1. Re: Share You tube too long - not
Steve Grisetti Apr 12, 2012 8:40 AM (in response to ;oiHQWEF;OIGhqwe;gofihqe)You can output longer videos for YouTube using this method, as outlined in the FAQs.
http://forums.adobe.com/thread/623549
Now go get some sleep.
2. Re: Share You tube too long - not
the_wine_snob Apr 12, 2012 9:19 AM (in response to ;oiHQWEF;OIGhqwe;gofihqe)Back when PrE 10 was being developed, YouTube had a 10 min. limit on the uploadds. YouTube added "enhanced accounts," but PrE 10 had already been released.
Steve's method is the way to use your enhnaced account, and upload longer Duration material.
My guess is that PrE 11 will reflect the enhanced account uploads, until YouTube makes another change. Over the years, YouTube has been a "moving target."
Good luck,
Hunt
3. Re: Share You tube too long - not
;oiHQWEF;OIGhqwe;gofihqe Apr 12, 2012 10:26 AM (in response to the_wine_snob)I'm not sure how this public relations answer helps me at the moment?
4. Re: Share You tube too long - not
;oiHQWEF;OIGhqwe;gofihqe Apr 12, 2012 10:41 AM (in response to Steve Grisetti)Not sure where the author got his info but these detailed suggestions
ain't in my version 7
5. Re: Share You tube too long - not
Ed.Macke Apr 12, 2012 10:44 AM (in response to ;oiHQWEF;OIGhqwe;gofihqe)You asked "what gives" - Hunt's answer is the "what gives".
You're welcome.
6. Re: Share You tube too long - not
;oiHQWEF;OIGhqwe;gofihqe Apr 12, 2012 10:58 AM (in response to Ed.Macke)The what gives was a rhetorical comment - guess it went over your head
too.
7. Re: Share You tube too long - not
Ed.Macke Apr 12, 2012 11:15 AM (in response to ;oiHQWEF;OIGhqwe;gofihqe)Rhetorical or not, other people reading these posts might benefit from knowing why or why not a certain feature works the way it does or doesn't.
For example, just knowing PRE was purposely designed to limit YouTube videos to 10 minutes tells the user they are not doing something wrong when they see the message about an 11:46 video being too long. Hunt's answer goes on to provide detail on why it was designed that way to help you - or later viewers - understand the reasoning behind the restriction and not be so "tired" of the product's perceived shortcomings.
In any event, everybody here is just trying to help, so a little kindness and gratitude would be lovely.
8. Re: Share You tube too long - not
Steve Grisetti Apr 12, 2012 11:22 AM (in response to Ed.Macke)And just a reminder to Mr. ;0iHQWEF;OIGhqwe;fofi (if that really is your name).
None of us on this forum work for Adobe. In fact, we don't make a penny helping people out. We're here just because we want to help. There's no justification for copping an attitude with us just because you don't like the answer.
So, please. A little appreciation for our efforts is much appreciated.
9. Re: Share You tube too long - not
;oiHQWEF;OIGhqwe;gofihqe Apr 12, 2012 11:48 AM (in response to Ed.Macke)Well, I've posted other videos within the last few months that are over
10 minutes directly from Elements without the error.
All with the same version of Elements 7.
Suddenly I have the restriction.
Further, why did Adobe get into policing YouTube's limitations - let
YouTube do it.
It's a foolish move because as he says "YouTube is a moving target."
I'm certain they weren't thinking of stiffing everyone with a newer
version to "overcome" this problem.
10. Re: Share You tube too long - not
the_wine_snob Apr 12, 2012 11:54 AM (in response to ;oiHQWEF;OIGhqwe;gofihqe)Steve's link helps you, if you just follow it.
Hunt
11. Re: Share You tube too long - not
Steve Grisetti Apr 12, 2012 11:58 AM (in response to the_wine_snob)Otherwise, if you're convinced the program used to output longer segments to YouTube and suddenly doesn't, you may need to figure out what's going on with your computer.
Adobe is not making changes to your 4-year-old software. Any changes must be happening at your end.
Hope you can get to the bottom of it.
12. Re: Share You tube too long - not
the_wine_snob Apr 12, 2012 11:58 AM (in response to ;oiHQWEF;OIGhqwe;gofihqe)It's a foolish move because as he says "YouTube is a moving target."
Obviously, you have not been around very long, doing video to be posted to YouTube. Over the years, their requirements have changed dramatically, their Encoding has changed dramatically, and recently, the limit on their Duration, for certain levels of subscripotion has also changed. To me, that constitutes a "moving target."
Over the last fifteen years, MPEG-2 and DV-AVI have had exactly zero changes. Those constitute a "fixed target."
I think that if I was coming to the forum to look for an answer to my problem, I would check my "attitude" at the door. Remember, no one is here, just to help you figure things out.
Good luck,
Hunt
13. Re: Share You tube too long - not
;oiHQWEF;OIGhqwe;gofihqe Apr 12, 2012 11:59 AM (in response to the_wine_snob)Actually the instructions are good but not relevant to 7.
Lots of the steps are not there.
14. Re: Share You tube too long - not
;oiHQWEF;OIGhqwe;gofihqe Apr 12, 2012 12:07 PM (in response to the_wine_snob)Right.
Thanks for all the help.
See you in differential calculus.
15. Re: Share You tube too long - not
the_wine_snob Apr 12, 2012 12:09 PM (in response to ;oiHQWEF;OIGhqwe;gofihqe)Actually, when I got my Civil Engineering degree, I did quite well in Differential Calculus.
Thank you,
Hunt
