I am working on an order form that has some conditional fields / pages that must be visible / hidden based on the user selection. However when I close and reopen the form all selections are switched to default view (either hidden or visible). How do I prevent that (other than printing the form to PDF).
Solved! Go to Solution.
Total Likes
Under Form Properties ... Defaults (tab) you can set "preserve scripting changes to form when saved" to automatic. If it is set to manual and you want to keep it that way you will have add code in the initialize events to restore the form state.
Hope that helps
Bruce
Total Likes
Hope that helps
Bruce
Total Likes
