7 Replies Latest reply on Dec 1, 2014 3:00 AM by BKBK
    "java.lang.ClassNotFoundException" when creating a CFC instance inside a webservice
    PeteComcar
      This question is also up on stack overflow: http://stackoverflow.com/questions/10089962/coldfusion-web-service-failing-to-see-componen t
      I've got a CFC that I'm going to access with ?wsdl as a SOAP webservice.
      If I call the CFC directly in a browser, my results render fine:
          http://server/webservice/calc.cfc?method=doStuff&foo=bar
      If I try to access it as a web service:
          ws = CreateObject("webservice", 'http://server/webservice/calc.cfc?wsdl');
          result = ws.doStuff('bar');
      I get an error:
      Cannot perform web service invocation doStuff.
      The fault returned when invoking the web service operation is:
      AxisFault
      faultCode
      : {http://schemas.xmlsoap.org/soap/envelope/}Server.userException
      faultSubcode
      faultString
      : coldfusion.xml.rpc.CFCInvocationException:
      [coldfusion.xml.rpc.CFCInvocationException : [java.lang.ClassNotFoundException :
      com
      .calculations.calc][java.lang.NullPointerException : null]]
      faultActor
      faultNode
      faultDetail
      {http://xml.apache.org/axis/}stackTrace:coldfusion.xml.rpc.CFCInvocationException:          [coldfusion.xml.rpc.CFCInvocationException : [java.lang.ClassNotFoundException :
      com
          at     coldfusion
      .xml.rpc.CFComponentSkeleton.__createCFCInvocationException(CFComponentSkeleton.java:733)
          at coldfusion
      .xml.rpc.CFComponentSkeleton.__convertOut(CFComponentSkeleton.java:359)
          at webservice
      .calc.doStuff(/var/www/vhosts/server/httpdocs/webservice/calc.cfc)
      at sun
      .reflect.NativeMethodAccessorImpl.invoke0(Native Method)
      at sun
      .reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
      at sun
      .r... ''
      The problem is because the doStuff function is declaring an instance of a CFC inside it:
      remote struct function doStuff(foo) {
      var objReturn = {};
          objReturn
      .msg = 'A message';
      // do a calculation
      var objCalc = new com.calculations.calc(foo);
          objReturn
      .calc = objCalc;
      return objReturn;
      So my CFC that I'm using as a webservice has got another CFC being declared inside a function. Browsing directly to my webservice CFC works fine, but trying to call it using the CreateObject/webservice route fails, as it can't create an instance of the **com.calculations.calc** component.
      It doesn't error, wierdly, if I comment out the objReturn.calc = objCalc line. So it seems I can create the instance, but the error isn't thrown till I assign it to my return struct.
      Also I've found, If I refresh the page a few times, sometimes the error changes to:
      AxisFault
      faultCode
      faultSubcode
      faultString
          com
      .calculations.calc][coldfusion.xml.rpc.CFCInvocationException :
          returnType must     be
      defined for remote CFC functions.]]
           faultActor
           faultNode
           faultDetail
          com
          returnType must be
          at coldfusion
      at coldfusion
      at webservices
      .TaxCalc.feed.getTaxCalc(/var/www/vhosts/server/httpdocs/webservice/calc.cfc)
      at sun
      .reflect.Nat... ''
      Message was edited by: PeteComcar - impvoed code formatting and added returntype update
