3 Replies Latest reply on Apr 28, 2012 6:27 AM by UlfLaursen
    Output timeline to HDMI monitor
    UlfLaursen Level 2
      Hi
      I am using PPRO CS 5.5 on PC and looking to upgrade to CS 6 when it comes out.
      I would like to get an output to an HDMI monitor, and would probably need a card for that.
      I have seen several cards on the web, but kind of unsure, which to chose. I only need preview output; no input.
      Thanks.
      Ulf
        • 1. Re: Output timeline to HDMI monitor
          Harm Millaard Level 7
          Every modern day video card can output to two monitors, AMD Eyefinity cards even up to 6 monitors and the nVidia GTX 680 up to 4 monitors.
          So if you only use a single monitor and want to add a second monitor, you probably only need the correct cable. If you use dual monitors and want to add a third monitor, then your choices are limited to the 680 or an AMD, or two GTX 4xx or two GTX 5xx cards that use the same driver.
          • 2. Re: Output timeline to HDMI monitor
            UlfLaursen Level 2
            Thanks a lot, Harm - as always, spot on :)
            /Ulf
            • 3. Re: Output timeline to HDMI monitor
              UlfLaursen Level 2
              Hi Harm
              I want to look more into this solution, because I might get into trouble using a black magic intensity pro with a newer asus motherboard (the line of recommended boards is very narrow).
              I have the GTX 570 installed in my PC and would install another GTX 4/5xx card too - so far so good :)
              How would I get the timeline output on one of the outputs of this extra card? Should I put in a setting in PPRO?
              Ulf
