I have d/loaded a book/file into my ADE library OK , then transferred it over to my Calibre library. However, when I then try to install it on my Sony T1, Calibre says it cannot do so becaues ACSM - how can I convert this into epub so I can get it onto reader please ? And please take pity, I am Mr TechDunce, so kindergarten language please !
There are a couple of things going on here. I'm going to gloss over the
technical stuff first, as you asked, but there are some 'catches' in the
process you'll need to keep in mind, and I'll cover them at the end. I'll
also assume you have a Windows PC.
The normal process of downloading an ebook has a couple of steps. The
first one is that the download site creates a small file of information
about the ebook. This file has a suffix of .ascm. The download site then
interacts with your computer to activate ADE, which reads that file, finds
the ebook and downloads it onto your computer in .epub (or.pdf for those
types of ebooks) format. ADE then can manage the ebook, opening it so you
can read it on your computer, or transferring it to your ereader. The
.ascm file disappears as soon as ADE has started the download.
The next step in the process is to hook up your ereader to your computer,
make sure it's recognized by the computer, and transfer the ebook to it
using ADE. That's done simply, by dragging and dropping the ebook from ADE
to the ereader.
Now, for the 'catches'. The first one is that you should have registered
with Adobe when you downloaded and installed ADE. Next, your ereader needs
to be registered with SONY and you should use the same user ID for that
registration as you used for ADE because ADE looks at the registration
information of your ereader. Using the same ID makes it very simple and
works 99.9% of the time.
Next, SONY ereader registration includes downloading and installing the
Reader Library. If that's not on your computer, then you will have
problems with transfers. ADE doesn't use this library, but apparently the
SONY ereaders check for it when they attach to your computer.
The next catch is that some ereaders are not supported by ADE. Although
it's in the list of supported devices, ADE seems to have problems with
the SONY PRS-T1 when doing a transfer.
The process for hooking up and doing transfers is pretty simple, but needs
to be followed in order: attach the ereader first and power it up if it
doesn't do that itself when you plug it in. Make sure that the computer
recognizes the ereader and has given it a drive letter. Then, start ADE.
If all is well, ADE will show the ereader as an item in the Bookshelf
section of the Library view screen - that's the left hand side of the
screen. You can click and hold your cursor on the title you want to
transfer, then drag it to your ereader and drop it. Repeat as desired.
When you're done with the transfers, you need to detach the ereader
LOGICALLY from your computer first. That means going down to the right
hand corner of the START bar at the bottom of your screen, finding the
little icon that looks like a small computer, and clicking on it. Then,
click on the drive letter assigned to your ereader. Once that's done, you
can close ADE, but DON'T disconnect your ereader physically from the
computer yet. Most of them tell you that they're processing new content or
words to that effect. Wait until that stops and then you can disconnect it.
I hope this helps.
To your other question: since ADE can do the transfers, I don't know why
you transfer an ebook from ADE to your Calibre library. If the ebook is
already in the ADE library as an .epub, then there's no way that Calibre
would see it as an .ascm file. Calibre itself is the same kind of program
as ADE, so you could use it with download sites in a similar way as I
describe above, and bypass ADE altogether if that works better for you with
your T1. Also, you can always go back to the SONY website and get your
ebooks from SONY.
Thanks VERY MUCH - but I have ADE and SonyReader all registered etc... and I prefer Calibre (as do a lot of Sony users) as it's so straightforward and simple !
So I download any book I buy/get(Gutenberg etc..) and "Save to File" ,so it is in my "Downloads" panel/box so I can drag 'n Drop it into Calibre. This is fine, in it goes. It's when I hit "Send to Device" that a box comes up and tells me it's ACSM, and has to be in a format Calibre can handle - ie epub.
Hope this is clear.
Date: Mon, 9 Apr 2012 07:57:43 -0600
To: rugmike@hotmail.co.uk
Subject: Convert ACSM ebook/file to epub....?
Re: Convert ACSM ebook/file to epub....?
created by Frustrated in AZ in Adobe Digital Editions - View the full discussion
There are a couple of things going on here. I'm going to gloss over thetechnical stuff first, as you asked, but there are some 'catches' in theprocess you'll need to keep in mind, and I'll cover them at the end. I'llalso assume you have a Windows PC. The normal process of downloading an ebook has a couple of steps. Thefirst one is that the download site creates a small file of informationabout the ebook. This file has a suffix of .ascm. The download site theninteracts with your computer to activate ADE, which reads that file, findsthe ebook and downloads it onto your computer in .epub (or.pdf for thosetypes of ebooks) format. ADE then can manage the ebook, opening it so youcan read it on your computer, or transferring it to your ereader. The.ascm file disappears as soon as ADE has started the download. The next step in the process is to hook up your ereader to your computer,make sure it's recognized by the computer, and transfer the ebook to itusing ADE. That's done simply, by dragging and dropping the ebook from ADEto the ereader. Now, for the 'catches'. The first one is that you should have registeredwith Adobe when you downloaded and installed ADE. Next, your ereader needsto be registered with SONY and you should use the same user ID for thatregistration as you used for ADE because ADE looks at the registrationinformation of your ereader. Using the same ID makes it very simple andworks 99.9% of the time. Next, SONY ereader registration includes downloading and installing theReader Library. If that's not on your computer, then you will haveproblems with transfers. ADE doesn't use this library, but apparently theSONY ereaders check for it when they attach to your computer. The next catch is that some ereaders are not supported by ADE. Althoughit's in the list of supported devices, ADE seems to have problems withthe SONY PRS-T1 when doing a transfer. The process for hooking up and doing transfers is pretty simple, but needsto be followed in order: attach the ereader first and power it up if itdoesn't do that itself when you plug it in. Make sure that the computerrecognizes the ereader and has given it a drive letter. Then, start ADE.If all is well, ADE will show the ereader as an item in the Bookshelfsection of the Library view screen - that's the left hand side of thescreen. You can click and hold your cursor on the title you want totransfer, then drag it to your ereader and drop it. Repeat as desired.When you're done with the transfers, you need to detach the ereaderLOGICALLY from your computer first. That means going down to the righthand corner of the START bar at the bottom of your screen, finding thelittle icon that looks like a small computer, and clicking on it. Then,click on the drive letter assigned to your ereader. Once that's done, youcan close ADE, but DON'T disconnect your ereader physically from thecomputer yet. Most of them tell you that they're processing new content orwords to that effect. Wait until that stops and then you can disconnect it. I hope this helps. To your other question: since ADE can do the transfers, I don't know whyyou transfer an ebook from ADE to your Calibre library. If the ebook isalready in the ADE library as an .epub, then there's no way that Calibrewould see it as an .ascm file. Calibre itself is the same kind of programas ADE, so you could use it with download sites in a similar way as Idescribe above, and bypass ADE altogether if that works better for you withyour T1. Also, you can always go back to the SONY website and get yourebooks from SONY. ======================
Replies to this message go to everyone subscribed to this thread, not directly to the person who posted the message. To post a reply, either reply to this email or visit the message page:
To unsubscribe from this thread, please visit the message page at . In the Actions box on the right, click the Stop Email Notifications link.
Start a new discussion in Adobe Digital Editions by email or at Adobe Forums
For more information about maintaining your forum email notifications please go to http://forums.adobe.com/message/2936746#2936746.
Quite clear, and very useful. Because what you said means that the .ascm
file did not go through the download process using ADE.
I'm not as clear on the process you used, so let me assume that it went
something like this:
You logged onto Gutenberg and found an ebook to download, then selected the
format for the ebook (.epub) and pressed the button. What should have
happened is that Gutenberg.org would begin the download, and during that
process, you would get a Windows screen that asked you whether you wanted
to OPEN or SAVE the file. If you chose SAVE, then Gutenberg should have
initiated the download and opened ADE, which would use the .ascm file to
find the ebook, then download it to the ADE library as an .epub.
So, let's do a little detective work. Pick the name of one of the ebooks
that seem to be messed up. Open ADE and look at the Library view and see
if that ebook shows up. If it does, then put your cursor on the small
arrow next to the ebook's name, and pick 'Item Info' from the drop-down
box. The information will include the address of the ebook on your
computer, and the ebook's format type. If everything worked correctly, the
ebook will be in the Digital Editions libraries, and the name will have the
.epub extension.
If the ebook doesn't appear in ADE's Library view, then ADE did not convert
the ebook during the download process. There could be several reasons for
this, including a bad definition file (.ascm file) or a missed connection
between the download site and your copy of ADE. If the problem involves
more than one ebook, there's a chance that your copy of ADE isn't
registered properly, and the download site is unable to open it.
Let's start there, because these are the 'normal' problem situations....
Great detective work! Thank you for the information. Very useful.
