6 Replies Latest reply: Apr 15, 2012 7:11 AM by Production Monkey RSS
    returning to a random cordinate?
    elimann
      basically i have an object set to appear at random co ordinate
      start_x = random(800)
      start_y = 300 + random(500)
      sprite(ch).locH = start_x
      sprite(ch).locV = start_y
      when moving the object and then detect a collision with another object i want it too return to that random coordinate created above so far i can only set it
      eg sprite(ch).locH = -1000
        • 1. Re: returning to a random cordinate?
          Mister MUX Community Member
          It's going to depend on your code but you just need to store the location in either a user-defined sprite property (best method) or a global variable. Where is this code found that you have posted, in a sprite behavior?
          • 2. Re: returning to a random cordinate?
            I am guessing your code is not in a sprite behavior, but that it is in a movie script somewhere. If that is the case it could look like this:
            global gRandomStartingLoc
            gRandomStartingLoc = point(random(800), 300+random(500))
            sprite(ch).loc = gRandomStartingLoc
            Then after the collision just reset the loc again
            • 3. Re: returning to a random cordinate?
              elimann Community Member
              hi, thanks for your reply
              that code i posted above is a sprite behaviour so i dont think the above will work
              • 4. Re: returning to a random cordinate?
                Actually it would, but it would be better to use a sprite property. Same code though.
                property pRandomStartingLoc
                pRandomStartingLoc = point(random(800), 300+random(500))
                sprite(ch).loc = pRandomStartingLoc
                on CollisionHandler me
                     sprite(spriteNum).loc = pRandomStartingLoc
                end
                So is this behavior attached to sprite(ch) ? If so, there's not need to reference the hard coded sprite name. You remove the hard coded sprite name so that it could be applied to another sprite and not need modifying. It makes for more "reuseable" code.
                property spriteNum, pRandomStartingLoc
                end
                Going a step further, suppose you have multiplle sprites with similar behavior, except their random starting loc different. You can remove all hard coded values. This behavior could be applied to any number of sprites without changing the code. Each would be customizable through the parameters dialog.
                property spriteNum, pRandomStartingLoc, pMaxRandomX, pMaxRandomY, pXmodifier, pYmodifier
                on beginSprite me
                  pRandomStartingLoc = point(random(pMaxRandomX) + pXmodifier, random(pMaxRandomY) + pYmodifier)
                end
                end
                on getPropertyDescriptionList
                  description = [:]
                  addProp description,#pMaxRandomX, [#default:800, #format:#integer, #comment:"Max Random LocX"]
                  addProp description,#pMaxRandomY, [#default:800, #format:#integer, #comment:"Max Random LocY"]
                  addProp description,#pXmodifier, [#default:0, #format:#integer, #comment:"Add this amount to the random LocX"]
                  addProp description,#pYmodifier, [#default:0, #format:#integer, #comment:"Add this amount to the random LocY"]
                  return description
                end
                • 5. Re: returning to a random cordinate?
                  thanks it worked. there is another problem i have come across which is seperate
                  heres my dilema
                  i currently have 5 sprites and 5 different set co ordinates for each one to spawn into with individual behaviour scripts, however i want each sprite to spawn into one of the set co ordinate without more than one of them spawning into the same point.
                  so eventually each sprite will spawn into a random set co ordinate
                  is this possible?
                  so something like
                  pRandomStartingLoc = (200,100) (300,100) (400,100) so each sprite spawns into only one set of cordinates without more than one spawning into the same one
                  • 6. Re: returning to a random cordinate?
                    Production Monkey Community Member
                    For fun I modified Mister MUX's behavior to pick random locations with no overlapping sprites.
                    This is accomplished by adding a global list of rects that are in current use, and making sure no new sprite rects overlap any rects in the list.
                    The global list is initialized in a Movie script:
                    global gOccupiedRects -- list of rects that are currently used by sprites
                    on prepareMovie
                      gOccupiedRects = []
                    end  prepareMovie
                    And the modified behavior is:
                    property Sp  -- this sprite
                    global gOccupiedRects -- list of rects that are currently used by sprites. Cleared in movie script
                    on beginSprite me
                      Sp = sprite(spriteNum)
                    Sp.loc = pRandomStartingLoc
                      cnt = 0
                      repeat while (me.overlaps(Sp.rect))
                        cnt = cnt + 1
                        if cnt > 10000 then  -- don' t want to get stuck in an infinite loop
                          put("Can not find non-overlapping location to place sprite. Aborting")
                          abort()
                        end if
                        -- try new random location
                      end repeat
                      gOccupiedRects.add(Sp.rect)
                    end beginSprite
                    -- check if testRect intersects/overlaps any rect in gOccupiedRects list
                    on overlaps me, testRect
                      EmptyRect = rect(0,0,0,0)
                      repeat with aRect in gOccupiedRects
                        if (aRect.intersect(testRect) <> EmptyRect) then return true  -- true means overlap
                      end repeat
                      return false
                    end overlaps
                    end CollisionHandler
                      description = [:]
                      return description
                    end getPropertyDescriptionList
