3. Re: Free barcode generator?
Newsgroup_User Jan 31, 2008 2:09 PM (in response to Newsgroup_User)Looks like that is all about making charts? Where is something about
generating barcodes?
"natg504" <webforumsuser@macromedia.com> wrote in message
news:fnsjfp$sv$1@forums.macromedia.com...
> http://www.fusioncharts.com/free/
4. Re: Free barcode generator?
jdeline Feb 1, 2008 9:53 AM (in response to Newsgroup_User)You may be able to get away with Code 39 font at http://www.barcodesinc.com/free-barcode-font/ -
5. Re: Free barcode generator?
kwmxz-6uDDUu Apr 12, 2012 10:38 AM (in response to Newsgroup_User)also im found Code 128 fully functional barcode generator http://www.mbcestore.com.mx/generador/codigo-de-barras/, just linked to my webservice/CFapp and im request string and return image with barcode very usefull
6. Re: Free barcode generator?
BKBK Apr 12, 2012 11:49 AM (in response to Newsgroup_User)Newsgroup_User wrote:
7. Re: Free barcode generator?
BKBK Apr 20, 2012 4:32 AM (in response to Newsgroup_User)Newsgroup_User wrote:
Hello one and all,
ColdFusion can go even one better. You can use the iText library, which currently ships with ColdFusion, to generate barcodes!
Here is a proof of concept:
<cfscript>
codeEAN = createobject("java","com.lowagie.text.pdf.BarcodeEAN");
codeEAN.setCodeType(codeEAN.EAN13);
codeEAN.setCode("4902555131719");
color = createobject("java","java.awt.Color");
image = codeEAN.createAwtImage(color.black, color.white);
bufferedImage = createObject("java", "java.awt.image.BufferedImage");
bufferedImageType = bufferedImage.TYPE_BYTE_GRAY;
bufferedImage = bufferedImage.init(image.getWidth(JavaCast("null", "")),image.getHeight(JavaCast("null", "")), bufferedImageType);
graphics2D = bufferedImage.createGraphics();
graphics2D.drawImage(image,0,0,JavaCast("null", ""));
barcodeImage = imageNew(bufferedImage);
</cfscript>
<cfimage action="writeToBrowser" source="#barcodeImage#" format="jpg">
8. Re: Free barcode generator?
-==cfSearching==- Apr 20, 2012 8:56 AM (in response to BKBK)Nice job! One shortcut you could add is grabbing the graphics object from the CF image instead of creating a new bufferedImage (slight savings). That is a trick I have used in the past:
ie ...
width = image.getWidth(JavaCast("null", ""));
height = image.getHeight(JavaCast("null", ""));
cfImage = imageNew("", width, height);
graphics = ImageGetBufferedImage(cfImage).getGraphics();
graphics.drawImage(image,0,0,JavaCast("null", ""));
9. Re: Free barcode generator?
JaumeCM Mar 23, 2013 12:01 PM (in response to BKBK)Hi BKBK,
Since I found your post I'm looking for documentation on the iText Coldfusion's library sintax. I'll try to generate Code128C barcodes but not found the exact sintax based on your code.
Thanks in advance.
10. Re: Free barcode generator?
BKBK Mar 23, 2013 2:02 PM (in response to JaumeCM)See the iText API for Barcode.
An example:
<cfscript>
code128= createobject("java","com.lowagie.text.pdf.Barcode128");
code128.setCodeType(code128.CODE128);
/* Set the code to generate */
code128.setCode("0123456789");
image = code128.createAwtImage(color.black, color.white);
</cfscript>
<!--- Output the code as an image --->
11. Re: Free barcode generator?
JaumeCM Mar 25, 2013 1:52 AM (in response to BKBK)Great! It works like a charm!
However I don't understand how to apply the API specifications you point me to, to the ColdFusion script.
I try to set the height and the width of the barcode but haven't seen where and how.
If I could take advantage of your knoledge one more time... ;-)
Thanks in advance.
12. Re: Free barcode generator?
Tim Cunningham-ACP Mar 25, 2013 6:44 AM (in response to JaumeCM)If you ever need QR codes you can use my project on riaforge http://qrtoad.riaforge.org/ It could do barcodes too.. just been too lazy to add it.
13. Re: Free barcode generator?
JaumeCM Mar 27, 2013 3:29 AM (in response to Tim Cunningham-ACP)It looks great! If I never need QR i will use it.
Now I still need to solve my barcode size problems.
Thanks.
14. Re: Free barcode generator?
JaumeCM Mar 27, 2013 3:34 AM (in response to BKBK)I had a look at the API and I can't see how to set the barcode width. I can set its height with "code128.setBarHeight(x);" but none of the parameters I tried (setX, setN...) seems to affect the overall size of the barcode and, as it gets rendered, it's unusable because the bars are too close to be read once printed.
I don't know where to look further.
If I use Coldfusion's ability to resize the resulting image, the result is too fuzzy because the bars become blured and the barcode reader can't read them properly.
I'm stuck!
Any suggestion will be much appreciated.
Thanks in advance.
15. Re: Free barcode generator?
JaumeCM Mar 27, 2013 9:46 AM (in response to JaumeCM)Solved with Barbecue http://barbecue.sourceforge.net !!
Thnaks.
16. Re: Free barcode generator?
Tim Cunningham-ACP Mar 27, 2013 10:50 AM (in response to JaumeCM)Very cool.
17. Re: Free barcode generator?
peerewe Jun 20, 2013 7:57 PM (in response to JaumeCM)Check this free version of barcode generator:http://www.onbarcode.com/tutorial/vb-net-barcode-create-net-windows.html
