22 Replies Latest reply on Apr 14, 2012 9:49 AM by braico
    serious help needed fixing an image gallery
    braico
      On my page
      http://www.dorff.nl/clients.html
      ive put this very nice gallery..
      The only problem is. I divided the gallery in 6 groups. But in every group you will see the same images. How can i change the images for each group seperately?
      I hope you understand what i ment.
      Regards Brian
        • 1. Re: serious help needed fixing an image gallery
          adninjastrator Level 4
          This is the part of the lightbox code that specifies which set of images to use:
          rel="lightbox[portfolio]"
          the [portfolio] part. You need to create a separate id name for each button you have. Then only those images in that set will display for that button.
          for example:
          rel="lightbox[first_button]"
          all images linked to in that set will display under the first button
          Then
          rel="lightbox[second_button]"
          to display a second set.....etc, etc.
          http://lokeshdhakar.com/projects/lightbox2/
          Best wishes,
          Adninjastrator
          • 2. Re: serious help needed fixing an image gallery
            braico Level 1
            Thank you very much for your response.
            Where can i finfd this code? In CSS? Because i can find it..
            Regards Brian
            Date: Wed, 11 Apr 2012 08:56:52 -0600
            To: braico@live.nl
            Subject: serious help needed fixing an image gallery
                created by adninjastrator in Dreamweaver - View the full discussion
            This is the part of the lightbox code that specifies which set of images to use:rel="lightbox[portfolio]"the part. You need to create a separate id name for each button you have. Then only those images in that set will display for that button.for example:rel="lightbox[first_button]"all images linked to in that set will display under the first buttonThenrel="lightbox[second_button]"to display a second set.....etc, etc.http://lokeshdhakar.com/projects/lightbox2/Best wishes,Adninjastrator
                 Replies to this message go to everyone subscribed to this thread, not directly to the person who posted the message. To post a reply, either reply to this email or visit the message page: http://forums.adobe.com/message/4327094#4327094
                 To unsubscribe from this thread, please visit the message page at http://forums.adobe.com/message/4327094#4327094. In the Actions box on the right, click the Stop Email Notifications link.
                 Start a new discussion in Dreamweaver by email or at Adobe Forums
              For more information about maintaining your forum email notifications please go to http://forums.adobe.com/message/2936746#2936746.
            • 3. Re: serious help needed fixing an image gallery
              braico Level 1
              i find it in code.
              1. i see 6 sets so i think i can strat with the second set. so it look like this
              where i can link the images to the button i named lightbox2?
              To: braico@live.nl
              • 4. Re: serious help needed fixing an image gallery
                Putting 6 image galleries on the same page is going to require a little "outside the box" thinking/coding.
                The lightbox you are using typically is for just one gallery on one page.
                But.. I'm sure there are ways around this.
                Just to review..
                the array of images used in this link are described in between the brackets [ ].
                So to create an array called "flyers" for example, you could use this:
                rel="lightbox[flyers]"
                Then only the images listed in that section of [flyers] images will display.
                To practice and understand this principle, you might want to create a few test pages...each which only has one set of images... not 6 galleries.
                So... do a new, single gallery page... test the array method mentioned above... then move on to a second gallery. Only after you can successfully select the appropriate images for the "Flyers" gallery, etc. should you attempt to combine the process into 6 galleries.
                Best wishes,
                Adninjastrator
                • 5. Re: serious help needed fixing an image gallery
                  braico Level 1
                  How do you listed the images?
                  Thank you for your answer. It sounds very difficult to do.
                  Is it possible that you tell me step bybstep how to make a singlle gallerie?
                  Regards
                  Verstuurd vanaf mijn iPhone
                  Op 12 apr. 2012 om 04:25 heeft "adninjastrator" <forums@adobe.com> het volgende geschreven:
                  Just to review..
                  the array of images used in this link are described in between the brackets .
                  Then only the images listed in that section of images will display.
                  Best wishes,
                  Adninjastrator
                  Replies to this message go to everyone subscribed to this thread, not directly to the person who posted the message. To post a reply, either reply to this email or visit the message page: http://forums.adobe.com/message/4328795#4328795
                  To unsubscribe from this thread, please visit the message page at http://forums.adobe.com/message/4328795#4328795. In the Actions box on the right, click the Stop Email Notifications link.
                  • 6. Re: serious help needed fixing an image gallery
                    I'd suggest you start a new, blank HTML page and build a single gallery on it.
                    I'm sure that where ever you got your gallery from will have a better explanation than I can provide on how to set up that gallery. So first, check there.
                    The principle that you will be looking for is to provide an <a> (anchor) with the same array name for each image you want in that set. You only need to dispay a linking image for the first gallery image... it gives the viewer something to click. For the other images in the array, you will not need to display an image... just provide an <a>
                    notice where the anchor tag starts and ends:
                    <a class="load_portfolio_img" rel="lightbox[portfolio]" href="images/abnamro_gustav.jpg">
                          <span class="rm_img noscript"><img src="images/abnamro_logo.jpg" alt="" /></span>
                          <span class="roll_over rollover"></span></a>
                    now you've got a number of classes as well as a rollover image that complicates things even more. You might want to start with a simpler gallery until you understand how they work.
                    Here is a working example of having 2 separate galleries on the same page... copy and paste code into DreamWeaver so the code formats better. Notice that only the first <a> has a <img src="....
                    The other <a> s do not display any image on the page... only in the Gallery slideshow
                    <h2>Photo Gallery 1</h2>
                        <a href="images/paw_Carrie-Elwha.jpg" rel="lightbox[paw]" title="Elwha River Valley approaching the bridge"><img src="images/125/paw_Carrie-Elwha.jpg" alt="Elwha River Valley approaching the bridge" width="125" height="93" border="0" title="Elwha River Valley approaching the bridge"/></a>
                        <a href="images/paw_Elwha_Approach_1.jpg" rel="lightbox[paw]" title="Approaching Elwha Bridge from the east"></a>
                        <a href="images/paw_Elwha_Ramp.jpg" rel="lightbox[paw]" title="Elwha Bridge ramp to pedestrian deck"></a>
                       <h2>Photo Gallery 2</h2>
                        <a href="images/sw_IMG_1115-Downtown-Trail.jpg" rel="lightbox[sw]" title="Trail near High School close to downtown Sequim"><img src="images/125/sw_IMG_1115-Downtown-Trail.jpg" alt="Trail near High School close to downtown Sequim" width="125" height="83" border="0" title="Trail near High School close to downtown Sequim"/></a>
                        <a href="images/sw_IMG_1945-Downtown-Sequim.jpg" rel="lightbox[sw]" title="Downtown Sequim"></a>
                        <a href="images/sw_IMG_3031-Bike-Group.jpg" rel="lightbox[sw]" title="Dungeness River Bridge near Audobon Center"></a>
                        <a href="images/sw_IMG_6488-River-Bridge.jpg" rel="lightbox[sw]" title="View from Bridge during early fall"></a>
                        <a href="images/sw_IMG_0868.jpg" rel="lightbox[sw]" title="Trail West of River Bridge"></a>
                    The first image in the set actually displays an image for the viewer to click, the other images in that set are simply anchors <a>.... no image displays on the page. But you can see there are two sets of arrays
                    rel="lightbox[paw]"
                    for Gallery 1 and
                    rel="lightbox[sw]"
                    for Gallery 2
                    Start very simple, a new page with just one gallery... learn to create a set of images and build on that knowledge to build a second gallery.
                    Best wishes,
                    Adninjastrator
                    • 7. Re: serious help needed fixing an image gallery
                      braico Level 1
                      Great im going to start right away.. i will keep you informed about the progress
                      regards
                      Brian
                      Date: Thu, 12 Apr 2012 07:49:46 -0600
                      To: braico@live.nl
                      I'd suggest you start a new, blank HTML page and build a single gallery on it.I'm sure that where ever you got your gallery from will have a better explanation than I can provide on how to set up that gallery. So first, check there.The principle that you will be looking for is to provide an (anchor) with the same array name for each image you want in that set. You only need to dispay a linking image for the first gallery image... it gives the viewer something to click. For the other images in the array, you will not need to display an image... just provide an rel="lightbox[flyers]notice where the anchor tag starts and ends:!images/abnamro_logo.jpg|alt=|src=images/abnamro_logo.jpg! now you've got a number of classes as well as a rollover image that complicates things even more. You might want to start with a simpler gallery until you understand how they work.Here is a working example of having 2 separate galleries on the same page... copy and paste code into DreamWeaver so the code formats better. Notice that only the first has a !! s do not display any image on the page... only in the Gallery slideshowh2. Photo Gallery 1
                              !images/125/paw_Carrie-Elwha.jpg|title=Elwha River Valley approaching the bridge|height=93|alt=Elwha River Valley approaching the bridge|width=125|src=images/125/paw_Carrie-Elwha.jpg|border=0!               h2. Photo Gallery 2
                               !images/125/sw_IMG_1115-Downtown-Trail.jpg|title=Trail near High School close to downtown Sequim|height=83|alt=Trail near High School close to downtown Sequim|width=125|src=images/125/sw_IMG_1115-Downtown-Trail.jpg|border=0!                The first image in the set actually displays an image for the viewer to click, the other images in that set are simply anchors .... no image displays on the page. But you can see there are two sets of arrays rel="lightbox[paw]"for Gallery 1 and rel="lightbox[sw]"for Gallery 2Start very simple, a new page with just one gallery... learn to create a set of images and build on that knowledge to build a second gallery.Best wishes,Adninjastrator
                           Replies to this message go to everyone subscribed to this thread, not directly to the person who posted the message. To post a reply, either reply to this email or visit the message page: http://forums.adobe.com/message/4329760#4329760
                           To unsubscribe from this thread, please visit the message page at http://forums.adobe.com/message/4329760#4329760. In the Actions box on the right, click the Stop Email Notifications link.
                      • 8. Re: serious help needed fixing an image gallery
                        And to encourage you, here is the link to the page which contains two photo galleries on one page:
                        http://www.olympicdiscoverytrail.com/trail_maps/pt_angeles_w_test.html
                        Scroll to the bottom of the page and you'll see two images used as links to two separate galleries.
                        View the source code if you need more info:
                        Best wishes,
                        Adninjastrator
                        • 9. Re: serious help needed fixing an image gallery
                          braico Level 1
                          Great so it is possible..
                          Date: Thu, 12 Apr 2012 09:09:17 -0600
                          To: braico@live.nl
                          And to encourage you, here is the link to the page which contains two photo galleries on one page:http://www.olympicdiscoverytrail.com/trail_maps/pt_angeles_w_test.htmlScroll to the bottom of the page and you'll see two images used as links to two separate galleries.View the source code if you need more info:Best wishes,Adninjastrator
                               Replies to this message go to everyone subscribed to this thread, not directly to the person who posted the message. To post a reply, either reply to this email or visit the message page: http://forums.adobe.com/message/4330016#4330016
                               To unsubscribe from this thread, please visit the message page at http://forums.adobe.com/message/4330016#4330016. In the Actions box on the right, click the Stop Email Notifications link.
