18 Replies Latest reply on Apr 20, 2012 6:05 AM by Production Monkey
    set spawn points for each sprite?
    elimann
      heres my dilema
      i currently have 5 sprites and 5 different set co ordinates for each one to spawn into with individual behaviour scripts, however i want each sprite to spawn into one of the set co ordinate without more than one of them spawning into the same point.
      so eventually each sprite will spawn into a random set co ordinate
      so something like
      pRandomStartingLoc = (200,100) (300,100) (400,100) so each sprite spawns into only one set of cordinates without more than one spawning into the same one
        • 1. Re: set spawn points for each sprite?
          Production Monkey Level 3
          You want something like the following:
          --  Random Set behavior
          property  pSetNum
          property  pMySet
          On GetPropertyDescriptionList me
            Props = [:]
            Props[#pSetNum] = [#default:#1, #format:#integer, #Range:[#min:1, #max:5], #comment:"Choose a set."]
            return Props
          end GetPropertyDescriptionList
          on beginSprite me
            Case pSetNum of
              1:  pMySet = [point(200,100), point(300,100), point(400,100)]
              2:  pMySet = [point(200,100), point(300,100), point(400,100)]
              3:  pMySet = [point(200,100), point(300,100), point(400,100)]
              4:  pMySet = [point(200,100), point(300,100), point(400,100)]
              5:  pMySet = [point(200,100), point(300,100), point(400,100)]
            end case
            put pMySet
          end beginSprite
          • 2. Re: set spawn points for each sprite?
            elimann Level 1
            would i use this code for each sprite?
            i tried the above code on my sprite but they didnt spawn at any of them points?
            • 3. Re: set spawn points for each sprite?
              Yes you would use one behavior for all five sprites.
              You need to modify the code I wrote and add it to your behavior. And, of course each "pMySet" property in the case statement would be set to a different list of points.
              The general idea is that if a set of sprites all have the same behavior but some of their properties need to be set to different values, then you use the " GetPropertyDescriptionList()" handler to set those differenct values.
              • 4. Re: set spawn points for each sprite?
                elimann Level 1
                it still didnt work, i put the code in a new behaviour as a test to see if they would spawn at different points but nothing is happening to my sprite
                • 5. Re: set spawn points for each sprite?
                  The code I posted is Not complete. You need to write the "spawning" code. I only show how to pick a different set of points for each sprite.
                  If your spawing code continues to not work, post your code so we can see what is not working.
                  • 6. Re: set spawn points for each sprite?
                    elimann Level 1
                    what kind of "spawning code" before my behaviour just assigned a certain co ordinate to each sprite
                    eg
                    property ch
                    on beginSprite me
                      ch = me.spriteNum
                      start_x = 100
                      start_y = 284
                      sprite(ch).locH = start_x
                      sprite(ch).locV = start_y
                    • 7. Re: set spawn points for each sprite?
                      I thought perhaps you were using some variation of the code Mister MUX wrote.
                      Here's a more complete version:
                      property  pSetNum
                      property  pMySet
                      property  pSp
                      property  pStartLoc
                      On GetBehaviorDescription me
                        return "Sets sprite to a random location based off a predefined set."
                      end GetBehaviorDescription
                        Props = [:]
                        return Props
                      on beginSprite me
                        pSp = Sprite(me.spriteNum)
                        -- get my location choice set
                        Case pSetNum of
                            -- *** Change these value to what you want *****
                          2:  pMySet = [point(100,200), point(500,105)]
                          3:  pMySet = [point(50,70), point(478,387)]
                          4:  pMySet = [point(400,500), point(623,245)]
                          5:  pMySet = [point(600,400), point(284,470)]
                        end case
                        pSp.loc = pMySet[random(pMySet.count)]   -- set my location
                        pStartLoc = pSp.loc  -- store current location in case you want to return to it
                      end beginSprite
                      on goToStartLoc me
                        pSp.loc = pStartLoc
                      end
                      • 8. Re: set spawn points for each sprite?
                        elimann Level 1
                        thanks this worked for the spawning however they can still spawn into the same co ordinates?
                        eg i tried with 2 sprites
                            1:  pMySet = [point(100,200), point(500,105)]
                        however set 1 and set 2 sprites still sometimes spawn into the same co ordinate? i want only one sprite in one co ordinate at a time
                        • 9. Re: set spawn points for each sprite?
                          I'm not sure what you want. Is this closer?
                          property  pPosNum
                          property  pSp
                          property  pStartLoc
                            Props = [:]
                            Props[#pPosNum] = [#default:#1, #format:#integer, #Range:[#min:1, #max:5], #comment:"Choose a set."]
                            return Props
                          on beginSprite me
                            pSp.loc = [point(200,100), point(300,100), point(400,100), point(500,100), point(600,100)][pPosNum]   -- set my location
                          end beginSprite
                          on goToStartLoc me
                            pSp.loc = pStartLoc
                          end
                          • 10. Re: set spawn points for each sprite?
                            elimann Level 1
                            for example if i have 2 objects
                            object 1 can spawn at (100,100) or (200,200)
                            object 2 can spawn at (100,100) or (200,200)
                            if object 1 spawns at (100,100) then object 2 must spawn at (200,200) and vice versa
                            • 11. Re: set spawn points for each sprite?
                              Okay fourth time may be the charm.
                              This behavior contains a Single Locations list that is global to all sprites with this behavior attached. Each sprite picks a random loc from the list and then deletes that value from the list so that no other sprite can use it.
                              Note: This uses some advanced Lingo, but you should only need to replace the point values in the list of point values.
                              property  pSp   -- this sprite
                              property  pStartLoc  -- this sprites location at beginsprite
                              -- global/static behavior property
                              property  curLocs  -- list of sprite locations used by ALL sprites with this behavior attached
                              on beginSprite me
                                -- define our quasi global locations list if it is not defined or is empty
                                if me.script.curLocs.voidP OR me.script.curLocs = [] then
                                  me.script.curLocs = [point(200,100), point(300,100), point(400,100), point(500,100), point(600,100)]  -- Define Sprite Locs Here
                                end if
                                Locs = me.script.curLocs
                                pSp.loc = Locs[random(Locs.count)]   -- set my location to random point from list
                                Locs.deleteOne(pSp.loc)  -- remove this Loc from list so that no other sprite can use it.
                                -- debug code. Check message window
                                put "Sprite " & me.spriteNum & " is at location " & pSp.loc
                              end beginSprite
                              on goToStartLoc me
                                pSp.loc = pStartLoc
                              end
                              on endSprite me
                                me.script.curLocs = void
                              end
                              on reset me
                                me.endSprite()
                                me.beginSprite()
                              end
                              • 12. Re: set spawn points for each sprite?
                                elimann Level 1
                                tried this with 2 objects using points [point(200,100), point(300,100)]
                                didnt work again, the objects were able to spawn at the same co ordinates
                                eg object 1 and object 2 both spawned at 200,100 when only one of them should have, then the other should have spawned at 300,100
                                EDIT IGNORE IT WORKED
                                • 13. Re: set spawn points for each sprite?
                                  elimann Level 1
                                  just to add, how would i restore the position of a given sprite in relation to this code?
                                  would i use  pStartLoc?
                                  • 14. Re: set spawn points for each sprite?
                                    pStartLoc holds the starting location point and you can use that to modify the code, or you can just call the goToStartLoc() handler. As in:
                                    sprite(5).goToStartLoc()
                                    sendAllSprites(#goToStartLoc)
                                    Delete the "reset()" handler above. It will not work correctly. I would delete it from the forum but the forum won't let me at the moment.
                                    • 15. Re: set spawn points for each sprite?
                                      elimann Level 1
                                      I used the code above "sprite(5)goToStartLoc()" but changed the 5 to ch so I can have a universal code for all the cast members I am using, I used it to try make them respawn but they all respawned back onto the random coordinate it was assigned to i.e all to (300,100). I want it so a member who was at (400,200) will return to that exact coordinate and another member for example at (600,400) with return to that exact coordinate.
                                      Any help will be appreciated.
                                      • 16. Re: set spawn points for each sprite?
                                        • 17. Re: set spawn points for each sprite?
                                          elimann Level 1
                                          this just sent all the sprites back to one random co ordinate, i want each sprite to return back to its each individual random cordinate that we used in the example code above
                                             eg using your code before
                                          me.script.curLocs = [point(200,100), point(300,100)]
                                          if sprite 1 spawns at (200,100), sprite 2 spawns at (300,100). im creating a dragging game so if i drag the sprite 1 to a wrong location i want sprite 1 to return back to (200,100), however as you know sprite 1 could also spawn at (300,100) next time. so basically i want whatever random co cordinate the sprite spawns at the start, for it to return to that same given co cordinate if a given action occurs
                                          • 18. Re: set spawn points for each sprite?
                                            The code I posted works exactly the way you want it to work. Each sprite returns to the random location that was picked on beginSprite. If it does not do that then you perhaps changed some code or have another behavior attached to the sprites that is causing your problem.
