I have some java code that I need to add within the header of every topic in my help project. Is there an easy way to do this instead of individually adding topic by topic?
What version of RH are you using? What do you mean by header? The section in HTML or just in the top of every topic?
Try a master page/template. You can create a header and add the code in there. Assign the master page to all topics et voila.
Greet,
Willam
sorry, I should be more specific....I'm using Robohelp 9 and it's not a template change that I'm making (such as a logo I want to appear at the top corner of every page) but a piece of code (google analytics to be specific) that needs to be added to every page to be able to track usage. The code needs to go on every page in order to analyze it.
This is something you probably only want to do in your ouput. The GA code must be placed directly in front of the </head> tag, so a simple find and replace will help. Just replace </head> with the google code + '</head>'.
Greet,
Willam
that would make sense to only add to the output. Can I do a find and replace all to the output files within robohelp or is there a better tool for that purpose?
We use a tool called PowerGREP 4 to manipulate the output files. That may help.
