1 Reply Latest reply on Apr 13, 2012 8:11 PM by Wil Renczes
    Avid AAF into Premiere works until "This project contained a sequence that could not be opened."
    ElliotFrahs Level 1
      I'm exporting an audio timeline from Avid to an AAF. I chose to copy and convert all the audio media into .WAV files, to place on a new harddrive and to provide a readable format for Premiere/Audition; (I read that Audition doesn't import AAF, but Premiere does, and can transfer to Audition.)
      Importing this AAF into premiere seems to work - it apparently links to the media and uses the AAF edl to create a new sequence, but before the import is successful I get the error message:
      "Fire Import Failure
      C:\[path]\PicLockAvidAudioTimelineExport.prproj
      Error Message
      This project contained a sequence that could not be opened. No sequence preview preset file or codec could be associated with this sequence type."
      What I don't understand is that this apparently refers to a premiere project sequence - prproj. Why is Premiere having trouble importing an AAF created from Avid?
      Using Premiere at school, I can import the AAF just fine. I'm using Premiere CS5 at home.
      Thank you!
