c4 fb 3e 0f  ..>...........>.
                      000000000f3efc10  b8 20 ba 05 3c ff 3e 0f - 28 72 a7 71 b0 44 a5 71  . ..<.>.(r.q.D.q
                      000000000f3efc20  ff ff ff ff 60 fc 3e 0f - 16 4d ab 71 40 06 00 00  ....`.>..M.q@...
                      000000000f3efc30  9c fc 3e 0f 01 00 00 00 - 94 fc 3e 0f 98 fc 3e 0f  ..>.......>...>.
                      000000000f3efc40  00 00 00 00 00 00 00 00 - 20 7d fe 01 5c fc 3e 0f  ........ }..\.>.
                      000000000f3efc50  bc fe 3e 0f c0 09 c2 05 - 20 7d fe 01 00 00 00 00  ..>..... }......
                      000000000f3efc60  40 06 00 00 b0 8a b0 0e - 40 06 00 00 9c fc 3e 0f  @.......@.....>.
                      000000000f3efc70  01 00 00 00 94 fc 3e 0f - 98 fc 3e 0f 00 00 00 00  ......>...>.....
                      000000000f3efc80  00 00 00 00 00 00 00 00 - 01 00 00 00 10 08 c2 05  ................
                      000000000f3efc90  48 ff 3e 0f 00 00 00 00 - 00 00 00 00 00 10 00 00  H.>.............
                      000000000f3efca0  c0 09 c2 05 70 fd 3e 0f - 41 00 91 7c 18 07 fa 01  ....p.>.A..|....
                      *----> State Dump for Thread Id 0x7e0 <----*
                      eax=00000000 ebx=05e98130 ecx=00000000 edx=00000000 esi=7fffffff edi=ffffffff
                      eip=7c90e514 esp=0f4efb70 ebp=0f4efbac iopl=0         nv up ei ng nz ac po cy
                              7c90e504 5d               pop     ebp
                              7c90e505 c3               ret
                              7c90e514 c3               ret
                              7c90e526 c3               ret
                              7c90e527 90               nop
                      0f4efbac 71a557c9 00000678 0000064c 00000000 ntdll!KiFastSystemCallRet
                      0f4efc24 71ab4d16 0000064c 0f4efc9c 00000001 mswsock+0x57c9
                      0f4efc60 0eb08ab0 0000064c 0f4efc9c 00000001 WS2_32!WSARecv+0x61
                      0000064c 00000000 00000000 00000000 00000000 SwitchBoardClient+0x48ab0
                      000000000f4efb70  5a df 90 7c 2b 40 a5 71 - 78 06 00 00 01 00 00 00  Z..|+@.qx.......
                      000000000f4efb80  98 fb 4e 0f 78 06 00 00 - 03 01 00 00 03 01 00 00  ..N.x...........
                      000000000f4efb90  f0 b1 e7 d9 b3 15 cd 01 - ff ff ff ff ff ff ff 7f  ................
                      000000000f4efba0  30 81 e9 05 00 00 00 00 - 00 00 00 00 24 fc 4e 0f  0...........$.N.
                      000000000f4efbb0  c9 57 a5 71 78 06 00 00 - 4c 06 00 00 00 00 00 00  .W.qx...L.......
                      000000000f4efbc0  06 00 00 00 bc fe 4e 0f - 80 7d fe 01 00 10 00 00  ......N..}......
                      000000000f4efbd0  9c fc 4e 0f 01 00 00 00 - 00 00 00 00 20 00 00 00  ..N......... ...
                      000000000f4efbe0  f4 fb 4e 0f af 59 48 78 - 03 01 00 00 60 1c c2 05  ..N..YHx....`...
                      000000000f4efbf0  78 06 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  x...............
                      000000000f4efc00  e8 fb 4e 0f 30 81 e9 05 - 00 00 00 00 c4 fb 4e 0f  ..N.0.........N.
                      000000000f4efc10  a8 39 6a 02 3c ff 4e 0f - 28 72 a7 71 b0 44 a5 71  .9j.<.N.(r.q.D.q
                      000000000f4efc20  ff ff ff ff 60 fc 4e 0f - 16 4d ab 71 4c 06 00 00  ....`.N..M.qL...
                      000000000f4efc30  9c fc 4e 0f 01 00 00 00 - 94 fc 4e 0f 98 fc 4e 0f  ..N.......N...N.
                      000000000f4efc40  00 00 00 00 00 00 00 00 - a0 7d fe 01 5c fc 4e 0f  .........}..\.N.
                      000000000f4efc50  bc fe 4e 0f c8 1c c2 05 - a0 7d fe 01 00 00 00 00  ..N......}......
                      000000000f4efc60  4c 06 00 00 b0 8a b0 0e - 4c 06 00 00 9c fc 4e 0f  L.......L.....N.
                      000000000f4efc70  01 00 00 00 94 fc 4e 0f - 98 fc 4e 0f 00 00 00 00  ......N...N.....
                      000000000f4efc80  00 00 00 00 00 00 00 00 - 01 00 00 00 18 1b c2 05  ................
                      000000000f4efc90  48 ff 4e 0f 00 00 00 00 - 00 00 00 00 00 10 00 00  H.N.............
                      000000000f4efca0  c8 1c c2 05 f9 59 48 78 - 88 3b 6a 02 30 00 00 00  .....YHx.;j.0...
                      *----> State Dump for Thread Id 0x914 <----*
                      eax=ffffffff ebx=00000000 ecx=05e7fe74 edx=7c90e514 esi=05e7fdd0 edi=00000000
                      eip=7c90e514 esp=107bfe18 ebp=107bff80 iopl=0         nv up ei pl zr na po nc
                              7c90e504 5d               pop     ebp
                              7c90e505 c3               ret
                              7c90e514 c3               ret
                              7c90e526 c3               ret
                              7c90e527 90               nop
                      *** ERROR: Symbol file could not be found.  Defaulted to export symbols for C:\WINDOWS\system32\RPCRT4.dll -
                      107bff80 77e76caf 107bffa8 77e76ad1 05e7fdd0 ntdll!KiFastSystemCallRet
                      107bff88 77e76ad1 05e7fdd0 7c97e174 7c917c51 RPCRT4!I_RpcBCacheFree+0x61c
                      107bffa8 77e76c97 00183d70 107bffec 7c80b729 RPCRT4!I_RpcBCacheFree+0x43e
                      107bffb4 7c80b729 04fd93a0 7c97e174 7c917c51 RPCRT4!I_RpcBCacheFree+0x604
                      107bffec 00000000 77e76c7d 04fd93a0 00000000 kernel32!GetModuleFileNameA+0x1ba
                      00000000107bfe18  aa da 90 7c e3 65 e7 77 - 1c 07 00 00 74 ff 7b 10  ...|.e.w....t.{.
                      00000000107bfe28  00 00 00 00 40 ba 2e 0e - 50 ff 7b 10 00 00 00 00  ....@...P.{.....
                      00000000107bfe38  00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                      00000000107bfe48  00 00 00 00 00 00 00 00 - 02 00 00 00 00 00 00 00  ................
                      00000000107bfe58  00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                      00000000107bfe68  00 00 00 00 01 00 00 00 - 00 00 00 00 00 00 00 00  ................
                      00000000107bfe78  00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                      00000000107bfe88  00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                      00000000107bfe98  00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                      00000000107bfea8  00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                      00000000107bfeb8  00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                      00000000107bfec8  00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                      00000000107bfed8  00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                      00000000107bfee8  00 00 00 00 1f 00 00 00 - e8 e6 fc 87 40 f5 df ff  ............@...
                      00000000107bfef8  03 5c 54 80 ff ff ff ff - 46 02 00 00 1b 5a 54 80  .\T.....F....ZT.
                      00000000107bff08  28 2c 01 a8 e8 e6 fc 87 - 20 f1 df ff 84 e8 fc 87  (,...... .......
                      00000000107bff18  72 38 50 80 58 e7 fc 87 - e8 e6 fc 87 78 b0 4f 80  r8P.X.......x.O.
                      00000000107bff28  54 e8 fc 87 80 ff 7b 10 - 85 d1 e7 77 48 ff 7b 10  T.....{....wH.{.
                      00000000107bff38  95 d1 e7 77 e0 10 90 7c - 38 3a 2d 0e a0 93 fd 04  ...w...|8:-.....
                      00000000107bff48  00 a2 2f 4d ff ff ff ff - 00 5d 1e ee ff ff ff ff  ../M.....]......
                      *----> State Dump for Thread Id 0xa94 <----*
                      eax=1448fc00 ebx=1448fecc ecx=00000003 edx=0000007c esi=00000000 edi=7ffdc000
                      eip=7c90e514 esp=1448fea4 ebp=1448ff40 iopl=0         nv up ei pl zr na po nc
                              7c90e504 5d               pop     ebp
                              7c90e505 c3               ret
                              7c90e514 c3               ret
                              7c90e526 c3               ret
                              7c90e527 90               nop
                      *** ERROR: Symbol file could not be found.  Defaulted to export symbols for C:\Program Files\Adobe\Adobe Bridge CS5\amtservices.dll -
                      *** ERROR: Symbol file could not be found.  Defaulted to export symbols for C:\WINDOWS\system32\ole32.dll -
                      1448ff40 7c80a115 00000002 14384af8 00000000 ntdll!KiFastSystemCallRet
                      1448ff5c 1415eb6e 00000002 14384af8 00000000 kernel32!WaitForMultipleObjects+0x18
                      14384f48 14384ac8 7a696c00 00000000 14384ae8 amtservices+0x3eb6e
                      14206494 77534955 68637469 76726553 00656369 0x14384ac8
                      1415ede0 fffffe68 082444f6 56097401 0081c8e8 ole32!CoGetStandardMarshal+0x139
                      e8f18b56 00000000 00000000 00000000 00000000 0xfffffe68
                      000000001448fea4  4a df 90 7c 90 95 80 7c - 02 00 00 00 cc fe 48 14  J..|...|......H.
                      000000001448feb4  01 00 00 00 00 00 00 00 - 00 00 00 00 ec 4a 38 14  .............J8.
                      000000001448fec4  e8 4a 38 14 40 4b 38 14 - 38 09 00 00 40 09 00 00  .J8.@K8.8...@...
                      000000001448fed4  4c ff 48 14 20 25 73 02 - 60 c2 c2 cc fe ff ff ff  L.H. %s.`.......
                      000000001448fee4  5b c8 72 02 55 64 6f 02 - 14 00 00 00 01 00 00 00  [.r.Udo.........
                      000000001448fef4  00 00 00 00 00 00 00 00 - 10 00 00 00 76 eb 17 1b  ............v...
                      000000001448ff04  34 4f 38 14 18 4f 38 14 - 00 c0 fd 7f 00 60 fa 7f  4O8..O8......`..
                      000000001448ff14  18 4f 38 14 00 00 00 00 - cc fe 48 14 70 73 2e 64  .O8.......H.ps.d
                      000000001448ff24  02 00 00 00 c0 fe 48 14 - 0f 00 00 00 dc ff 48 14  ......H.......H.
                      000000001448ff34  d8 9a 83 7c 80 96 80 7c - 00 00 00 00 5c ff 48 14  ...|...|....\.H.
                      000000001448ff44  15 a1 80 7c 02 00 00 00 - f8 4a 38 14 00 00 00 00  ...|.....J8.....
                      000000001448ff54  ff ff ff ff 00 00 00 00 - 48 4f 38 14 6e eb 15 14  ........HO8.n...
                      000000001448ff64  02 00 00 00 f8 4a 38 14 - 00 00 00 00 ff ff ff ff  .....J8.........
                      000000001448ff74  02 00 00 00 40 4b 38 14 - 48 4f 38 14 ec ff 48 14  ....@K8.HO8...H.
                      000000001448ff84  bc ec 15 14 e8 4a 38 14 - 48 4f 38 14 18 4f 38 14  .....J8.HO8..O8.
                      000000001448ff94  48 4f 38 14 de 30 14 14 - 02 00 00 00 20 00 00 00  HO8..0...... ...
                      000000001448ffa4  40 4b 38 14 af ee 15 14 - 18 4f 38 14 20 00 00 00  @K8......O8. ...
                      000000001448ffb4  20 4f 38 14 29 b7 80 7c - 40 4b 38 14 20 00 00 00   O8.)..|@K8. ...
                      000000001448ffc4  20 4f 38 14 40 4b 38 14 - 00 60 fa 7f 00 76 83 8a   O8.@K8..`...v..
                      000000001448ffd4  c0 ff 48 14 30 e4 0a 88 - ff ff ff ff d8 9a 83 7c  ..H.0..........|
                      *----> State Dump for Thread Id 0xf08 <----*
                      eax=1d5e9600 ebx=00000000 ecx=0000ffff edx=00000003 esi=00000000 edi=1983d694
                      eip=7c911911 esp=1983d5a0 ebp=1983d654 iopl=0         nv up ei pl zr na po nc
                      cs=001b  ss=0023  ds=0023  es=0023  fs=003b  gs=0000             efl=00010246
                      function: ntdll!RtlInitializeCriticalSection
                              7c9118ed 55               push    ebp
                              7c9118ee 10ff             adc     bh,bh
                              7c9118f0 4d               dec     ebp
                              7c9118f1 1085d20f8483     adc     [ebp+0x83840fd2],al
                              7c9118f7 800100           add     byte ptr [ecx],0x0
                              7c9118fa 837d1000         cmp     dword ptr [ebp+0x10],0x0
                              7c9118fe 0f843e010000  je ntdll!RtlInitializeCriticalSection+0x425 (7c911a42)
                              7c911904 837dac00         cmp     dword ptr [ebp-0x54],0x0
                              7c911908 0f850b030000 jne ntdll!RtlInitializeCriticalSection+0x5fc (7c911c19)
                              7c91190e 8a5dd3           mov     bl,[ebp-0x2d]
                              7c911911 668b500c         mov     dx,[eax+0xc]          ds:0023:1d5e960c=0005
                              7c911915 668955b4         mov     [ebp-0x4c],dx
                              7c911919 8d7010           lea     esi,[eax+0x10]
                              7c91191c 897594           mov     [ebp-0x6c],esi
                              7c91191f 8b550c           mov     edx,[ebp+0xc]
                              7c911922 66f74202ffff     test    word ptr [edx+0x2],0xffff
                              7c911928 7511         jnz ntdll!RtlInitializeCriticalSection+0x31e (7c91193b)
                              7c91192a 0fb755b4         movzx   edx,word ptr [ebp-0x4c]
                              7c91192e 8d34d6           lea     esi,[esi+edx*8]
                              7c911931 897594           mov     [ebp-0x6c],esi
                              7c911934 0fb7400e         movzx   eax,word ptr [eax+0xe]
                      *** ERROR: Symbol file could not be found.  Defaulted to export symbols for C:\WINDOWS\system32\VERSION.dll -
                      *** ERROR: Symbol file could not be found.  Defaulted to export symbols for C:\WINDOWS\system32\appHelp.dll -
                      *** ERROR: Symbol file could not be found.  Defaulted to export symbols for C:\WINDOWS\system32\faultrep.dll -
                      1983d654 7c911db7 1d080001 1983d694 00000002 ntdll!RtlInitializeCriticalSection+0x2f4
                      1983d670 7c80bccd 1d080001 1983d694 00000003 ntdll!LdrFindResource_U+0x18
                      1983d6c4 77c013e3 1d080001 00000001 00000010 kernel32!FindResourceW+0x5f
                      1983d714 77b464e5 04fdbc68 1983d8f4 00000000 VERSION!GetFileVersionInfoSizeW+0x57
                      1983d91c 77b5b13d 1983d724 04fdbaa0 05efcd20 appHelp!SdbTagIDToTagRef+0x609
                      1983d938 77b59fbb 05ef4cb0 1983d98c 1983d958 appHelp+0x1b13d
                      1983dbf4 77b5a905 00000804 1983dc24 10000001 appHelp!SdbReadEntryInformation+0x756
                      1983de58 77b5aa40 025900b8 10000001 1983e674 appHelp!SdbGrabMatchingInfoEx+0x2c2
                      1983de74 69459160 025900b8 10000001 1983e674 appHelp!SdbGrabMatchingInfo+0x17
                      1983df9c 69457442 025900b8 00000000 1983e674 faultrep!ReportFault+0x13e2
                      1983e898 694582b1 1983fba8 ffffffff 00198310 faultrep!ReportFaultDWM+0x12d5
                      1983f90c 7c864526 1983fba8 ffffffff 00000000 faultrep!ReportFault+0x533
                      1983fb80 7c83ab50 1983fba8 7c839b39 1983fbb0 kernel32!UnhandledExceptionFilter+0x55c
                      1983ffec 00000000 0074f670 04bdf838 00000000 kernel32!ValidateLocale+0x1328
                      000000001983d5a0  01 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                      000000001983d5b0  00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                      000000001983d5c0  00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                      000000001983d5d0  00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                      000000001983d5e0  00 00 00 00 00 00 00 00 - 00 00 00 00 03 00 00 00  ................
                      000000001983d5f0  00 00 00 00 94 d6 83 19 - 00 00 00 00 00 00 00 00  ................
                      000000001983d600  00 00 00 00 00 96 5e 1d - 00 00 00 00 00 96 5e 1d  ......^.......^.
                      000000001983d610  00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                      000000001983d620  00 00 00 00 00 00 00 00 - 78 b0 03 00 00 00 00 00  ........x.......
                      000000001983d630  00 00 00 00 46 ac 80 7c - ff ff 00 00 a0 d5 83 19  ....F..|........
                      000000001983d640  00 00 00 00 b4 d6 83 19 - 20 e9 90 7c c8 19 91 7c  ........ ..|...|
                      000000001983d650  00 00 00 00 70 d6 83 19 - b7 1d 91 7c 01 00 08 1d  ....p......|....
                      000000001983d660  94 d6 83 19 02 00 00 00 - 00 00 00 00 a4 d6 83 19  ................
                      000000001983d670  c4 d6 83 19 cd bc 80 7c - 01 00 08 1d 94 d6 83 19  .......|........
                      000000001983d680  03 00 00 00 a4 d6 83 19 - 01 00 00 00 01 00 08 1d  ................
                      000000001983d690  00 00 00 00 10 00 00 00 - 01 00 00 00 00 00 00 00  ................
                      000000001983d6a0  05 ad 80 7c 00 00 00 00 - 0c 00 00 00 88 d6 83 19  ...|............
                      000000001983d6b0  e1 ac 80 7c 04 d7 83 19 - d8 9a 83 7c f8 bc 80 7c  ...|.......|...|
                      000000001983d6c0  00 00 00 00 14 d7 83 19 - e3 13 c0 77 01 00 08 1d  ...........w....
                      000000001983d6d0  01 00 00 00 10 00 00 00 - e0 d8 83 19 a0 ba fd 04  ................
                      *----> State Dump for Thread Id 0x434 <----*
                      eax=37393231 ebx=04bdb5b8 ecx=04bdb5b8 edx=7c90e514 esi=04bdb5b8 edi=105bf834
                      eip=0074f582 esp=1c96ff88 ebp=1c96ffb0 iopl=0         nv up ei ng nz na po nc
                      cs=001b  ss=0023  ds=0023  es=0023  fs=003b  gs=0000             efl=00000286
                      function: Bridge!CTJPEGRotateOptions__operator=
                              0074f569 75c8   jnz Bridge!CTJPEGRotateOptions__operator=+0x103493 (0074f533)
                              0074f56b 0033             add     [ebx],dh
                              0074f56d c5508d           lds     edx,[eax-0x73]
                              0074f570 45               inc     ebp
                              0074f571 f4               hlt
                              0074f572 64a300000000     mov     fs:[00000000],eax
                              0074f578 8965f0           mov     [ebp-0x10],esp
                              0074f57b 8bf1             mov     esi,ecx
                              0074f57d 8975ec           mov     [ebp-0x14],esi
                              0074f580 8b06             mov     eax,[esi]
                      FAULT ->0074f582 8b500c           mov     edx,[eax+0xc]     ds:0023:3739323d=????????
                              0074f585 c745fc00000000   mov     dword ptr [ebp-0x4],0x0
                              0074f58c ffd2             call    edx
                              0074f58e eb13   jmp Bridge!CTJPEGRotateOptions__operator=+0x103503 (0074f5a3)
                              0074f590 c745e8ffffffff   mov     dword ptr [ebp-0x18],0xffffffff
                              0074f597 b89df57400       mov     eax,0x74f59d
                              0074f59c c3               ret
                              0074f59d 8b75ec           mov     esi,[ebp-0x14]
                              0074f5a0 8b45e8           mov     eax,[ebp-0x18]
                              0074f5a3 c6460c00         mov     byte ptr [esi+0xc],0x0
                              0074f5a7 8b4df4           mov     ecx,[ebp-0xc]
                      1c96ffb0 0074f67f 7c80b729 04bdb5b8 105bf834 Bridge!CTJPEGRotateOptions__operator=+0x1034e2
                      1c96ffec 00000000 0074f670 04bdb5b8 00000000 Bridge!CTJPEGRotateOptions__operator=+0x1035df
                      000000001c96ff88  14 83 80 d9 34 f8 5b 10 - b8 35 a3 0f b8 b5 bd 04  ....4.[..5......
                      000000001c96ff98  00 00 00 00 b8 b5 bd 04 - 88 ff 96 1c dc ff 96 1c  ................
                      000000001c96ffa8  40 f1 a5 00 ff ff ff ff - ec ff 96 1c 7f f6 74 00  @.............t.
                      000000001c96ffb8  29 b7 80 7c b8 b5 bd 04 - 34 f8 5b 10 b8 35 a3 0f  )..|....4.[..5..
                      000000001c96ffc8  b8 b5 bd 04 00 80 fa 7f - 05 00 00 c0 c0 ff 96 1c  ................
                      000000001c96ffd8  ac fb 96 1c ff ff ff ff - d8 9a 83 7c 30 b7 80 7c  ...........|0..|
                      000000001c96ffe8  00 00 00 00 00 00 00 00 - 00 00 00 00 70 f6 74 00  ............p.t.
                      000000001c96fff8  b8 b5 bd 04 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                      000000001c970008  00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                      000000001c970018  00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                      000000001c970028  00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                      000000001c970038  00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                      000000001c970048  00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                      000000001c970058  00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                      000000001c970068  00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                      000000001c970078  00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                      000000001c970088  00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                      000000001c970098  00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                      000000001c9700a8  00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                      000000001c9700b8  00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                      *----> Symbol Table <----*
                      0064bf70  Bridge!CTJPEGDecodeOptions__operator=
                      0064bf80  Bridge!CTJPEGQualityParams__operator=
                      0064bfa0  Bridge!CTJPEGEncodeOptions__operator=
                      0064bfc0  Bridge!CTJPEGImageContent__operator=
                      0064bfe0  Bridge!CTJPEGRect__operator=
                      0064bfe0  Bridge!CTJPEGData__operator=
                      0064bfe0  Bridge!CTJPEGMetaData__operator=
                      0064bfe0  Bridge!CTJPEGWarningHandler__operator=
                      0064bfe0  Bridge!CTJPEGTask__operator=
                      0064c000  Bridge!CTJPEGTaskManager__operator=
                      0064c030  Bridge!CTJPEGReader__operator=
                      0064c030  Bridge!CTJPEGTiledContentReader__operator=
                      0064c050  Bridge!CTJPEGMemoryManager__operator=
                      0064c050  Bridge!CTJPEGMetaDataHandler__operator=
                      0064c050  Bridge!CTJPEGHeader__operator=
                      0064c050  Bridge!CTJPEGWriter__operator=
                      0064c070  Bridge!CTJPEGTiledContentWriter__operator=
                      0064c0a0  Bridge!CTJPEGRotateOptions__operator=
                      00a58af0  Bridge!CTJPEGDecodeOptionsInitDefault
                      00a58c70  Bridge!CTJPEGEncoderRelease
                      00a58ca0  Bridge!CTJPEGEncodeOptionsInitDefault
                      00a58cd0  Bridge!CTJPEGDecoderRelease
                      00a58e10  Bridge!CTJPEGRotateOptionsInitDefault
                      00a58e30  Bridge!CTJPEGEncoderBulkWriteMetaData
                      00a58ed0  Bridge!CTJPEGEncoderWriteMetaData
                      00a58f70  Bridge!CTJPEGDecoderHasMoreTiles
                      00a58f90  Bridge!CTJPEGDecoderGetNextTileInfo
                      00a58fb0  Bridge!CTJPEGDecoderSetOutColorSpace
                      00a58fd0  Bridge!CTJPEGLibTerminate
                      00a58ff0  Bridge!CTJPEGLibInit
                      00a59080  Bridge!CTJPEGEncoderWriteHeader
                      00a592c0  Bridge!CTJPEGDecoderCreateUsingData
                      00a59450  Bridge!CTJPEGDecoderCreate
                      00a59580  Bridge!CTJPEGEncoderWriteContent
                      00a596a0  Bridge!CTJPEGEncoderWriteTiledContent
                      00a59770  Bridge!CTJPEGEncoderWriteNextTileContent
                      00a59820  Bridge!CTJPEGDecoderReadNextTile
                      00a598d0  Bridge!CTJPEGDecoderReadContent
                      00a599e0  Bridge!CTJPEGDecoderReadTiledContent
                      00a59aa0  Bridge!CTJPEGDecoderReadHeader
                      00a59b40  Bridge!CTJPEGRotateImage
                      00b456e4  Bridge!defaultCTJPEGMemoryManager
                      00b47144  Bridge!defaultCTJPEGTaskManager
                      • 8. Re: CS5 bridge Crashes Consistently
                        Level 7
                        That does look like a bug in Bridge, related to rotation of JPEG documents.
                        • 9. Re: CS5 bridge Crashes Consistently
                          Curt Y Level 7
                          nuharjegfaaetnok wrote:
                          The behavior is the same when I drag files and when I use Edit Cut - Paste.
                          Have you tried using "Move To or Copy To" rather than your methods above?  Takes less computer resources than drag and drop.
                          If Chris Cox says the crash report looks like a bug then it probably is.
                          I would definitely submit a bug report and quote Chris Cox.  He is not a Bridge engineer, but one of the principal programmers of Photoshop.
                          If you had a set point you could try to roll back to pervious version.
                          • 10. Re: CS5 bridge Crashes Consistently
                            nuharjegfaaetnok Level 1
                            There used to be a way to file a bug report. I don't see any such option anymore for users (like me) that has no support plan.
                            Curt Y, I will look into rolling back the XP updates - good idea, thanks!
                            • 11. Re: CS5 bridge Crashes Consistently
                              Curt Y Level 7
                              It appears the best bet now to to use the community form to report a problem.  Here is the link for it.  http://feedback.photoshop.com/photoshop_family
