trying to install Acrobat X Standard from disc. Computer gives me message that I have not met the system requirements. But I have, so what do I do?
Mostlikely your windows vista is still SP1. Update it to SP2 and it should work.
What are your system info....
check here http://www.adobe.com/products/acrobatstandard/tech-specs.html and compare
First check form the below link that you actually meet the system requirements.
http://www.adobe.com/products/acrobatpro/tech-specs.html
If you do, then copy the contents of the disc to a folder on the desktop and try running the installer and check if it works.
Windows Vista Home Premium
AMD 64x2 Dual Core Processor 5600 2.80 GHz
Memory 2942 MB
32 bit system
copied disc to desktop, tried to run it and got same message.
please attach the install.log file(c:\Program Files\CommonFiles\Adobe\Installers\[Adobe Application name<date>].log.gz)
What's your screen resolution? A lot of such failures hinge on this trivial thing, meaning that the installer may not read the resolution correctly, even though it is actuall quite large. Can happen on notebooks with external graphics output or desktop machines with multiple displays that are conencted in an odd order... Check your graphics driver and update it, if necessary.
Mylenium
Willy P had the solution for me. I hadn't upgraded to Service Pak 2. Thank you for your help. bestoftmz
Mylenium is right ,,,,,,What you have posted are not the determining factor for the software to meet the requirement,
Please check the link provided my me in earlier post and compare it with yours , those are the minimum requirement anyone of them if missing could cause this issue.
Willy P had my solution. Thank you for your help. !!! bestoftmz
Willy- you had the right answer for me. My service pak was still on 1. Thank you for your help. Much appreciated
