Free barcode generator?
Jan 30, 2008 Jan 30, 2008
Does anyone know of a free or 'cheap' barcode generator that will work with
CF?
11.0K
Guest
Jan 31, 2008 Jan 31, 2008
Looks like that is all about making charts? Where is something about
generating barcodes?
"natg504" <webforumsuser@macromedia.com> wrote in message
news:fnsjfp$sv$1@forums.macromedia.com...
> http://www.fusioncharts.com/free/
Guest
Feb 01, 2008 Feb 01, 2008
You may be able to get away with Code 39 font at http://www.barcodesinc.com/free-barcode-font/
Apr 12, 2012 Apr 12, 2012
also im found Code 128 fully functional barcode generator http://www.mbcestore.com.mx/generador/codigo-de-barras/, just linked to my webservice/CFapp and im request string and return image with barcode very usefull
Newsgroup_User wrote:
Does anyone know of a free or 'cheap' barcode generator that will work with CF?
Barbecue.
Apr 20, 2012 Apr 20, 2012
Hello one and all,
ColdFusion can go even one better. You can use the iText library, which currently ships with ColdFusion, to generate barcodes!
Here is a proof of concept:
<cfscript>
codeEAN = createobject("java","com.lowagie.text.pdf.BarcodeEAN");
codeEAN.setCodeType(codeEAN.EAN13);
codeEAN.setCode("4902555131719");
color =  createobject("java","java.awt.Color");
image = codeEAN.createAwtImage(color.black, color.white);
bufferedImage = createObject("java", "java.awt.image.BufferedImage");
bufferedImageType = bufferedImage.TYPE_BYTE_GRAY;
bufferedImage = bufferedImage.init(image.getWidth(JavaCast("null", "")),image.getHeight(JavaCast("null", "")), bufferedImageType);
graphics2D = bufferedImage.createGraphics();
graphics2D.drawImage(image,0,0,JavaCast("null", ""));
barcodeImage = imageNew(bufferedImage);
</cfscript>
<cfimage action="writeToBrowser" source="#barcodeImage#" format="jpg">
Valorous Hero ,
Nice job!  One shortcut you could add is grabbing the graphics object from the CF image instead of creating a new bufferedImage (slight savings). That is a trick I have used in the past:
ie     ...
        width  = image.getWidth(JavaCast("null", ""));
        height = image.getHeight(JavaCast("null", ""));
        cfImage = imageNew("", width, height);
        graphics = ImageGetBufferedImage(cfImage).getGraphics();
        graphics.drawImage(image,0,0,JavaCast("null", ""));
Mar 23, 2013 Mar 23, 2013
Hi BKBK,
Since I found your post I'm looking for documentation on the iText Coldfusion's library sintax. I'll try to generate Code128C barcodes but not found the exact sintax based on your code.
Thanks in advance.
See the iText API for Barcode.
An example:
<cfscript>
code128= createobject("java","com.lowagie.text.pdf.Barcode128");
code128.setCodeType(code128.CODE128);
/* Set the code to generate */
code128.setCode("0123456789");
image = code128.createAwtImage(color.black, color.white);
</cfscript>
<!--- Output the code as an image --->
Mar 25, 2013 Mar 25, 2013
Great! It works like a charm!
However I don't understand how to apply the API specifications you point me to, to the ColdFusion script.
I try to set the height and the width of the barcode but haven't seen where and how.
If I could take advantage of your knoledge one more time... 😉
Thanks in advance.
Participant ,
If you ever need QR codes you can use my project on riaforge http://qrtoad.riaforge.org/ It could do barcodes too.. just been too lazy to add it.
Mar 27, 2013 Mar 27, 2013
It looks great! If I never need QR i will use it.
Now I still need to solve my barcode size problems.
Thanks.
I had a look at the API and I can't see how to set the barcode width. I can set its height with "code128.setBarHeight(x);" but none of the parameters I tried (setX, setN...) seems to affect the overall size of the barcode and, as it gets rendered, it's unusable because the bars are too close to be read once printed.
I don't know where to look further.
If I use Coldfusion's ability to resize the resulting image, the result is too fuzzy because the bars become blured and the barcode reader can't read them properly.
I'm stuck!
Any suggestion will be much appreciated.
Thanks in advance.
Solved with Barbecue http://barbecue.sourceforge.net   !!
Thnaks.
Participant ,
Very cool.
Jun 20, 2013 Jun 20, 2013
Jun 08, 2022 Jun 08, 2022
<cfimage action="writeToBrowser" source="#barcodeImage#" format="jpg" width="400" height="100">
Nov 09, 2022 Nov 09, 2022
I copied the code and it does create a barcode, awesome.  How do you set a varabile for the barcode?
Nov 11, 2022 Nov 11, 2022
quote
By @philr3814055
A variable has already been set for it. 🙂 The name of the variable is barcodeImage.
For example, if you wished to save the barcode as a Jpeg file, you could do something like this at the end:
<!--- Saves barcode to current directory --->
<cfimage action="write" destination="#expandpath('myBarcode.jpg')#" source="#barcodeImage#"
Documentation
