4 Replies Latest reply: Apr 12, 2012 7:14 AM by the_wine_snob RSS
    Divx Plus
    steve29106335
      Can I make a movie using Divx Plus in Premiere Elements?
        • 1. Re: Divx Plus
          Steve Grisetti CommunityMVP
          Divx is not an editable format, and it certainly won't work in Premiere Elements.
          You may be able to convert it to a DV-AVI using a program like Super, per the FAQs to the right of this forum, however, and then you can edit it in this program.
          http://forums.adobe.com/thread/415317
          • 2. Re: Divx Plus
            steve29106335 Community Member
            Not asking can I edit Divx Plus, will it make a Divx Plus movie?
            • 3. Re: Divx Plus
              It will make a Divx movie.
              You may need to use another processor to convert to Divx Plus.
              • 4. Re: Divx Plus
                the_wine_snob CommunityMVP
                While I have not used the "Plus" version yet, I have Exported/Shared to DivX fairly often.
                In PrE, one would install the necessary CODEC's, and then under Export/Share, choose MS AVI. At Advanced, the Compressor can be chosen. The default is CinePak by Radius (a very old, and virtually useless CODEC), but from the drop-down, DivX Plus should be available.
                Unless there is some issue with the Plus version, it should Export/Share just fine.
                There is also a suite of DivX utilities, and one of those is their Pro Encoder. If one were to Exprt/Share in another format, that Encoder will do the compression. The old "Pro" suite was US $ 39, but I have not checked lately.
                Good luck,
                Hunt
