12 Replies Latest reply on Apr 6, 2016 3:02 AM by Daniel_Poffley
    Adobe Premiere exports white as grey
    Helmut1011
      I have been searching the web for my problem, but I think I am on the wrong path:
      After rendering a 3D-Animation in single PNGs, I imported these to Premiere, added them to a sequence and exported it. The problem I am getting with all codecs and all container-formats (except QuickTime!): white is rendered grey
      Here is a screenshot of comparison final video/ preview in premiere:
      Here is what I tried (and what did not work):
      - applying ProcAmp Effect: no difference
      - rendering preview (preview in premiere looks good) and using preview files for export: white still grey
      - exporting in different container formats and codecs: no results for all windows container file formats: avi, mpeg, H.264 etc.
      - only time it works: exporting to quick time container file (works with all codecs!) - so I have the feeling it is not a codec-issue
      - using all combination of settings: Maximum Render Quality and Render at Maximum Depth, using PAL or NTSC etc.
      So, at least there is a way to export it correctly using Quicktime as the file format. But I need to put this animation in a power point presentation for a presentation, and unfortunateley QuickTime is the only format not supported by PP..
      Thank you for any suggestions or hints..
        • 1. Re: Adobe Premiere exports white as grey
          chac57
          If you have Quicktime 7, open the .mov file with QT7, click file-export-movie to windows media. You will have multiple choices of quality settings.
          Good luck
          1 person found this helpful
          • 2. Re: Adobe Premiere exports white as grey
            Helmut1011 Level 1
            I did this, and guess what - the exported video is again played grey! So I did some more research: uploaded the animation to a webservice and tada: it's white again! So this has nothing to do with my file, but with my computer playback! There must be some setting somewhere that reduces the contrast of movies... what a mess!
            • 3. Re: Adobe Premiere exports white as grey
              Jim_Simon Level 8
              And that is why computer monitors are never used for quality control.  You judge the look and colors only using a properly calibrated external TV.
              • 4. Re: Adobe Premiere exports white as grey
                Sieboldianus
                Jim, this has nothing to do with my computer monitor. It looks like a display driver problem. Unfortunately, installing the newest ATI Drivers didn't help.
                If I disable RGB->YUV conversions in VLC Player, the aniomation is diplayed correctly white but unfortunately, Power Point is using Windows Media Player where I can't find such an option.
                • 5. Re: Adobe Premiere exports white as grey
                  Jim Curtis Level 3
                  I would suggest a few things, more or less in this order:
                  - Delete your preferences (quit, hold alt and launch Pr), try again.
                  - Start a new project with different but similar footage, and export again.  Any change?
                  - Uninstall and reinstall Pr.
                  - If all this fails, you might need to reinstall your OS, as some of the core video functions may be damaged.
                  I don't share your feeling about ruling out a codec.  CoDec is short for Compression/Decompression.  You may be compressing fine, but having issues with decompression, or vice-versa.
                  Don't know if this will help, but there are options in Quicktime and the WMV component for Mac (which I use) that holds settings for gamma filters, etc.  And I wonder if there isn't something similar in the Windows side that you may have inadvertently set, or gotten broken because of a file corruption, preference, etc.
                  Sounds maddening, though.  Hope you get it fixed.
                  • 6. Re: Adobe Premiere exports white as grey
                    Sieboldianus Level 1
                    Thank you! I found a detour that worked. Since everything encapsulated in QuickTime MOV format is displayed correctly (also in Windows Media Player), I added WM Player plugin to PP and loaded the QuickTime file with Mpeg4-Codec rendering from premiere. Since I am getting a new laptop in 2 weeks, no need to mess with some deep in-system things that went wrong on this..
                    • 7. Re: Adobe Premiere exports white as grey
                      Jim_Simon Level 8
                      It may well be, but that's exactly why you need a calibrated, external TV for the job of quality control.
                      Software players, display drivers, even the OS itself can alter the visual display of media on your computer monitor.
                      • 8. Re: Adobe Premiere exports white as grey
                        Jim Curtis Level 3
                        Hmm.  I do agree that a calibrated external broadcast display is the way to go for accurate QC.  But I'm thinking this puzzle isn't a driver, because look again at his screen shot.  I presume the white you see behind the grayish still on the left is the Sequence that was exported.  And if so, there's a shift all right.  One you'd see on any display.
                        Anyway, Sieboldianus said he found a workaround.  Happy ending.
                        • 9. Re: Adobe Premiere exports white as grey
                          Adobeeeeeeeeeeeeeeeeeeeee Level 1
                          I know its a old thread but I just came up against this but with my new Nvidia card - now I see a few fixes on the internet such as messing arround with the quicktime players settings like the blend and alpha for each individual video :O  - awful idea! And also turning off the Direct X direct draw and direct 3D settings in the quicktime player was another fix I saw but does affect smoothness in some situations so again not a good idea.
                          Finaly I decided to look at the nVidia settings today and if I switch the adjust video colour settings from 'video player settings' to 'NVIDIA settings' theres an advanced tab where you can change the dynamic range from the deefault of limited 16 - 235 to full of 0 - 255 - why this setting is on I dont know but it causes me the exact same problem and in full the whites are white again! Bah!
                          • 10. Re: Adobe Premiere exports white as grey
                            distriller Level 1
                            Thank you so much! At last I understand why QuickTime and VLC showed weird gray instead of white on my Windows & NVIDIA setup. It was super confusing! Indeed the answer was this Dynamic range Full 0-255 at NVIDIA Control Panel -> Video -> Adjust video color settings. Impossible to understand why they would use the limited range as default.
                            • 11. Re: Adobe Premiere exports white as grey
                              RickGates Level 1
                              Yes Thanks... this solved the same problem for me.  Not sure what NVidia gains by limiting the dynamic range.
                              • 12. Re: Adobe Premiere exports white as grey
                                Daniel_Poffley
                                Typical usage scenarios:
                                The Limited (16-235) setting is commonly used by many televisions.
                                The Full (0-255) setting may allow more detail in the dark and white areas of some content.
