1. Re: URGENT: Can't enable email for Admin? HELP!
Brad Lawryk Apr 13, 2012 9:29 AM (in response to BaseZero)I may be wrong here but my understanding is that the email you use to get to the admin is by default activated if on the same domain. If the email you set up to access the Partner portal is not the same as the domain you will need to set up a new user in your admin and activate the email for that user.
So I am just guessing that the admin login email you are using is different than the email you are trying to set up?
2. Re: URGENT: Can't enable email for Admin? HELP!
BaseZero Apr 13, 2012 9:34 AM (in response to Brad Lawryk)The email I'm trying to access is the same as the admin email for my Partner Portal. So, if it is activated by default, then why can I not access the webmail with my user password tied to the Partner Portal email "username"?
I've already set up a new user and email is working just fine, so I know that the system in a general sense is functional.
3. Re: URGENT: Can't enable email for Admin? HELP!
BaseZero Apr 13, 2012 9:45 AM (in response to BaseZero)More information here:
When I cross over into the "old" BC interface and out of the "V3 Preview", I'm able to view the two Users currently set up. One is an "email only" user that the email is working just fine and I'm able to go into that user and change details associated with that user, including enabling email, etc. It also shows my address but when I try access it to "enable email" (which is unchecked and grayed out) I am not able to access it and I get this message at the top:
"Account details for this user can only be changed on the Adobe website at this time. You may only remove this user from this site by clicking the 'Delete' button."
Of course, when I follow the link provided, I can't find ANYWHERE to "enable email" for this account as it is tied to my BC-hosted website / webmail.
So, now I reason is the solution to:
- Make the other user an admin.
- Delete my user account
- Re-create my account with my email and make sure to enable the email functionality
- Change admin capabilities back to myself and remove them from the surrogate user / admin I imbued with said power before
Again, taking shots in the dark here until either someone who's dealt with this before helps out or Adobe throws me a rope.
Can't restate more loudly how URGENT this matter is. Thanks in advance.
4. Re: URGENT: Can't enable email for Admin? HELP!
Brad Lawryk Apr 13, 2012 9:52 AM (in response to BaseZero)Have you tried accessing the email through the webmail?
Go to http://mail.yourdomain.com
If it is the same as your admin login to the partner portal I believe it will work by default.
5. Re: URGENT: Can't enable email for Admin? HELP!
BaseZero Apr 13, 2012 10:06 AM (in response to Brad Lawryk) -
6. Re: URGENT: Can't enable email for Admin? HELP!
BaseZero Apr 13, 2012 10:37 AM (in response to Brad Lawryk)Ok, just got off the phone with Adobe and now I'm more than a little bit disappointed in the answer. I spoke with a service rep that directed me to the knowledge base for Business Catalyst and instructed me to look for a "work around".
Now, having been a professional for over 20 years and and Adobe customer for just as long, that's quite a load of B.S.
I've been to the knowledge base. It's usually where I go first looking for solutions. Kind of a do-it-yourselfer in that regard. Secondly, the issue in and of itself directs me back to Adobe and my account page with them, completely independant of the Business Catalyst System entirely with no visible solution to this problem when I arrive at the main Adobe ID account page.
ADOBE, if you're listening, this is unacceptable behavior. We're not hobbyists here, we run businesses and are relying on your business solutions to be exactly that; BUSINESS SOLUTIONS – not BUSINESS GOOSECHASES.
Now, that I've had my chance to vent, if someone from Adobe would please contact me through this board, not email obviously to get this remedied, I would appreciate it very much.
7. Re: URGENT: Can't enable email for Admin? HELP!
BaseZero Apr 13, 2012 10:55 AM (in response to Brad Lawryk)Just made a form submission "contact" with the BC support team. No response as of yet. This is a dire situation indeed. Losing revenue with each passing hour we don't have our email.
Anyone have any other ideas here? REALLY could use some kind of solution here.
Thanks in advance!
8. Re: URGENT: Can't enable email for Admin? HELP!
BaseZero Apr 13, 2012 12:38 PM (in response to BaseZero)Just checking in. I see the issue is getting alot of views, but no solutions yet. My research throughout the forums show that this is quite possibly something that the BC crew will have to handle due to the initial site the username was attached to has long been deleted from the system.
ADOBE!!! ARE YOU OUT THERE!
Seriously though, there really should be someone monitoring these boards for situations that truly are of an emergency nature. .................help?....................
9. Re: URGENT: Can't enable email for Admin? HELP!
Liam Dilley Apr 13, 2012 2:35 PM (in response to BaseZero)Hey there. I am in my iPad but the way admin and emails works was changed and fuly documented and announced.
I do not know about the old interface but switch to the new one. You shoukd be using that anyway. Every new site has that by default and the old one is there just so you can transition to the new one.
Admin and email users are now split. You have admin users and you set them up and under site settings as well you then set up the email users.
Thy why and what of this can be found in a blog post on the bc site
10. Re: URGENT: Can't enable email for Admin? HELP!
Liam Dilley Apr 13, 2012 2:37 PM (in response to BaseZero)Base zero, in terms of these forums, brand new just started getting up and running and in general BC support is not on here 24/7. If you have serious issues you need to use ticket or live support. No point calling adobe either because they won't know about business catalyst.
11. Re: URGENT: Can't enable email for Admin? HELP!
Liam Dilley Apr 13, 2012 3:12 PM (in response to Liam Dilley)Here is the blog post link: http://www.businesscatalyst.com/_blog/bc_blog#User%20and%20e-mail%20accounts
12. Re: URGENT: Can't enable email for Admin? HELP!
BaseZero Apr 13, 2012 3:42 PM (in response to Liam Dilley)Liam, thanks for the input.
I found out calling Adobe doesn't solve anything… the hard way.
Almost completely demoralized at this point. Just spent the entire day trying to sort this out. Been on Live Chat with BC for the past hour. They don't know what's wrong with it either.
Had me submit a ticket because the dude I was chatting with couldn't solve it. Said it needed to be escalated. So I did. He said I could continue to use BC while they sort it out on their end. Now, I can't even log into BC. Keep getting errors. Was seriously pushing this to be a Branded platform solution for our clients. May have to rethink that now. Not sure.
Guess the exhausting part of this is that after spending the entire day trying to sort it out, come to find out that the issues are not related to anything we did or didn't do.
13. Re: URGENT: Can't enable email for Admin? HELP!
officeBrah Apr 14, 2012 12:06 AM (in response to BaseZero)Sounds like you simply need to reassign the user to the site you want to enable email for.
So log into the admin console as the user you wish to enable email for, then navigate to home > my details. From the 'Default Site' dropdown, select the site that you wish to enable email for as this user.
Then you should be able to navigate to admin > manage users and enable email for yourself. You may need to log out and in again before the changes take affect. You may also need to populate the password fields on the My Details page for the changes to the default site to take affect.
14. Re: URGENT: Can't enable email for Admin? HELP!
BaseZero Apr 14, 2012 9:03 AM (in response to officeBrah)Dude, it's gotten even worse now. I can't even log into Business Catalyst to do anything on any of the accounts I'm currently building or managing for our business clients, much less my own email. It keeps returning "Bad Credentials" when I try to login.
I'm really incredulous at this point that this isn't resolved. Fortunately, I have a user I can log into away from my partner account to submit yet another ticket calling attention to this, but I am really amazed and frustrated at the level of attention that this is NOT getting by the ADOBE team.
We're not a Premium Partner yet, but if anyone else is and could do us a Good Samaritan favor, please call attention to this thread and the issue at hand for us, we REALLY need to make some headway on this ASAP. We have a growing list of current clients and "new proposal" prospects that aren't aware yet that we have ground to a halt on their work and proposals due to this terrible situation.
Thanks in advance.
15. Re: URGENT: Can't enable email for Admin? HELP!
Brad Lawryk Apr 14, 2012 9:39 AM (in response to BaseZero)By some chance you are using Adobe Muse as well?
16. Re: URGENT: Can't enable email for Admin? HELP!
BaseZero Apr 14, 2012 11:05 AM (in response to Brad Lawryk)Yes we are.
17. Re: URGENT: Can't enable email for Admin? HELP!
BaseZero Apr 14, 2012 11:07 AM (in response to Brad Lawryk)But just to be straight, this problem presented itself while we were working with Business Catalyst, not Muse. Even though we create content and publish via Muse into BC, all of it has transpired while working inside the BC system itself.
With that out of the way, why do you ask?
18. Re: URGENT: Can't enable email for Admin? HELP!
Brad Lawryk Apr 14, 2012 11:12 AM (in response to BaseZero)Because there was a bug that causes problems with connections in the latest Muse build. I believe there is a note about this on the Muse Forums. I am not at my work computer at the moment so I don't have the link handy.
19. Re: URGENT: Can't enable email for Admin? HELP!
BaseZero Apr 14, 2012 11:23 AM (in response to Brad Lawryk)Well, I suppose I'll head over there and let them know what is going on as well. Maybe they'll have better luck getting some response from the BC team to get this issue resolved.
On another note, Is this the typical level of support I can expect from the BC team? If it is, they really need to invest more time and thought into their support processes if this is the extent of product support that they provide. I get it if a form doesn't work on a website or something that is that of a technical "hey we're working on a problem that will be handled in the next patch" type of support.
But this is a Game-Stopper kind of issue and we're going on 48 hours with Live Chat, Trouble Tickets from two different sources and still no visible results from BC.
In additiona, since I can't access my partner account at all at this point, is there somewhere else I should be going or door I should be pounding to get their attention? Do they even frequent these forums, or am I just spinning my wheels here?
20. Re: URGENT: Can't enable email for Admin? HELP!
Brad Lawryk Apr 14, 2012 11:31 AM (in response to BaseZero)The Adobe Forums are User to User Forums. And to be honest the BC Team and a few very knowledgable people such as Liam frequent these forums more than most Adobe User Forums. You almost never see an Adobe Employee on the Dreamweaver Forum. They are meant for User to User troubleshooting and advise.
I do know that BC is in the process to making some changes to the current support ticketing system as well.
21. Re: URGENT: Can't enable email for Admin? HELP!
Liam Dilley Apr 14, 2012 7:16 PM (in response to Brad Lawryk)Brad is correct, it does not sound like you went to BC support much at all. The forums are more comunity - partner to partner although BC will post here. These are brand new aspect of BC forums on the Adobe forums so people are just finding their feet on here as well from the BC comunity.
Muse is at fault, lots of us building BC sites not having problems but we have not all made the switch over the Adobe ID stuff which is becoming clear that is your issue. Your not allone and as Brad rightly pointed out it is because your using the Muse which had that account creation aspect and its messed things up.
Other people have reported this and BC staff on here have already acknolweged the problem.
Muse.. why do people use it? lol. Just crap on so many levels, this is just another reason for me to hate it
22. Re: URGENT: Can't enable email for Admin? HELP!
Brad Lawryk Apr 14, 2012 8:31 PM (in response to Liam Dilley)Muse.. why do people use it? lol. Just crap on so many levels, this is just another reason for me to hate it
Mark this day on a calendar! Liam and I agreed on something. Muse = Bad .... very very bad. ;-)
23. Re: URGENT: Can't enable email for Admin? HELP!
Liam Dilley Apr 14, 2012 11:08 PM (in response to Brad Lawryk)Just watch these forums when it goes gold and creative cloud launches Brad.
Be prepared to answer questions you can't believe are asked, lol.
I feel for support. They are struggling now, it's going to be an utter nightmare for them.
Adobe ID stuff for BC got pushed back so it is a surprise to see the Muse stuff role with it, looks like Adobe was ready but not BC Side.
I hope lessons are learned and this does not happen to all of us when it's fully rolled out.
24. Re: URGENT: Can't enable email for Admin? HELP!
mario_gudelj Apr 15, 2012 2:01 AM (in response to Liam Dilley)1 person found this helpfulHi BaseZero,
Please see my PM and get back to me if you have any further issues.
Cheers,
Mario
25. Re: URGENT: Can't enable email for Admin? HELP!
BaseZero Apr 15, 2012 9:19 PM (in response to BaseZero)Alright. Problem has been resolved.
Thank you to Mario, Alex, Brad, Liam and everyone else who took the time to get involved in this issue and get it resolved for us. Much faith has been restored in the BC System as well as the Muse product.
For the record, it wasn't an issue created by Muse. I've been a BC member for close to two years now and the account was setup long before Muse was around. I'm currently working with the Muse team regarding login issues as well, which are completely separate issues.
Thanks again much to all and hopefully we can repay the favor someday!
So, let's keep moving forward!
26. Re: URGENT: Can't enable email for Admin? HELP!
JoJoMcK May 1, 2012 9:42 AM (in response to BaseZero)Could you please post the solution to this issue?
27. Re: URGENT: Can't enable email for Admin? HELP!
BaseZero May 1, 2012 9:56 AM (in response to JoJoMcK)This was something that had to be remedied at the BC support level. Not sure what they did on their end to get it working again.
28. Re: URGENT: Can't enable email for Admin? HELP!
Sidney MitchellMay 1, 2012 10:23 AM (in response to JoJoMcK)
Hi JoJoMcK!
Let us know which email account you are having troubles with and I can look into this further.
If wanting to keep the mail address private send me a direct PM here.
Cheers!
-Sidney
29. Re: URGENT: Can't enable email for Admin? HELP!
Sidney MitchellMay 3, 2012 9:57 AM (in response to Sidney Mitchell)
1 person found this helpfulHi everyone!
Just to recap Jojo's issue.
Client's Issue: After client merged their user ID with Adobe they then wanted to enable email for the specific ID as well.
Resolution: The user will need to go into the site admin and go to site settings -> email address. Create an email only user under the same merged Adobe ID as required. Thne under "activation email" use another email address to recieve the email to active the newly created mail account.
Hope this helps!
-Sidney
