14 Replies Latest reply on May 5, 2012 10:29 AM by BKBK
    webservices with xml file
    jfb00 Pioneer
      How can I read xml file using web services?
      Here is my cfc web services: (I just want to see how to read the xml file)
      <cfcomponent>
        <cffunction name="getBooks" access="remote" returntype="string" output="no">
          <cfargument name="xmlObject" type="xml" required="yes" >
          <cfset BookResponse = "">
          <cfset var arrIndx = "">
          <cftry>
              <cfloop from="1" to="#ArrayLen(arguments.xmlObject.XmlChildren)#" index="arrIndx">
                  <cfset BookResponse= arguments.xmlObject.XmlChildren[arrIndx].XmlName>
              </cfloop>
            <cfcatch type="any">
                <cfset BookResponse= "#cfcatch.message# #cfcatch.detail#">
           </cfcatch>
         </cftry>
      <cfreturn BookResponse>
        </cffunction>
      </cfcomponent>
      Here my code to test the web services:
      1. Define the xml
      <!--- Setup some XML to work with --->
      <cfsavecontent variable="XMLFile"><?xml version="1.0"?>
      <root>
      <header>
      <user>1</user>
      </header>
      <book>
      <isbn>0321330110</isbn>
      <title>Macromedia ColdFusion MX 7 Certified Developer Study Guide</title>
      <author>Ben Forta</author>
      </book>
      <header>
      <user>2</user>
      </header>
      <book>
      <isbn>0596004206</isbn>
      <title>Learning XML, Second Edition</title>
      <author>Erik Ray</author>
      </book>
      <header>
      <user>3</user>
      </header>
      <book>
      <isbn>0782140297</isbn>
      <title>Coldfusion MX Developer's Handbook</title>
      <author>Raymond Camden</author>
      </book>
      </root>
      </cfsavecontent>
      2.Invoke the web services
      <cfinvoke
         method="getBooks"
         returnvariable="rawXMLBookList"
         webservice="http://localhost/Hoteleria/webServices/books.cfc?wsdl">
         <cfinvokeargument name="xmlObject" value="#XMLFile#">
      </cfinvoke>
      <!---<cfset XMLDocResult = XmlParse(rawXMLBookList)>
      <cfdump var="#XMLDocResult#">--->
      <cfdump var="#rawXMLBookList#' >
      3. Error: Element XMLOBJECT.XMLCHILDREN is undefined in ARGUMENTS.
      I try also using XMLParse without luck.
      Any ideas?
        • 1. Re: webservices with xml file
          jfb00 Pioneer
          Looks like is not passing the XML doc.
          I try this in my function: <cfset BookResponse = #xmlObject#>
          Just to see if I can see the XML, I am getting this:  [#document: null]
          Any ideas?
          • 3. Re: webservices with xml file
            BKBK Rockstar
            There are few things you can improve, for example, using cfxml to pass an XML object, rather than cfsavecontent which passes a string. The following ilustrates this and other points:
            books.cfc
            <cfcomponent>
              <cffunction name="getAuthors" access="remote" returntype="string" output="no">
                <cfset var authors = "">
                <cftry>
                    <cfloop from="1" to="#ArrayLen(arguments.xmlObject.XmlRoot["root"].XmlChildren)#" index="arrIndx">
                        <!--- 'Author' elements are in 'book'. The 'book' elements are even-numbered --->
                        <cfif arrIndx mod 2 is 0>
                            <cfset authors = authors & chr(10) & chr(13) & arguments.xmlObject.XmlRoot["root"].XmlChildren[arrIndx].author.XmlText>
                          </cfif>
                   </cfloop>
                      <cfset authors = "#cfcatch.message# #cfcatch.detail#">
                 </cfcatch>
               </cftry>
              <cfreturn authors>
              </cffunction>
            </cfcomponent>
            testPage.cfm
            <cfxml variable="XMLFile"><root>
            <header>
            <user>1</user>
            </header>
            <book>
            </book>
            <header>
            <user>2</user>
            </header>
            <book>
            </book>
            <header>
            <user>3</user>
            </header>
            <book>
            </book>
            </root>
            </cfxml>
            <!---Invoke the web services--->
            <cfinvoke
               method="getAuthors"
               returnvariable="authorList"
            </cfinvoke>
            <cfdump var="#authorList#" >
            • 4. Re: webservices with xml file
              jfb00 Pioneer
              Thanks for you reply and help.
              I try your suggestion, i got this error:
              An error occured while Parsing an XML document. Content is not allowed in prolog.
              If I change the function parameter type from xml to any, it pass but i get this error:
              Element XMLOBJECT.XMLROOT is undefined in ARGUMENTS.
              Any ideas?
              • 5. Re: webservices with xml file
                BKBK Rockstar
                How does your cfargument line look like?
                • 6. Re: webservices with xml file
                  jfb00 Pioneer
                  I am using your example files. I have CF9.
                  • 7. Re: webservices with xml file
                    BKBK Rockstar
                    Odd. Just as a test, what happens when you drop the arguments scope, like this
                    <cfloop from="1" to="#ArrayLen(xmlObject.XmlRoot["root"].XmlChildren)#" index="arrIndx">
                                    <cfset authors = authors & chr(10) & chr(13) & xmlObject.XmlRoot["root"].XmlChildren[arrIndx].author.XmlText>
                                  </cfif>
                    </cfloop
                    • 8. Re: webservices with xml file
                      jfb00 Pioneer
                      I am back to this XML issue.
                      I am getting this:
                      Element XMLROOT is undefined in XMLOBJECT.
                      Something is not clicking here.
                      Any ideas?
                      Thanks for your help!
                      • 9. Re: webservices with xml file
                        BKBK Rockstar
                        Sorry about that. It did work for me!
                        What about doing it on the basis of strings, as follows:
                        books.cfc
                        <cfcomponent>
                          <cffunction name="getAuthors" access="remote" returntype="string" output="yes">
                            <cfargument name="xmlString" type="string" required="yes" >
                           <cfset var xmlObject = "">
                           <cfset var rootChildren = "">
                            <cfxml variable="xmlObject"><cfoutput>#arguments.xmlString#</cfoutput></cfxml>
                            <cfset rootChildren = xmlObject.xmlRoot.xmlChildren>
                            <cftry>
                                <cfloop from="1" to="#ArrayLen(rootChildren)#" index="arrIndx">
                                        <cfset authors = authors & chr(10) & chr(13) & rootChildren[arrIndx].author.XmlText>
                                      </cfif>
                               </cfloop>
                             </cfcatch>
                           </cftry>
                          <cfreturn authors>
                          </cffunction>
                        </cfcomponent>
                        testPage.cfm
                        <!--- Setup XML string to work with --->
                        <cfsavecontent variable="XMLFile"><root>
                        <header>
                        <user>1</user>
                        </header>
                        <book>
                        </book>
                        <header>
                        <user>2</user>
                        </header>
                        <book>
                        </book>
                        <header>
                        <user>3</user>
                        </header>
                        <book>
                        </book>
                        </root>
                        </cfsavecontent>
                        <cfinvoke
                           method="getAuthors"
                           <cfinvokeargument name="xmlString" value="#XMLFile#">
                        </cfinvoke>
                        • 10. Re: webservices with xml file
                          BKBK Rockstar
                          If the call to the web service continues to fail, then refresh the WSDL. The following code will refresh it:
                          <cfset serviceFactory = CreateObject("java", "coldfusion.server.ServiceFactory")>
                          <cfset rpcService = serviceFactory.XmlRpcService>
                          <cfset wsdl="http://localhost/Hoteleria/webServices/books.cfc?wsdl">
                          <cfset rpcService.refreshWebService(wsdl)>
                          Message was edited by: BKBK
                          • 11. Re: webservices with xml file
                            jfb00 Pioneer
                            This solution work BKBK, Thanks!
                            Now if it is not much to ask. I add a general node at the top of the xml like:
                            <general>
                                <accountUser>234</accountUser>
                            </general>
                            How can I go to the node "accountUser", change the value and return the whole xml file with this new value updated?
                            Best,
                            • 12. Re: webservices with xml file
                              BKBK Rockstar
                              <general>
                              </general>
                              <!--- The XML document object --->
                              <cfxml variable="XMLObject"><root>
                              <general>
                              </general>
                              <header>
                              <user>1</user>
                              </header>
                              <book>
                              </book>
                              <header>
                              <user>2</user>
                              </header>
                              <book>
                              </book>
                              <header>
                              <user>3</user>
                              </header>
                              <book>
                              </book>
                              </root>
                              </cfxml>
                              <cfset XMLObject.root.general.accountUser.xmlText = 567>
                              <cfdump var="#XMLObject#">
                              • 13. Re: webservices with xml file
                                jfb00 Pioneer
                                Thank you so much for your time and help!
                                Best,
                                • 14. Re: webservices with xml file
                                  BKBK Rockstar
                                  How kind of you!
