1. Re: prints come out as blank
Bill@VT Apr 7, 2012 4:59 AM (in response to firedancer442)Printing what to what. If you are talking about printing a PDF from Acrobat to the printer, did you select document as the part to be printed in the print menu, or just markup? Details and versions of software and OS are useful in helping.
2. Re: prints come out as blank
firedancer442 Apr 9, 2012 5:04 AM (in response to Bill@VT)Printing from reader to hard copy it doesnt matter where the PDF came from it wont print all I get is a blank page out of the printer
3. Re: prints come out as blank
Jntanyan Apr 15, 2012 2:44 PM (in response to firedancer442)We're having a similar problem with Mac OS (Lion 10.7) and Adobe Reader 10.1.3 update. Haven't been able to print any web pdfs since the 10.1.3 upgrade. A real pain with sites like Stamps.com!! Still no response to our forum post: http://forums.adobe.com/message/4333422#4333422.
Anybody?!?!
4. Re: prints come out as blank
Atul AgarwalApr 16, 2012 8:00 AM (in response to firedancer442)
Kindly update your application to the latest Adobe Reader 10.1.3.
Atul
5. Re: prints come out as blank
firedancer442 Apr 16, 2012 8:17 AM (in response to firedancer442)Updated to Reader 10.1.3 I still can not print any PDF Files
6. Re: prints come out as blank
Atul AgarwalApr 16, 2012 8:21 AM (in response to firedancer442)
Kindly uncheck the option "Print on both sides" available on Print dialog. Let me know if that helps.
Atul
7. Re: prints come out as blank
firedancer442 Apr 16, 2012 8:55 AM (in response to firedancer442)checked that the print both sides radio button is not selected still nothing
8. Re: prints come out as blank
sonal2890Apr 16, 2012 9:12 PM (in response to firedancer442)
Can you please check your preview box present at the right bottom corner of print dialog. Is the preview coming right?
If no, then please try changing 'Comment and Forms' option present just above it. Try selecting 'Document and markups'.
Hope this will solve your problem.
9. Re: prints come out as blank
jeffo555 Apr 19, 2012 6:16 PM (in response to firedancer442)I am having the same problem. I have mac 10.6.8, reader 10.1.3, firefox 11 and safari 5.1.2. Changed firefox to 32 bit, can view pdf's in firefox and safari, and can print in firefox and safari using the print icon on the pdf doc. However, I can not view or print blank pdf docs using the file print command from the firefox and safari toolbars. Printer works fine. Suggestions?
10. Re: prints come out as blank
Atul AgarwalApr 19, 2012 10:51 PM (in response to jeffo555)
Hi Jeff,
This is a known issue at our end and is being tracked via bug# 3167558 (providing this number for future reference).
I would not be able toc omment on when the fix could be released. however, I will keep you posted for any updates.
Atul Agarwal
Adobe System
11. Re: prints come out as blank
shehrki Apr 20, 2012 12:03 PM (in response to firedancer442)I'm having this problem too and I'm printing by using the print icon at the bottom of the screen. You don't get the same kind of options as from the file->print connections. I'm going back to an older form of this software. http://get.adobe.com/reader/otherversions/
12. Re: prints come out as blank
HJ77 Apr 9, 2013 8:00 AM (in response to firedancer442)In the advanced setting for your printer, you can select print as image....this solved the problem for me.
13. Re: prints come out as blank
Sendoku May 8, 2014 10:50 AM (in response to firedancer442)I am also having this issue with 10.1.9.
I have created a PDF form in Acrobat from another PDF and the latest version of Adobe reader prints a blank page when the form is filled out. I can print the page if I print it in black and white, or if I save the document, and reopen it, or if I print as an image. However none of these are convenient solutions for the people having to use this form.
The form will not print if it is downloaded and opened and then filled out and printed. It will however work in older versions of reader (10 and down). I believe this is due to an update with Acrobat's form builder, or Adobe reader not flattening the PDF properly when the form is filled out. Very confusing and frustrating.
14. Re: prints come out as blank
Dr. Pamela Rutledge Apr 15, 2015 9:23 AM (in response to firedancer442)Having same problem randomly. This morning with documents printing blank when scanned from ScanSnap using Mac OS Yosemite 10.10.3 printing to Brother 6080 but not from those printed to PDF in MSWord. Can only print when checking "print as image" in advanced but this makes them not searchable.
15. Re: prints come out as blank
monica_antonia Apr 27, 2015 11:33 PM (in response to Dr. Pamela Rutledge)1 person found this helpfulthis link fixed blank pages being printed for me! go to print-advanced options- click on print as image
16. Re: prints come out as blank
-thedude- May 7, 2015 10:50 PM (in response to Atul Agarwal)Hi Atul
I have tried all the mentioned fixes with no luck. When I print the PDF, it prints blank. I have the latest adobe reader installed. I have unchecked 'choose paper source' and 'print as an image '. It still prints blank.
Anything else i should do?
Please advise
17. Re: prints come out as blank
ksuguy May 16, 2015 10:16 AM (in response to -thedude-)I started to have the same issue last night on my Samsung printer. Here are some things I did. One, I noticed it defaulted to printing to One Note and not my printer. I also had to change the Quality advanced setting from 600 to dpi1200 . I was also printing blank pages from gmail so anyway hope this helps. I'm printing today.
18. Re: prints come out as blank
ksuguy May 16, 2015 10:19 AM (in response to -thedude-)I started to have the same issue last night on my Samsung printer. Here are some things I did. One, I noticed it defaulted to printing to One Note and not my printer. I also had to change the Quality advanced setting from 600 to dpi1200 . I was also printing blank pages from gmail so anyway hope this helps. I'm printing today. Also my drivers for my printer were recently updated via software update so I don't know if that had any impact or not. I went to my Samsung Easy Printer Manager app and made sure the settings looked okay and I had the right default printer selected. The good news is that it technically is "printing" now it's just finding out the setting or why it's not getting the text info. You may want to also mark print in gray scale to see if that has some impact. Good luck
19. Re: prints come out as blank
allieh31932593 Jul 20, 2015 5:25 AM (in response to firedancer442)Me too - seems to be since the update of Adobe software! Very fustrating. Adobe please fix asap
20. Re: prints come out as blank
egstl Jul 27, 2015 10:32 AM (in response to firedancer442)I was able to resolve it by taking the URL and pasting it into FireFox, which in turn allowed me to save it to my hard drive. I then opened the saved file in Adobe Acrobat, and it printed out correctly!
21. Re: prints come out as blank
rogerc77282027 Aug 19, 2015 8:34 AM (in response to firedancer442)My situation was even more weird. I created a pdf from several pdf files. When I printed it, the last 10 pages came out blank!!! I tried multiple changes as suggested above. nada. I went back to the original and did a save as smaller pdf, then inserted that into the master file in place of the previous pages, finally safved it all as small size pdf. Now it's printing. Very mysterious.
22. Re: prints come out as blank
LuckyLuke2 Aug 27, 2015 9:01 AM (in response to firedancer442)1 person found this helpfulHi,
save the file as JPG and then print.
That worked for me.
23. Re: prints come out as blank
piojarias Sep 1, 2015 7:32 PM (in response to firedancer442)2 people found this helpfulI had this problem many times and just found a possible solution.
May be you are printing a file that comes from a scanned image. So in the Print Menu go to the Advance options and choose "Print as Image".
You can look for more in
24. Re: prints come out as blank
itv70949108 Oct 1, 2015 12:01 PM (in response to piojarias)I have had this issue with scanned PDFs since upgrading to Reader DC. Reader says I need to install an Asian language pack, but that doesn't make sense.
Choosing to "Print as Image" still results in a blank page. Copying it to a JPEG works, although this is not a viable long term solution.
25. Re: prints come out as blank
Paul_dt Oct 8, 2015 1:52 PM (in response to itv70949108)I'm getting the identical message....to continue, I must install the Asian language pack?! Get on this Adobe!
26. Re: prints come out as blank
vaamorais Oct 12, 2015 9:07 AM (in response to Paul_dt)I think to have solved the issue on my end.
It seems that by installing the Asian Language Pack and choosing to "Print as Image" solves the problem.
By the way, I am using Adobe Reader XI v11.0.12.
Hope this helps.
27. Re: prints come out as blank
bernardoe62426296 Jan 6, 2016 6:09 PM (in response to firedancer442)You will need to upload the Asian Language Pack for the Acrobat Reader DC and it solves the problem. I uploaded and uninstalled Acrobat Reader DC 2015.00920069 several times and could not print some previous saved pdf files. With Acrobat Reader DC 2015.00920069 installed, I then uploaded the Asian Language Pack for the Acrobat Reader DC and bingo, the program prints all images. The problem of blank pages being printed is over, gone, absent.
28. Re: prints come out as blank
jesq Mar 31, 2016 7:45 AM (in response to firedancer442)Issue is still not fixed, but you can work around it.
1. Update to the latest Adobe by clicking Help/check for updates.
2. Click File/Print/ SUMMARIZE COMMENTS/ Click yes on pop up
3. That's it...this was the only thing that worked for me.
29. Re: prints come out as blank
Miguel Agawin Feb 2, 2017 10:22 AM (in response to firedancer442)Just an update to this old, potentially resolved issue as I've just experienced it for the first time: The unusual property in the PDF document with which I'm having this issue includes a complex or high-density vector graphic. My suspicion is it's a rendering/processing issue for the printer. I resolved it by reformatting said graphic to a high-quality bitmap image. Obviously not a perfect but if my hypothesis is true, the outcome could be a firmware issue on the part of the printer. (Using Acrobat DC 15.23.20056.213124 on El Capitan.)
30. Re: prints come out as blank
originalapache Feb 14, 2017 5:16 PM (in response to Jntanyan)i have same problem , I fill up my document , but the page print out blank with out the info!
mac OS sierra
V- 10.12.3
Adobe DC
31. Re: prints come out as blank
andreac81386378 May 16, 2017 3:11 PM (in response to originalapache)i tried everything up above, except holding a live chicken and dancing in the rain during full moon.
this issue was driving me crazy, and i was become desperate.
besides trying to download drivers, update my software for my Canon PIXMA 522, or for Adobe Acrobat Reader (don't have a paid version - and wouldn't buy one at this rate) - i also tried to convert them into other files (.txt, .jpg, .xlsx, .doc, ... ) NONE of that worked.
then, i deleted my printer from my computer (MacBook Air 2013, OSX Yosemite 10.10.5) - then added it back. FINALLY, everything worked again (as far as printing). good grief!! why would Adobe make such a user unfriendly program that brings us all to this page in panic, desperation, and different levels of frustration??
for the record, my printer seemed to work normally in every which way with all other programs and for other uses while i was in this battle to print ONE PDF file (which wouldn't convert to .txt or anything else because the OCR scrambled too many words).
32. Re: prints come out as blank
robertk36 Jul 27, 2017 7:47 AM (in response to firedancer442)I have a similar problem, where I create PDF's from Photoshop and when I try to print from Adobe Reader the pages would be blank. My solution was to go to Edit>Preferences>Security(Enhanced) and un-check Enable Enhanced Security
33. Re: prints come out as blank
Kaeon1 Aug 4, 2017 9:22 PM (in response to firedancer442)Windows 10 Version 1703 (16257.1)
Adobe Acrobat Reader DC 2017.009.20058
I also tried everything:
- Installing language packs
- Modifying every printer setting under the sun
- 'Print as image'
- No duplex
- Document / Document Markups / Summarize Comments / etc.
- Uninstalling and reinstalling the printer
No luck using Adobe Acrobat Reader DC to print my PDF. It always comes out blank.
I did however open the PDF in Chrome and selected 'Print using system dialog' and was able to duplex print my PDF successfully from there.
34. Re: prints come out as blank
rossh69207487 Nov 22, 2017 2:25 PM (in response to firedancer442)Frustrated too! My windows just upgraded to the "new" 1709 windows 10 version 16299.64. I'm running on a 64-bit Dell Laptop.
Up until the this new version of windows installed, adobe was running "slow" but at least it would print.
We scan to a pdf on an Epson scanner (not an all-in-one, just a scanner), it scans fine, image shows in Epson preview fine, saves fine. Open it in either preview or in Adobe, and it's BLANK, or the first page is blank and/or miscellaneous pages are blank, but WON'T print at all, all pages blank when printing.
We've uninstalled and then updated the scanner drivers/software, we've update the Adobe reader, we've removed and added the printer drivers, still nothing. I also have the full version of Adobe on another laptop, and it does it there too.
Sometimes it'll print from "quick print" but not every time. Some of the pdf's just spool forever and never print.
Something has changed and needs to be addressed ASAP.
35. Re: prints come out as blank
Abambo Nov 29, 2017 12:38 PM (in response to rossh69207487)There is apparently an update out, that solves the blank pages problem.
See this: Re: PDF prints come out as blank
