1. Re: Adobe Premiere exports white as grey
chac57 Apr 10, 2012 5:41 PM (in response to Helmut1011)1 person found this helpfulIf you have Quicktime 7, open the .mov file with QT7, click file-export-movie to windows media. You will have multiple choices of quality settings.
Good luck
2. Re: Adobe Premiere exports white as grey
Helmut1011 Apr 10, 2012 8:30 PM (in response to chac57)I did this, and guess what - the exported video is again played grey! So I did some more research: uploaded the animation to a webservice and tada: it's white again! So this has nothing to do with my file, but with my computer playback! There must be some setting somewhere that reduces the contrast of movies... what a mess!
3. Re: Adobe Premiere exports white as grey
Jim_Simon Apr 10, 2012 9:58 PM (in response to Helmut1011)this has nothing to do with my file, but with my computer playback!
And that is why computer monitors are never used for quality control. You judge the look and colors only using a properly calibrated external TV.
4. Re: Adobe Premiere exports white as grey
Sieboldianus Apr 11, 2012 10:34 AM (in response to Helmut1011)Jim, this has nothing to do with my computer monitor. It looks like a display driver problem. Unfortunately, installing the newest ATI Drivers didn't help.
If I disable RGB->YUV conversions in VLC Player, the aniomation is diplayed correctly white but unfortunately, Power Point is using Windows Media Player where I can't find such an option.
5. Re: Adobe Premiere exports white as grey
Jim Curtis Apr 11, 2012 11:57 AM (in response to Sieboldianus)I would suggest a few things, more or less in this order:
- Delete your preferences (quit, hold alt and launch Pr), try again.
- Start a new project with different but similar footage, and export again. Any change?
- Uninstall and reinstall Pr.
- If all this fails, you might need to reinstall your OS, as some of the core video functions may be damaged.
I don't share your feeling about ruling out a codec. CoDec is short for Compression/Decompression. You may be compressing fine, but having issues with decompression, or vice-versa.
Don't know if this will help, but there are options in Quicktime and the WMV component for Mac (which I use) that holds settings for gamma filters, etc. And I wonder if there isn't something similar in the Windows side that you may have inadvertently set, or gotten broken because of a file corruption, preference, etc.
Sounds maddening, though. Hope you get it fixed.
6. Re: Adobe Premiere exports white as grey
Sieboldianus Apr 11, 2012 12:31 PM (in response to Jim Curtis)Thank you! I found a detour that worked. Since everything encapsulated in QuickTime MOV format is displayed correctly (also in Windows Media Player), I added WM Player plugin to PP and loaded the QuickTime file with Mpeg4-Codec rendering from premiere. Since I am getting a new laptop in 2 weeks, no need to mess with some deep in-system things that went wrong on this..
7. Re: Adobe Premiere exports white as grey
Jim_Simon Apr 11, 2012 12:44 PM (in response to Sieboldianus)It looks like a display driver problem.
It may well be, but that's exactly why you need a calibrated, external TV for the job of quality control.
Software players, display drivers, even the OS itself can alter the visual display of media on your computer monitor.
8. Re: Adobe Premiere exports white as grey
Jim Curtis Apr 11, 2012 12:50 PM (in response to Helmut1011)Hmm. I do agree that a calibrated external broadcast display is the way to go for accurate QC. But I'm thinking this puzzle isn't a driver, because look again at his screen shot. I presume the white you see behind the grayish still on the left is the Sequence that was exported. And if so, there's a shift all right. One you'd see on any display.
Anyway, Sieboldianus said he found a workaround. Happy ending.
9. Re: Adobe Premiere exports white as grey
Adobeeeeeeeeeeeeeeeeeeeee Apr 25, 2013 3:57 AM (in response to Jim Curtis)1 person found this helpfulI know its a old thread but I just came up against this but with my new Nvidia card - now I see a few fixes on the internet such as messing arround with the quicktime players settings like the blend and alpha for each individual video :O - awful idea! And also turning off the Direct X direct draw and direct 3D settings in the quicktime player was another fix I saw but does affect smoothness in some situations so again not a good idea.
Finaly I decided to look at the nVidia settings today and if I switch the adjust video colour settings from 'video player settings' to 'NVIDIA settings' theres an advanced tab where you can change the dynamic range from the deefault of limited 16 - 235 to full of 0 - 255 - why this setting is on I dont know but it causes me the exact same problem and in full the whites are white again! Bah!
10. Re: Adobe Premiere exports white as grey
distriller Oct 28, 2013 10:51 AM (in response to Adobeeeeeeeeeeeeeeeeeeeee)Thank you so much! At last I understand why QuickTime and VLC showed weird gray instead of white on my Windows & NVIDIA setup. It was super confusing! Indeed the answer was this Dynamic range Full 0-255 at NVIDIA Control Panel -> Video -> Adjust video color settings. Impossible to understand why they would use the limited range as default.
11. Re: Adobe Premiere exports white as grey
RickGates Jun 12, 2015 8:38 AM (in response to distriller)Yes Thanks... this solved the same problem for me. Not sure what NVidia gains by limiting the dynamic range.
12. Re: Adobe Premiere exports white as grey
Daniel_Poffley Apr 6, 2016 3:02 AM (in response to Helmut1011)Typical usage scenarios:
The Limited (16-235) setting is commonly used by many televisions.The Full (0-255) setting may allow more detail in the dark and white areas of some content.
