Flex Data services not working in Oracle AS or OC4J 10.1.3
Avatar
Level 1
I followed the instructions in the Install documentation but
still can’t get the Data services to work in Oracle AS or
OC4J 10.1.3. If I try to run Flex Admin I get an RPC fault
“Send Fail, faultcode=client.error.messagesend
faultdetail=channel.connect.fail error netconnection.call.failed:
http: status 500 messageID=2907c199-e9be-8081-c279-423f593a7777. If
I try to run the samples i either get a send fail Error or
1 Exception found.
Exception java.lang.OutOfMemoryError Java heap space.
Increasing the heap size does not help. Does anyone have any
suggestions?
Avatar
Level 2
Do you see exceptions logged at startup?
Avatar
Level 1
No I don't see any exceptions when OC4J or Oracle AS starts
up
Avatar
Level 1
Oc4J start up output:
C:\download\J2EE\oc4j\bin>oc4j -start
Starting OC4J from C:\download\J2EE\oc4j\j2ee\home ...
2006-10-13 13:11:42.903 NOTIFICATION JMS Router is initiating
06/10/13 13:12:00 10/13 13:12:00 INFO Loading configuration
file C:\download\J2E
E\oc4j\j2ee\home\applications\Flex Data
Services\flex\WEB-INF\flex\flex-webtier-
config.xml
06/10/13 13:12:01 10/13 13:12:01 INFO Loading configuration
Services\flex\WEB-INF\flex\flex-config.x
ml
06/10/13 13:12:12 10/13 13:12:12 INFO Loading configuration
E\oc4j\j2ee\home\applications\Flex Data Services
Samples\samples\WEB-INF\flex\fl
ex-webtier-config.xml
06/10/13 13:12:13 10/13 13:12:13 INFO Loading configuration
ex-config.xml
06/10/13 13:12:13 Oracle Containers for J2EE 10g (10.1.3.0.0)
initialized
Avatar
Level 2
Would you turn on server and client debugging and retry? The
500 error doesn't give much info to go on.
For client side - add:
<mx:TraceTarget level="0" />
This will add lots of output to the flashlog.txt file. And
for the server side add this to the services-config.xml file under
logging (level="Debug" is key):
<target class="flex.messaging.log.ConsoleTarget"
level="Debug" >
<properties>
<prefix>[Flex] </prefix>
<includeDate>true</includeDate>
<includeTime>true</includeTime>
<includeLevel>true</includeLevel>
<includeCategory>false</includeCategory>
</properties>
<filters>
<pattern>Endpoint.*</pattern>
<pattern>DataService.*</pattern>
<pattern>Service.*</pattern>
<pattern>Message.command.*</pattern>
<pattern>Message.data.*</pattern>
</filters>
</target>
Avatar
Level 3
hi,
There is a MBean restriction on oc4j which makes fds fail to
start. Please verify this by requesting the messagebroker servlet!
example
http://localhost:8888/samples/messagebroker/amf
You should see a blank page. If you see a mbean error, it is
the issue which I mentioned.
Workaround: Go to bin/oc4j.cmd or oc4j and edit the java args
set JVMARGS=%OC4J_JVM_ARGS%
-Doc4j.jmx.security.proxy.off=true
I also suggest to increase your heap
set JVMARGS=%OC4J_JVM_ARGS% -Xmx512m
William Chan
Avatar
Level 1
William I added the params to JVMARGS and now I get the
following when OC4J starts
C:\ProgramFiles\oc4j\bin>oc4j -start
Starting OC4J from C:\ProgramFiles\oc4j\j2ee\home ...
2006-10-17 10:26:06.138 ERROR SCH-13001 scheduler
initialization failed
2006-10-17 10:26:06.158 WARNING
oracle.j2ee.jmsrouter.RouterException: scheduler
initialization failed; nested exception is:
java.lang.IllegalStateException: un
expected mbean count, 0
and when I try to access
I get the following
500 Internal Server Error
flex.messaging.config.ConfigurationException: Unable to
create service 'flex.messaging.services.HTTPProxyService' for
'proxy-service' due to the following error: class 'null' could not
be found in the classpath.
at
flex.messaging.config.MessagingConfiguration.createServices(MessagingConfiguration.java:202)
at
flex.messaging.config.MessagingConfiguration.configureBroker(MessagingConfiguration.java:84)
at
flex.messaging.MessageBrokerServlet.init(MessageBrokerServlet.java:105)
at com.evermind[Oracle Containers for J2EE 10g (10.1.3.0.0)
].server.http.HttpApplication.loadServlet(HttpApplication.java:2231)
].server.http.HttpApplication.findServlet(HttpApplication.java:4617)
].server.http.HttpApplication.findServlet(HttpApplication.java:4541)
].server.http.HttpApplication.getRequestDispatcher(HttpApplication.java:2821)
].server.http.HttpRequestHandler.doProcessRequest(HttpRequestHandler.java:740)
].server.http.HttpRequestHandler.processRequest(HttpRequestHandler.java:451)
].server.http.HttpRequestHandler.serveOneRequest(HttpRequestHandler.java:218)
].server.http.HttpRequestHandler.run(HttpRequestHandler.java:119)
].server.http.HttpRequestHandler.run(HttpRequestHandler.java:112)
at
oracle.oc4j.network.ServerSocketReadHandler$SafeRunnable.run(ServerSocketReadHandler.java:260)
at
oracle.oc4j.network.ServerSocketAcceptHandler.procClientSocket(ServerSocketAcceptHandler.java:230)
at
oracle.oc4j.network.ServerSocketAcceptHandler.access$800(ServerSocketAcceptHandler.java:33)
at
oracle.oc4j.network.ServerSocketAcceptHandler$AcceptHandlerHorse.run(ServerSocketAcceptHandler.java:831)
].util.ReleasableResourcePooledExecutor$MyWorker.run(ReleasableResourcePooledExecutor.java:303)
at java.lang.Thread.run(Thread.java:595)
Avatar
Level 3
I have the error and warning too, but the samples work. We
are working on it to provide a fix. By the meanwhile, you should be
able to get fds work. Can you remove the fds samples and redeploy
it? Will get you update if any!
William Chan
Avatar
Level 1
I removed and redeployed the samples and evrything works now
the only problem now is the OC4J messsage
Avatar
Level 3
I saw that too. I think it is only happened on 10.1.3.0.0,
not 10.1.3.1 We are also contacting oracle to solve that issue!
William Chan
Avatar
Level 1
I have also been having these issues with OC4J.
Did you find out which version of OC4J is needed, and has the
issue been resolved with Oracle?
Many thanks,
Nathan
