1. Re: Splitting a circle up evenly
MikeGondek Apr 17, 2012 12:11 PM (in response to Josh525)Draw circle
Pull 2 guides for center
Draw a rectangle using the thicknes for your gap
Center rectangle on guides (recomend using smart guides on)
Rotate Tool
Option click on guides center, and enter 72° = 360/5)
CMD D to make 4 more copies
Select All
Pathfinder >>Minus front
Not sure what your second question is? Try the knife tool to split up your circel freehand, click and hold the eraser to to find the knife tool.
2. Re: Splitting a circle up evenly
Jacob Bugge Apr 17, 2012 12:34 PM (in response to Josh525)Josh,
Or you may, with no drawing/transforming at all:
1) Create a Polar Grid (Polar Grid Tool bundled with the Line Tool) with 5 Radial Dividers and no Concentric ones, size as the circle,
2) Select the Radial Divider Group and set the Stroke Weight to the desired gap width,
3) Object>Path>Outline Stroke,
4) Also select the circular path and Pathfinder>Minus Front (Subtract from shape area in older versions, maybe holding Alt/Option),
5) (Re)set the Fill colour (using the option at the bottom of the Toolbox).
3. Re: Splitting a circle up evenly
Steve Fairbairn Apr 17, 2012 4:52 PM (in response to Josh525)Or use a pie chart with 5 equal slices. Then Jacob's method
5. Re: Splitting a circle up evenly
Wade_Zimmerman Apr 17, 2012 7:32 PM (in response to Josh525)You can also try using this method in the video
http://www.wadezimmerman.com/videos/FiveSectionCircle.mov
BTW on the pc to draw a shape such as an ellipse from the center you hold down the control key.
6. Re: Splitting a circle up evenly
Josh525 Apr 18, 2012 10:07 AM (in response to MikeGondek)Hey guys. Thanks for your responses. I actually wanted to make the slices vertically through the circle to make vertical segments (rather than a pie chart effect). I guess the process for doing so remains the same.
I just wanted to check - after creating my segmented circle, I want to make each segment 3D as this design is for a Logo.
Which of the methods presented, would lend itself best to 3D designing? Or wouldn't it matter?
ie, If I created the segments using rectangles, would I then be able to edit/fill those segments individually?
Would one never just "draw in" the gaps from a circle template using the pen/line tool etc??
Many thanks again,
josh
7. Re: Splitting a circle up evenly
Jacob Bugge Apr 18, 2012 11:06 AM (in response to Josh525)Josh,
Ah.
You may quite easily:
1) Place a vertical line with the Line Tool, at 1/5 W from the left, Stroke weight equalling the desired gap,
2) Object>Path>Outline Stroke,
3) Object>Transform>Move a copy 3 times by 1/5 W,
4) Select everything and Pathfinder>Minus Front.
This will leave you with 5 simple paths, for easy application of 3D.
8. Re: Splitting a circle up evenly
Wade_Zimmerman Apr 18, 2012 12:08 PM (in response to Jacob Bugge) -
9. Re: Splitting a circle up evenly
Jacob Bugge Apr 18, 2012 12:19 PM (in response to Josh525)Josh,
If you do what Wade said, remember to rotate by 90 degrees.
10. Re: Splitting a circle up evenly
Wade_Zimmerman Apr 18, 2012 12:58 PM (in response to Jacob Bugge)Or just make the blend left to right as I already wrote in the first line of my response.
11. Re: Splitting a circle up evenly
Jacob Bugge Apr 21, 2012 6:02 AM (in response to Josh525)Josh,
I just rediscovered this thread, after having overlooked it, and realized my overlooking of the crucial left to right option mentioned post #8, as pointed out in post #10; the right wording in post #9 would have been:
If you do what Wade showed, remember to rotate by 90 degrees.
It is easier to look at a drawing, but sometimes full reading (and understanding) is better.
It has occurred to me that a literal interpretation of the OP and post #6 may be that the circle should be cut, but nothing should be carved out of it.
This would lead to a quite different solution, which may be done in a number of ways, the one shown below being silly but fun to make:
1) Create the circle,
2) Create a vertical line at one fifth from the left side (line Tool is fine), longer than the circle is high,
3) Move a copy of the line thrice by one fifth,
4) Join adjacent endpoints to create a single meander path of the four lines,
5) With only the path selected, Object>Path>Divide Objects below,
6) Move the slices apart (may be done four/two/one at a time with Object>Transform>Move).
Here shown for a circle without and with stroke:
