Workaround for importing 3D files in CS6?
Guest
Apr 16, 2012 Apr 16, 2012
One of my favorite features in AE CS5.5 is the ability to import 3D files created in one of my 3D programs without plugins. Basically, I just import my 3D model into Photoshop and save it as a PSD, then import the PSD file into AE. This is the ONLY way to import 3D files into AE without having to buy plug-ins, etc, since AE doesn't accept the most common 3D file types. However, everything I've read is that Adobe is eliminating this. Does anyone know how Adobe is going to address this problem in CS6?
58.4K
Probably not before CS7 (or 6.5?). In the meantime simply buy Zaxwerks Invigorator/ Pro Animator or the up and coming Video Copilot Element plug-in or one of the possibly many other plug-ins that will surface... If that really is so important to you, springing those 150 bucks that Andrew promised Element will cost is a no-brainer, considering how it will enhance your workflows beyond anything Adobe currently can offer...
Mylenium
Guest
Thanks, but the problem is that the plug in from Zaxwerks costs $450, and it costs me $0 to import from Photoshop. As for Element, it appears to be something to create 3D objects within AE. Since I create models in other 3D programs (Hexagon and DAZ), Element doesn't look like a viable option. One thing I greatly enjoyed is that I could create a 3D model, then someone else could change a surface in Photoshop without having to know anything about 3D, just PS, and I could then import it into AE. I've been doing web design from home for years, so I just have Web Premium CS3, but I'm doing video at my day job and I want to add that option for my current web clients, so ponying up the money for the new Master Collection is going to be enough of an issue without spending another $450....
**************** Slight correction********************
OK, I'd been looking on the VCP site, and from what I could find (I follow VCP, but the last update on Element was awhile back and I don't have that great a memory, lol), I didn't see anything about importing obj files. Then I just found an article on another site that said Element will be able to import those files. So, I may have to get it, but only if it is able to import obj files. Still, I'm not happy about this feature being removed. It also doesn't address the problem with no longer being able to allow someone to change a surface in PS then import the PSD file. Oh well....
Apr 18, 2012 Apr 18, 2012
Neither are we.
Photoshop changed sooooo much in its 3D implementation (for the better) that it just wasn't possible to integrate all of the changes before it was time to release the new version.
May 13, 2012 May 13, 2012
I've been working on a project that involves animating a 3D model of a car as it maneuvers past a Photoshop created set in front of which some masked video activities are occurring (i.e. the video against the set are often seen as a point of view of a passenger in the car.) I have also been doing what Bruce describes, finding pre-made models on the internet and altering texture before bringing them into After Effects. My question is whether my better option now is simply to continue working in AE 5.5 or whether I will be more efficient creating the whole animation within PS CS 6. For example, would I be able to create the masked video segments within AE and bring those into PS, where I perhaps I could composite the animated model? This loss of the ability to manipulate 3D models in AE -- a workflow I was only just haltingly beginning to learn -- has set me back, confused me, and left me unsure how to proceed. Anyone have thoughts? Is this plug in from Video Copilot the solution and if so, can it interact with my AE project as is or do I go back to the model and reimport and animate it anew? Thanks for any ideas.
Element is just another custom 3D render plug-in and share's the same limitations as all 3D-ish plug-ins in AE have - like not natively obscuring with AE's 3D layers. That said, from your description it sounds like what you want would be perfectly doable in Element, though, inside this closed eco system, but of course it's a whole different approach. And not to spell out the obvious: It's not available to the public yet, so if you are on a deadline, that doesn't do you any good and you'll probably have to stick with PS CS6 animation capabilities for the tiem being.
Mylenium
May 14, 2012 May 14, 2012
Thanks for your help. No deadline. Passion project. (I'm also no animator -- editor by trade). But the news I'm getting from you is I should plan to composite this in Photoshop. My workflow had been to create non-video elements in Photoshop and do video, composite, and animation work in After Effects. I think you're saying I can do the animation in Photoshop and should re-think my approach so my final project is created there. If Element shows up and can help -- although it may be too late in terms of my having gone too far down the road -- then I take a look at that. OK. I'm new enough to all of this that I think this only requires a brain reset.
Jun 08, 2012 Jun 08, 2012
When After Effects CS6 promised fully raytraced 3D and a 3D camera tracker, I expected 3D file import to come standard. What good is a 3D camera tracker if all I can use it for is text and flat images? Also, in one of the videos I saw on the After Effects webpage, I saw the person manipulating a hotwheels logo that was 3D extruded, then a 3D chair. Am I supposed to believe that someone modeled that 3D chair in after effects? Or was it imported?
Plenty. It's the single redeeming feature in all CS6, considering that most others do not work as advertised and make me wanna slap someone. Think of all those other 3D plug-ins that may benefit from it like partticle fountains integrated with your 3D scenery or such stuff... That part of the exercise is useful. i only wish it was actualyl fun to use CS6 for eve4rything else instead of being such a nerve wrecking experience....
Mylenium
But my point was, it would be exponentially more useful if I could use the camera tracker to insert a 3D object into a scene. It is helpful for things like diplaying graphics on a blank screen, or replacing the contents of a sign and things of that nature. Still, I would like it let me put a 3D object on a flat plane (maybe a stool on an empty wooden floor, or a book on a desk.
You can do that already. It's called a 3D program. That stool is gonna look a million times better with global illumination, proper texturing and environment in your 3D program than it ever could in AE's renderer. Well, at least the current 1990s plastic version of it, anyway. If that really is your point, then you should abandon AE and learn Blender, which - come to think of it - even has its own camera tracker.
Mylenium
I'd suggest another approach. I'd take your 3D elements and render them as multi pass plates with motion in your 3D app, then use AE to composite those elements in AE where you can add additional graphic elements, control the relationship between the various render passes (like reflections, specularity, diffusion).
If you're on a budget look at Blender. It is free, open source, and will export camera animations to After Effects perfectly.
Ok. maybe I should have been more clear. Yes, I can do the camera tracking and 3D rendering in a 3rd party program, but it seemed to me that the inclusion of these features (raytraced 3D and camera tracker) was to offer you the convenience of doing it in after effects, rather than having to render the footage and bring it into blender (or, in my case, I use Cheetah 3D). It would be much easier to work with because then I can manipulate the 3D object with all the other elements in the comp.
I'd much rather be able to do it all in after effects.
Message was edited by: superchuckinator - added specifics
Although I thought the raytraced 3D looked pretty darn good in the demo videos adobe showed off
You'll get much better results using a 3D app. Maybe it's time to look at efficient workflows. AE is principally a compositing program. Bringing in Photoshop 3D objects works, barely, with huge render times for the results. GPU based ray tracing (if you don't have a compatible cuda card) is also horrendously slow compared to the GPU ray tracing available in Blender or any other dedicated 3D app.
AE may eventually get there, but the basic structure of the pixel math AE uses will have to dramatically change to implement these changes.
My normal 3D workflow is:
  1. Concept sketches and or animatics generated on paper or in AE
  2. 3D Motion and animation tests using very primitive models
  3. If the CGI is going to be used with live video now is the time to plan and shoot the background plates
  4. 3D motion tracking of video (if needed)
  5. Motion Tests in 3D app
  6. Final texturing and lighting / rendering multiple passes
  7. Import passes into AE and Composite
This is for complex problems.
It's not necessarily meant to create complex geometry or render it ultra-realistic inside the program. Yes, it may be possible at some point to render your stool against a backplate and have it look like it was always there, but even then you wouldn't do some things in AE and the attainable level of complexity will be tied to specific rules and limits. Also you will stil lhave to weigh how sensible it will be to work in AE vs. a 3D program and consider some questions like whether there is more compositing than actual 3D or is it the other way around... It's about finding the most efficient workflow. As for the quality aspect - I've been doing 3D much longer than AE and I could tell you a thing or two about it, but let's just say that AE has a long way to go, if you want to go beyond all those reflective logos they always use in the demos...
Mylenium
The stool was really just an example to get my point across. So what you're saying is that what program I use depends on what my needs are. Lets say I had 3D shiny logo that I created in a 3rd party application, would it still be practical to (if this feature existed) import it into after effects, or would it be better to redraw it in Illustrator then extrude it in AE.
Jun 09, 2012 Jun 09, 2012
This depends entirely on your shiny logo and how you want to have it interact with the scene. I do 80% of that kind of work in Blender (or another 3D app) using artwork I created in Illustrator. I create my motion in the 3D app and do final compositing and tweaking in AE. If reflections (ray tracing) are not necessary to place my shiny logo in a scene as if it were really there I'll import a 3D object into AE using Invigorator. If the object is really simple and the shot is not very long I'll extrude in AE. I've only done experiments with Photoshop 3D. The results were OK but the workflow was way too slow to be useful to me. If I can't turn out product in a very short amount of time I can't make a living in this business and still have time to enjoy my family or my life.
So for the project I described earlier in this thread -- which consists of a stock 3D car to which I applied texture in Photoshop (re-colored it and added a taxi logo) and a street set I'm constructing out of 2D material -- mostly also in Photoshop -- with my intention being to animate the car driving past the 2D material -- the part I had planned to do in After Effects -- should I take the above discussion to mean I ought to be doing this all in Blender? I have only just begun to learn Blender and it hasn't had my highest priority. Is it able to import stock 3D models and 2D sets created elsewhere and then let me combine them with interactive lights and animate them with perspective? Before I drop everything I've been doing to take the time to learn a whole new program, I'd love some support in knowing that at least for this project, the effort is going to lead me where I want to go. Thanks for thoughts.
You can do exactly what you have proposed in AE with plug-ins or using Photoshop 3d import in CS5.5, but it's not going to be very efficient. Blender will import most standard 3D models and texturing is easy and much more powerful than it is in Photoshop. Depending on the time you have to devote to the project I'd say that you should be able to spend a couple of hours going through some Blender tutorials and have enough knowledge to texture and animate your vehicle with lights and a camera move. It would then, if you're a little familiar with 3D apps, take another couple of hours to set up the blender scene and render out the passes. If you're a complete novice the process would take a couple of days. An AE project using third party plug-ins or CS5.5 and Photoshop 3D could also easily take a couple of days (20 hours) for a novice. So I guess it's a tossup. There's a fair amount of support for both workflows.
OK. Thanks Rick. I guess in my case I'll be plunging back into Blender. I had recently been making my way through a Roland Hess book, but that -- as I suppose most Blender tutorials do -- assumes I want to do my modeling from scratch. I like knowing how that works in theory, but I doubt I'll ever have the time and patience to become a professional modeler. I do, however, want to know enough to be able to modify stock ones. Ironically, it was the intro of CS 6 and all the changes to the way it works with 3D that caused me to stop my Blender education in order to figure out what was going on with Adobe's stuff. Time to pick Blender up again it seems.
Thats exactly what I want: I want the logo to look like its in the scene, and I want to import it except instead of using invigorator, I want to be able to do it without shelling out a few hundred bucks for a plugin
Advocate ,
Take a look at Zaxwerks Proanimator. Its great for 3D logos and text and it runs as a plug in for AE. A few hours of tutorials and you will be amazed at what you can create.
http://zaxwerks.com/gallery/index.shtml
http://zaxwerks.com/proanimator/index.shtml
But the whole reason I joined this thread is to try to get funcionality like proanimator or invigorator without plugins, adding them to after effects would save me from having to shell out money for plugins
Advocate ,
Well, EXCUSE ME
It aint gonna happen at this time. If you are a pro making money from editing you buy the tools you need to get the job done.
