1. Re: How to make this effect?
Trevor.Dennis Apr 7, 2012 2:45 PM (in response to JTA497)I can get close by using Render > Fibers, and using Free Transform to stretch them vertically, and finally using a Levels layer to adjust the contrast, but I could not get the lines as fine as in your example.
2. Re: How to make this effect?
Semaphoric Apr 7, 2012 5:46 PM (in response to JTA497)Filter > Stylize > Wind. You'll have to rotate the results by 90 degrees to duplicate your example.
4. Re: How to make this effect?
Trevor.Dennis Apr 9, 2012 5:21 AM (in response to Noel Carboni)That's the sort of result I was getting with fibers, and I tried using noise as a starting point at the same time. It just isn't as finely lined as the paint.net effect.
5. Re: How to make this effect?
Flexesss Apr 8, 2012 11:08 PM (in response to JTA497)A good lesson. And how to make multi-colored stripes?
7. Re: How to make this effect?
Flexesss Apr 9, 2012 4:45 AM (in response to JTA497)c.pfaffenbichler, thanks.
8. Re: How to make this effect?
Trevor.Dennis Apr 9, 2012 5:26 AM (in response to Flexesss)I guess if you wanted really fine lines, you could use Free Transfer step & Repeat, but by heck it would come to some layers!
9. Re: How to make this effect?
emil emil Apr 9, 2012 6:57 AM (in response to JTA497)I believe that was done with a brush. Create a brush from a long narrow triangle - the custom paths shape tool has already a triangle shape that can be stretched when creating it. From the brush controls enable only Size Jitter from Shape Dynamics and set it to 100% and from the Brush Tip Shape adjust spacing as desired.
For color gradient, create a gradient layer on top and make it a clipping mask (Ctrl + Alt + G)
10. Re: How to make this effect?
Noel Carboni Apr 9, 2012 7:09 AM (in response to Trevor.Dennis)Trevor.Dennis wrote:
Honestly, I don't see a problem with the "fineness" of the lines in my example, as they are a single pixel in width, but there's always the possibility of creating any effect at a much larger size and downsizing.
-Noel
