1. Re: Do LR editing operations commute?
RikkFlohr Apr 16, 2012 6:44 PM (in response to imagex ideas)According to what I've read, the Develop Pipeline is fixed and specific. The order in which the adjustments are applied is irrelevant. It is the final position of the sliders is the determining factor.
2. Re: Do LR editing operations commute?
DdeGannes Apr 16, 2012 7:43 PM (in response to RikkFlohr)Agreed, actually when working in the develop module Lightroom works with the original file and re-renders the file with every adjustment made and as Rikk says the adjustments are applied in a specific order. If you have made several changes to a particular setting e.g saturation, clarity, exposure it will render the net effect of each.
3. Re: Do LR editing operations commute?
imagex ideas Apr 17, 2012 7:05 AM (in response to DdeGannes)Are you saying that regardless of which order in which I actually apply the editing adjustments, LR rerenders the editing changes applying adjustments in its predetermined order. So, in my original post example if LR wants to apply Exposure adjustments before Tone Curve adjustments, it will do so even if I change the tone curve before I move the Exposure slider. If this is the case, is the predetermined order that LR uses essentially the top down order of controls on the Basic panel or something else?
4. Re: Do LR editing operations commute?
RikkFlohr Apr 17, 2012 7:10 AM (in response to imagex ideas)The predetermined order is not published. We can make guesses at the actual order but they are only guesses.
Whether you apply exposure as your first editing step or your last makes no difference. The rendering pipeline will apply it within a prescribed order.
5. Re: Do LR editing operations commute?
DdeGannes Apr 17, 2012 7:13 AM (in response to imagex ideas)As far as I am aware LR has not published the specific process order that it uses to render the final image. So the order you make the adjustments you wish to apply will not affect the final rendered image.
