37 Replies Latest reply on Apr 16, 2012 9:24 AM by Jonathan Fortis
    search results displaying all records, please help
    Jonathan Fortis
      i did post this before but didnt have any luck I have used my search script before but tried it again and it is returning ALL the results from the DB..Can anyone see what i am missing?
      $var_SalaryReq_Recordset1 = "%";
      if (isset($_GET['SalaryReq'])) {
        $var_SalaryReq_Recordset1 = $_GET['SalaryReq'];
      $var_skills_offered_Recordset1 = "%";
      if (isset($_GET['skills_offered'])) {
        $var_skills_offered_Recordset1 = $_GET['skills_offered'];
      $var_location_Recordset1 = "%";
      if (isset($_GET['location'])) {
        $var_location_Recordset1 = $_GET['location'];
      $var_PositionReq_Recordset1 = "%";
      if (isset($_GET['PositionReg'])) {
        $var_PositionReq_Recordset1 = $_GET['PositionReg'];
      mysql_select_db($database_hostprop, $hostprop);
      $query_Recordset1 = sprintf("SELECT userid, FirstName, Surname, SalaryReq, PositionReq, location, otherComments, skills_offered FROM think_signup WHERE SalaryReq LIKE %s OR PositionReq LIKE %s OR location LIKE %s OR skills_offered LIKE %s", GetSQLValueString("%" . $var_SalaryReq_Recordset1 . "%", "text"),GetSQLValueString("%" . $var_PositionReq_Recordset1 . "%", "text"),GetSQLValueString("%" . $var_location_Recordset1 . "%", "text"),GetSQLValueString("%" . $var_skills_offered_Recordset1, "text"));
      $query_limit_Recordset1 = sprintf("%s LIMIT %d, %d", $query_Recordset1, $startRow_Recordset1, $maxRows_Recordset1);
      $Recordset1 = mysql_query($query_limit_Recordset1, $hostprop) or die(mysql_error());
      $row_Recordset1 = mysql_fetch_assoc($Recordset1);
      the search feilds are
                  <input name="PositionReq" type="text" class="textfeilds" value="Job Title" size="32" />
                  <input name="skills_offered" type="text" class="textfeilds" value="Skills Required" size="32" />
                  <input name="SalaryReq" type="text" class="textfeilds" value="Salary Offered" size="32" />
                  <input name="location" type="text" class="textfeilds" value="Location" size="32" />
      thanks in advance
        • 1. Re: search results displaying all records, please help
          bregent Most Valuable Participant
          That query will only work if the user enters values in all fields, right? Otherwise it will return all rows. How are you testing this?
          • 2. Re: search results displaying all records, please help
            Jonathan Fortis Level 1
            Thats correct, if user inputs a search into only one feild it returns all results, I want it to work if even only one search box is used, I used this logic before and it works fine, but this time it doesnt
            • 3. Re: search results displaying all records, please help
              You could not have used the same logic successfully before - it simply will not work. You are using the LIKE predicate and OR keywords separating your conditions. And you are setting the default value to the SQL wildcard. So if a user doesn't enter a value in a field, all rows from the table will match.
              As I have said before, the best way to solve this is to dynamically build the WHERE clause. You add each field to the WHERE clause only if the user entered a value. Another option, and a bit of a kludge in my option, is to set the default value to something that you know will never appear in the table values, like "XXXXXXX".
              Also, not related to your problem, but I notice that your skills_offered field is not appending the wildcard to the end. Not sure if this was intentional.
              • 4. Re: search results displaying all records, please help
                this is the statment from the previous search that works how i need it
                $var_tk_job_title_Recordset1 = "%";
                if (isset($_GET["tk_job_title"])) {
                  $var_tk_job_title_Recordset1 = $_GET["tk_job_title"];
                $var_tk_job_location_Recordset1 = "%";
                if (isset($_GET["tk_job_location"])) {
                  $var_tk_job_location_Recordset1 = $_GET["tk_job_location"];
                $var_tk_job_salary_Recordset1 = "%";
                if (isset($_GET["tk_job_salary"])) {
                  $var_tk_job_salary_Recordset1 = $_GET["tk_job_salary"];
                $query_Recordset1 = sprintf("SELECT tk_job_title, tk_job_location, tk_job_salary, LEFT(tk_job_desc,200) as truncated_job_desc FROM think_jobsearch WHERE tk_job_title LIKE %s OR tk_job_location LIKE %s OR tk_job_salary LIKE %s", GetSQLValueString("%" . $var_tk_job_title_Recordset1 . "%", "text"),GetSQLValueString("%" . $var_tk_job_location_Recordset1 . "%", "text"),GetSQLValueString("%" . $var_tk_job_salary_Recordset1 . "%", "text"));
                and thats why i replicated it for the new search
                was this in a previous post?
                .>Also, not related to your problem, but I notice that your skills_offered field is not appending the wildcard to the end. Not sure if this was intentional
                no this was not intentional, i have amended this
                • 5. Re: search results displaying all records, please help
                  also i tried using the xxxxx as the defualt value instead of the SQL wildcard % and no results are displayed??
                  • 6. Re: search results displaying all records, please help
                    Can you show me the complete script where you have the default values set to 'xxxxxxx' and tell us what values are being entered in the search criteria when no results are displayed. Also include the code from your search form.
                    • 7. Re: search results displaying all records, please help
                      $currentPage = $_SERVER["PHP_SELF"];
                      $maxRows_Recordset1 = 5;
                      $pageNum_Recordset1 = 0;
                      if (isset($_GET['pageNum_Recordset1'])) {
                        $pageNum_Recordset1 = $_GET['pageNum_Recordset1'];
                      $startRow_Recordset1 = $pageNum_Recordset1 * $maxRows_Recordset1;
                      $var_SalaryReq_Recordset1 = "xxxxx";
                      $var_skills_offered_Recordset1 = "xxxxx";
                      $var_location_Recordset1 = "xxxxx";
                      $var_PositionReq_Recordset1 = "xxxxx";
                      $query_Recordset1 = sprintf("SELECT SalaryReq, skills_offered, location, PositionReq, otherComments, userid, FirstName, Surname FROM think_signup WHERE SalaryReq LIKE %s OR PositionReq LIKE %s OR location LIKE %s OR skills_offered LIKE %s", GetSQLValueString("%" . $var_SalaryReq_Recordset1 . "%", "text"),GetSQLValueString("%" . $var_skills_offered_Recordset1 . "%", "text"),GetSQLValueString("%" . $var_location_Recordset1 . "%", "text"),GetSQLValueString("%" . $var_PositionReq_Recordset1 . "%", "text"));
                      if (isset($_GET['totalRows_Recordset1'])) {
                        $totalRows_Recordset1 = $_GET['totalRows_Recordset1'];
                      } else {
                        $all_Recordset1 = mysql_query($query_Recordset1);
                        $totalRows_Recordset1 = mysql_num_rows($all_Recordset1);
                      $totalPages_Recordset1 = ceil($totalRows_Recordset1/$maxRows_Recordset1)-1;
                      $queryString_Recordset1 = "";
                      if (!empty($_SERVER['QUERY_STRING'])) {
                        $params = explode("&", $_SERVER['QUERY_STRING']);
                        $newParams = array();
                        foreach ($params as $param) {
                          if (stristr($param, "pageNum_Recordset1") == false &&
                              stristr($param, "totalRows_Recordset1") == false) {
                            array_push($newParams, $param);
                        if (count($newParams) != 0) {
                          $queryString_Recordset1 = "&" . htmlentities(implode("&", $newParams));
                      $queryString_Recordset1 = sprintf("&totalRows_Recordset1=%d%s", $totalRows_Recordset1, $queryString_Recordset1);
                      the form is
                      examples of search criteria are job title would be say police officer, location would be say london
                      when using xxxx no results are being dispalyed
                      • 8. Re: search results displaying all records, please help
                        Please, I need to see the entire form, everything between and including the FORM tags.
                        • 9. Re: search results displaying all records, please help
                          <form id="form3" name="form3" method="post" action="../candidate-search-results.php">
                                    <p>
                          <td colspan="2"><img name="CANDSEARCH_r1_c1_s1" src="../images/CANDSEARCH_r1_c1_s1.png" width="74" height="5" border="0" id="CANDSEARCH_r1_c1_s1" alt="" /></td>
                                        <td rowspan="3"><a href="../candidate-search-results.php" onmouseout="MM_nbGroup('out');" onmouseover="MM_nbGroup('over','CANDSEARCH_r1_c3_s1','images/CANDSEARCH_r1_c3_s2.png','im ages/CANDSEARCH_r1_c3_s4.png',1);" onclick="MM_nbGroup('down','navbar1','CANDSEARCH_r1_c3_s1','images/CANDSEARCH_r1_c3_s3.pn g',1);">
                                          <input type="image" src="../images/CANDSEARCH_r1_c3_s1.png" width="50" height="17" border="0" id="CANDSEARCH_r1_c3_s1" alt="" />
                                  </form>
                          • 10. Re: search results displaying all records, please help
                            i have just noticed something there is a double line to the ../candidate-search-results.php
                            one is the form tag and the other in the search image, would this be the problem?
                            • 11. Re: search results displaying all records, please help
                              Is the above what u needed, I re
                              moved the other button link but that di
                              dnt do anything
                              • 12. Re: search results displaying all records, please help
                                Look at the code. What method are you using to submit the form? What method are you using to retrieve the form values !
                                • 13. Re: search results displaying all records, please help
                                  OK,i see that when i posted to the thread, i have now changed the form to GET but it is still not working, if i change the default value to the wildcard % it displays all the results but if i change it to xxxxx i get no results, so i know the way the form was sent was incorrect but now being changed i am still getting the same results.
                                  • 14. Re: search results displaying all records, please help
                                    So now you need to start troubleshooting by echoing values to the screen. Start by outputting $query_Recordset1 and paste the results here.
                                    • 15. Re: search results displaying all records, please help
                                      i put an echo at the end of the script, i then done a search on the location and the echo gave the following resutls
                                      SELECT SalaryReq, skills_offered, location, PositionReq, otherComments, userid, FirstName, Surname FROM think_signup WHERE SalaryReq LIKE '%%%' OR PositionReq LIKE '%%%' OR location LIKE '%%%' OR skills_offered LIKE '%%%'
                                      • 16. Re: search results displaying all records, please help
                                        Where is the submit button on your form?
                                        • 17. Re: search results displaying all records, please help
                                          i have added the submit value as below
                                          <input type="image" src="../images/CANDSEARCH_r1_c3_s1.png" width="50" height="17" border="0" value="Submit" id="CANDSEARCH_r1_c3_s1" alt="" />
                                          and still showing the same as before
                                          • 18. Re: search results displaying all records, please help
                                            Why are you populating a value in the text field? How are you clearning that out before submitting?
                                            This tells me that your default value is still '%' and you have NOT changed it to 'xxxxx'.  Or, you are using some unposted method to populate it with '%'.
                                            • 19. Re: search results displaying all records, please help
                                              this is to show the user what to input, i am not clearing it before submission (this is the same as the other search that working)
                                              sorry i was trying something i have changed the values back and done another echo test
                                              SELECT SalaryReq, skills_offered, location, PositionReq, otherComments, userid, FirstName, Surname FROM think_signup WHERE SalaryReq LIKE '%xxxxx%' OR PositionReq LIKE '%xxxxx%' OR location LIKE '%xxxxx%' OR skills_offered LIKE '%xxxxx%'
                                              • 20. Re: search results displaying all records, please help
                                                Submit the form, and then copy the url from the address bar and post it here.
                                                The only reason it appears to be working is because the default values you put into those fields has not yet appeared in your data. But this is obviously a very poor practice that will eventually lead to trouble. You must always clear out that data before posting.
                                                • 21. Re: search results displaying all records, please help
                                                  http://www.rerecruitment.co.uk/beta/candidate-search-results.php
                                                  it isnt passing any of the information
                                                  the other search that is working is giving the following results
                                                  current-positions.php?tk_job_title=security&tk_job_location=Location&tk_job_salary=Salary& x=87&y=5
                                                  again here is the echo
                                                  • 22. Re: search results displaying all records, please help
                                                    Are you sure you changed the form method to GET? It appears that you have not.
                                                    • 23. Re: search results displaying all records, please help
                                                      <form id="form3" name="form3" method="get" action="../candidate-search-results.php">
                                                      • 24. Re: search results displaying all records, please help
                                                        ok it seem to be a problem with the submit graphic, i will change the image, i tried it with a standard button and it worked.
                                                        thanks
                                                        just a quick one though,
                                                        should i change the other search page to xxxx rather than the wildcard?
                                                        • 25. Re: search results displaying all records, please help
                                                          its strange becuase some of the feilds are working the job title isnt working and neither is the skills required but the salary offered and location are working now
                                                          • 26. Re: search results displaying all records, please help
                                                            I can't comment without knowing all of the details. If you are using AND to combine conditions, then you probably want to continue using the wildcard. In any case, I wouldn't put default text in the form fields. Use labels to help the user complete the form.
                                                            • 27. Re: search results displaying all records, please help
                                                              When you are not getting the expected results, we need to see the SQL submitted - every time.
                                                              Echo the $query_Recordset1  variable and post the results.
                                                              • 28. Re: search results displaying all records, please help
        in the db i have an input called security in the PositionReq field, then in the skills_offered i have an input called fireman     in the SalaryReq feild i have a neg result and for locatio i have test 12 stored
        searching for jobtitle for security
        SELECT SalaryReq, skills_offered, location, PositionReq, otherComments, userid, FirstName, Surname FROM think_signup WHERE SalaryReq LIKE '%Salary Offered%' OR PositionReq LIKE '%Skills Required%' OR location LIKE '%Location%' OR skills_offered LIKE '%xxxxx%'
        this has no results
        this looks like something is going wrong here??
        searching skills required for fireman
        '%Salary Offered%' OR PositionReq LIKE '%fireman%' OR location LIKE '%Location%' OR skills_offered LIKE '%xxxxx%'
        this has no results
        searching salary required for NEG
        SELECT SalaryReq, skills_offered, location, PositionReq, otherComments, userid, FirstName, Surname FROM think_signup WHERE SalaryReq LIKE '%neg%' OR PositionReq LIKE '%Skills Required%' OR location LIKE '%Location%' OR skills_offered LIKE '%xxxxx%'
        a result is displayed
        searching for test 12
        SELECT SalaryReq, skills_offered, location, PositionReq, otherComments, userid, FirstName, Surname FROM think_signup WHERE SalaryReq LIKE '%Salary Offered%' OR PositionReq LIKE '%Skills Required%' OR location LIKE '%test 12%' OR skills_offered LIKE '%xxxxx%'
        • 29. Re: search results displaying all records, please help
        >this has no results
        Right. Are you expecting a result? You have no search criteria entered, other than the default values you have in the form fields.
        >this has no result
        Right. You are searching for 'fireman' in the PositionReq column, but you stated above that it is in the skills_offered column.
        Why does PositionReq  SalaryReq use proper case naming, while skills_offered uses lower case with an underscore?  Things are a real mess! We've already found about a dozen errors in your code for this relatively simple search form.
        • 30. Re: search results displaying all records, please help
        i did put an input of security, i dont know why it isnt showing any results
        i see that now!, this is a mess
        I dont understand how it has got like this. Is is a problem ( i know its not good practice) to  have an underscore
        or should i go back and start again
        • 31. Re: search results displaying all records, please help
        it looks like all the inputs field are getting muddled up.
        • 32. Re: search results displaying all records, please help
        i found the problem, i have another recordset in the main body of the page. the trouble is the other recordset needs to go throughout the site and need to be inbedded into the non editable region. it is only showing results from the DB. When i insert it into the main site it give problems to the pages that already containing infor from the DB
        • 33. Re: search results displaying all records, please help
        You can use underscores, proper case, camel case -anything that you want. The key is consistency; it makes your code easier to read which results in less coding errors and easier maintenance. Pick a naming convention for your objects and stick with it 100% of the time. You don't need to use the same convention for database objects as you do for php objects - but within each object type (table name, column name, local variable, etc) be consistent. Search the web for 'database naming conventions' and 'php naming conventions' for some ideas.
        • 34. Re: search results displaying all records, please help
        i will read this and try and keep the coding neat
        • 35. Re: search results displaying all records, please help
        Hello, i am testing the search code
        if (isset($_GET['PositionReq'])) {
        $var_PositionReq_Recordset1 = $_GET['PositionReq'];
        in the database i have in the skills_offered column
        good communicator excellent negotiator truck driver
        when i search good communicator i get nothing, when i search excellent negotiator i get nothing, when i search truck driver i get tthe result. i have tried various combinations like good driver and i get nothing
        can anyone help?
        • 36. Re: search results displaying all records, please help
        I've already told you where the problem is. If you echo $query_Recordset1 you'll immediately be able to see the cause.
        • 37. Re: search results displaying all records, please help
        sorry,,,just needed a kick  . "%"
        thanks for the prompt.
        regards
