5 Replies Latest reply: Apr 11, 2012 8:42 AM by _spoboyle RSS
    How to manipulate a bitmap loaded through FileReference.load() ?
    Venian Community Member
      Hi there,
      I'm loading a bitmap with FileReference.load() and than dump the byteArray into a Loader object and than add that loader object to stage.
      The problem is that regardless if I load the loader into a Sprite or add it to the stage, neither the loader or the sprite don't have width or height. It's always 0. So I can't scale the image as I don't know it's dimensions.
      Does anyone had this problem before and found a solution?
      Thank you!
        • 1. Re: How to manipulate a bitmap loaded through FileReference.load() ?
          _spoboyle Community Member
          this code works
          package
                    import flash.display.Loader;
                    import flash.display.LoaderInfo;
                    import flash.display.Sprite;
                    import flash.events.Event;
                    import flash.events.MouseEvent;
                    import flash.net.FileFilter;
                    import flash.net.FileReference;
                    import flash.text.TextField;
                    import flash.text.TextFieldAutoSize;
                    public class Main extends Sprite
                              private var fileRef:FileReference;
                              public function Main():void
                                        if (stage)
                                                  init();
                                        else
                                                  addEventListener(Event.ADDED_TO_STAGE, init);
                              public function init(e:Event = null):void
                                        removeEventListener(Event.ADDED_TO_STAGE, init);
                                        fileRef = new FileReference();
                                        stage.addEventListener(MouseEvent.MOUSE_DOWN, onDown);
                                        var txt:TextField = new TextField();
                                        addChild(txt);
                                        txt.autoSize = TextFieldAutoSize.LEFT;
                                        txt.x = txt.y = 20;
                                        txt.text = "click anywhere to load an image file...";
                              private function onDown(evt:MouseEvent):void{
                                        fileRef.browse([new FileFilter("Images", "*.jpg;*.gif;*.png")]);
                                        fileRef.addEventListener(Event.SELECT, onSelected);
                                        stage.removeEventListener(MouseEvent.MOUSE_DOWN, onDown);
                              private function onSelected(evt:Event):void{
                                        fileRef.addEventListener(Event.COMPLETE, onLoaded);
                                        fileRef.load();
                                        fileRef.removeEventListener(Event.SELECT, onSelected);
                              private function onLoaded(evt:Event):void{
                                        var loader:Loader = new Loader();
                                        loader.contentLoaderInfo.addEventListener(Event.COMPLETE, onComplete);
                                        loader.loadBytes(evt.target.data);
                                        addChild(loader);
                                        fileRef.removeEventListener(Event.COMPLETE, onLoaded);
                              private function onComplete(e:Event):void
                                        var loaderInfo:LoaderInfo = e.target as LoaderInfo;
                                        loaderInfo.removeEventListener(Event.COMPLETE, onComplete);
                                        var loader:Loader = loaderInfo.loader;
                                        trace("loader size: ", loader.width, loader.height);
          • 2. Re: How to manipulate a bitmap loaded through FileReference.load() ?
            Thank you.
            But I know that method works, that's the method to load the image. The problem is that after you load it, it has 0 (zero) width and height even though the image displays. So I can't manipulate it as I can't find it's width and height.
            • 3. Re: How to manipulate a bitmap loaded through FileReference.load() ?
              sorry i initially left a bit off and have since updated the code.
              if you try and get the width and height of loader just after you call loadBytes you will get 0, 0
              you have to setup and eventlistener for Event.COMPLETE and when you receive that you can access the width and height
              • 4. Re: How to manipulate a bitmap loaded through FileReference.load() ?
                I see.
                I didn't though that loadBytes was actually a loading process which of courses needs an onComplete event. It though it just dumps the bytes into the loader object since the image is already loaded into RAM.
                Tnx mate!
                • 5. Re: How to manipulate a bitmap loaded through FileReference.load() ?
                  no worries
                  the file reference loads the bytes into a ByteArray. Loader then needs to load the bytes from the ByteArray. It will be pretty quick but you still have to wait
