4 Replies Latest reply on Apr 22, 2012 9:51 PM by Sathyamoorthi
    ExternalInterface: Type? String, Object and any types?
    SourceSkyBoxer Level 1
      Hello dear guys,
      i want know about ExternalInterface - just i have same problem with String or Array - if i like this.
      But i am working with AS3 with in-block Javascript like trick by Facebook Api Libraries.
      I know same functions for Boolean and Object right..
      Code is MyLibrary.as
      package ....
                import flash.external.ExternalInterface;
                public class MyLibraray
                           *           MyLibrary Exit
                          private static var _exit:Object;
                          public static function Exit():void
                                    try{
                                              if(ExternalInterface.available){
                                                        _exit = ExternalInterface.call(jsBirdge.script());
                                                        _exit = ExternalInterface.call("JSL.jsExit"); //
                                    }catch( error:Error) {}
      And jsBirdge.as <- It is in-block with Javascript into XML Format and Doement Format like Javascript Version into Actionscript
      package ...
                public class jsBirdge
                          private static var NS:String = "JSL";
                          public static function script():String
                                    try{
                                                        ExternalInterface.call(script_js);
                                                        ExternalInterface.call("JSL.setSWFObject", ExternalInterface.objectID);
                                    return NS;
                          private static const script_js:XML =
                                    <script>
                                              <![CDATA[
                                                        function (){
        var curwin = Titanium.UI.currentWindow;
        JSL= {
        setSWFObjectID: function( swfObjectID ) {
        JSL.swfObjectID = swfObjectID;
        /*          Same Functions  */
        jsExit : function(){
        Titanium.exit();
                                    </script>;
      How does ExternalInterace work with currect type?
      If i use custom call like exit for Titanium Desktop than ExternalInterface will check currect type - like function type exit() = Titanium.exit(); as Type "String"
      Or another example: File, FileSystem and FileStream are types as object, is it right?
      Or Booleam Example true or false as type Booleam. ...
      Is it posskible that externalInterface works fine with any types/functions?
      I have been tested with ExternalInterface and In-Block Javascript = IT works fine... Look out! http://developer.appcelerator.com/question/135288/how-do-you-know-flash-and-titanium
      But i hate disturbated communication function like GWT external / fscommand...
      I want use only AS3 / JS. Just i miss this nice example because i don't forget - where are nice examples? I wish because you would say me about currect result
      Thanks i hope because i get nice answer / result for currect types / function for externalinterface via inblock: Javascript.
        • 1. Re: ExternalInterface: Type? String, Object and any types?
          Sathyamoorthi
               I am not really clear with your above post. But you can communicate with javascript from flex by the below way.
          Javascript:
          function CallMe()
               alert("Call Me");
          function CallMeWithArg(value)
               alert("This is your value: " + value);
          Action Script:
          ExternaInterface.call('CallMe'); //without argument.
          ExternaInterface.call('CallMeWithArg', 'HelloWorld'); //with argument.
          • 2. Re: ExternalInterface: Type? String, Object and any types?
            Hey @Sathyamoorthi,
            thank you i understand.
            If i am using only ExternalInterface like Javascript with in-block into AS3 than as3 library ( swc ) works complety. Example: I am using with Titanium Desktop.
            I will call externalInterface by Javascript's Library.
            Look example:
            Application.as:
              *          SourceSkyBoxer's Library
              * Support for Titanium Desktop
            package net.sourceskyboxer.as3titan
                      public class Application
                                 *           Application Exit
                                public static var _exit:String;
                                public static function Exit():String
                                          try{
                                                              _exit = ExternalInterface.call(jsBirdgeTitanium.script());
                                                              _exit = ExternalInterface.call("TIAS.jsExit");
                                          return _exit;
                                 *           Application Restart
                                public static var _restart:String;
                                public static function Restart():String
                                          try{
                                                              _restart = ExternalInterface.call(jsBirdgeTitanium.script());
                                                              _restart = ExternalInterface.call("TIAS.jsRestart");
                                          return _restart;
                                 *           Application Maximize
                                public static var _maximize:String;
                                public static function Maximize():String
                                          try{
                                                              _maximize = ExternalInterface.call(jsBirdgeTitanium.script());
                                                              _maximize = ExternalInterface.call("TIAS.jsMaximize");
                                          return _maximize;
                                 *           Application Restore / Unmaximize
                                public static var _restore:String;
                                public static function Restore():String
                                          try{
                                                              _restore = ExternalInterface.call(jsBirdgeTitanium.script());
                                                              _restore = ExternalInterface.call("TIAS.jsRestore");
                                          return _restore;
                                 *           Application Minimize
                                public static var _minimize:String;
                                public static function Minimize():String
                                          try{
                                                              _minimize = ExternalInterface.call(jsBirdgeTitanium.script());
                                                              _minimize = ExternalInterface.call("TIAS.jsMinimize");
                                          return _minimize;
                                 *           Application Super this...
                                public function Application():void
                                          super();
            And jsBirdgeTitanium.as:
                      public class jsBirdgeTitanium
                                public static var NS:String = "TIAS";
                                          try{
                                                              ExternalInterface.call("TIAS.setSWFObject", ExternalInterface.objectID);
                                          return NS;
                                public static const script_js:XML =
                                          <script>
                                                    <![CDATA[
                                                              function (){
        TIAS = {
        TIAS.swfObjectID = swfObjectID;
        /*          Application Functions  */
        Titanium.App.exit();
        jsRestart : function(){
        Titanium.App.restart();
        jsMaximize : function(){
        curwin.maximize();
        jsRestore : function(){
        curwin.unmaximize();
        jsMinimize : function(){
        curwin.minimize();
        /*          System Functions  */
        jsGetplfo : function(){
        Titanium.getPlatform(os);
                                          </script>;
            How do i know? When do i click same without "()" than ExternalInterface can't work because it has same problem with special structures of Javascript. If i check error for Javascript Structure simple with Adobe Dreamweaver CS5 than i add completed Javascript In-Block into AS3 ( jsBirdgeTitanium.as )
            I knew nice trick by FaceBook's Library - Did you know about FaceBook's Library for swc files and Sources. I have been foound Javascript In-Block by FaceBook:
            FaceBook_graphi / api / com / facebook / core / FacebookJSBridge.as
                      Copyright (c) 2010, Adobe Systems Incorporated
                      All rights reserved.
                      Redistribution and use in source and binary forms, with or without
                      modification, are permitted provided that the following conditions are
                      met:
                      * Redistributions of source code must retain the above copyright notice,
                      this list of conditions and the following disclaimer.
                      * Redistributions in binary form must reproduce the above copyright
                      notice, this list of conditions and the following disclaimer in the
                      documentation and/or other materials provided with the distribution.
                      * Neither the name of Adobe Systems Incorporated nor the names of its
                      contributors may be used to endorse or promote products derived from
                      this software without specific prior written permission.
                      THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS
                      IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
                      THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
                      PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
                      CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
                      EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
                      PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
                      PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
                      LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
                      NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
                      SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
            package com.facebook.graph.core {
                       * Class that wraps javascript code for communicating with Facebook Javascript SDK.
                       * This class replaced the previous FBJSBridge.js file.
                      public class FacebookJSBridge {
                                public static const NS:String = "FBAS";
                                public function FacebookJSBridge() {
                                          try {
                                                    if( ExternalInterface.available ) {
                                                              ExternalInterface.call( script_js );
                                                              /*Get a reference to the embedded SWF (object/embed tag). Note that Chrome/Mozilla Browsers get the 'name' attribute whereas IE uses the 'id' attribute.
                                                              This is important to note, since it relies on how you embed the SWF. In the examples, we embed using swfObject and we have to set the attribute 'name' the
                                                              same as the id.*/
                                                              ExternalInterface.call( "FBAS.setSWFObjectID", ExternalInterface.objectID );
                                          } catch( error:Error ) {}
                                private const script_js:XML =
                                          <script>
                                                    <![CDATA[
                                                              function() {
        FBAS = {
        FBAS.swfObjectID = swfObjectID;
        init: function( opts ) {
        var options = FB.JSON.parse( opts );
        FB.init( options );
        FB.Event.subscribe( 'auth.authResponseChange', function( response ) {
        FBAS.updateSwfAuthResponse( response.authResponse );
        setCanvasAutoResize: function( autoSize, interval ) {
        FB.Canvas.setAutoResize( autoSize, interval );
        setCanvasSize: function( width, height ) {
        FB.Canvas.setSize( { width: width, height: height } );
        login: function( opts ) {
        FB.login( FBAS.handleUserLogin, FB.JSON.parse( opts ) );
        addEventListener: function( event ) {
        FB.Event.subscribe( event, function( response ) {
        FBAS.getSwf().handleJsEvent( event, FB.JSON.stringify( response ) );
        handleUserLogin: function( response ) {
        logout: function() {
        FB.logout( FBAS.handleUserLogout );
        handleUserLogout: function( response ) {
        swf = FBAS.getSwf();
        swf.logout();
        ui: function( params ) {
        obj = FB.JSON.parse( params );
        method = obj.method;
        cb = function( response ) { FBAS.getSwf().uiResponse( FB.JSON.stringify( response ), method ); }
        FB.ui( obj, cb );
        getAuthResponse: function() {
        authResponse = FB.getAuthResponse();
        return FB.JSON.stringify( authResponse );
        getLoginStatus: function() {
        FB.getLoginStatus( function( response ) {
        if( response.authResponse ) {
        } else {
        FBAS.updateSwfAuthResponse( null );
        getSwf: function getSwf() {
        return document.getElementById( FBAS.swfObjectID );
        updateSwfAuthResponse: function( response ) {
        if( response == null ) {
        swf.authResponseChange( null );
        } else {
        swf.authResponseChange( FB.JSON.stringify( response ) );
                                          </script>;
            That is "In-Block" for Javascript into AS3.
            I would like this because ExternalInterface is very better than get4flex or get4air. Did you know about ExternalInterface - communicate is very better or went bad?
            I would find for currect structure for Actionscript 3 and Javascript communication for externalinterface with different types like variable, array, boolean and ayn functions / types?
            What does externalinterface support with types by Javascript?
            I know void type - it is very simple only click. But i need any types. Thanks!
            • 3. Re: ExternalInterface: Type? String, Object and any types?
              Why do you not answer me I need bit help for different type for externalinterface like Object, String, Void or Array.....
              • 4. Re: ExternalInterface: Type? String, Object and any types?
                Sathyamoorthi Level 2
                as far as i know, you can only pass strings to javascript. i am not sure about complex data types.
